Cambridge Sept 2019 archiving thread
threads for previous physical ABug events
dv8
Re: Cambridge Sept 2019 archiving thread
Post by dv8 » Mon Sep 23, 2019 5:49 pm
tricky wrote:
Mon Sep 23, 2019 5:30 pm
Main booklet is about 60 a5 pages!
The main user guide has already been done (see this thread)
I would only need the text to speech booklet.
Post by CMcDougall » Mon Sep 23, 2019 7:03 pm
Paul wrote:
Sun Sep 22, 2019 10:28 pm
Boots Tape C15 R-Soft
No UEF
here : viewtopic.php?f=32&t=12748&p=163894&hil ... ft#p163894
dv8
Post by dv8 » Mon Sep 23, 2019 7:46 pm
tricky wrote:
Mon Sep 23, 2019 5:54 pm
Sorry, 8 A5 pages ;)
Sounds doable, I should be able to put a PDF together pretty quickly.
Post by CMcDougall » Mon Sep 23, 2019 8:17 pm
Paul wrote:
Sun Sep 22, 2019 10:36 pm
Simonsoft - Disassembler
that is sideA, being the HELP file,
did sideB work at all, should be a file called GO :
Post by CMcDougall » Mon Sep 23, 2019 9:15 pm
Paul wrote:
Sun Sep 22, 2019 10:29 pm
Colisoft - Personal Quiz
don't waste time on that either, its already here, but as a SSD :
viewtopic.php?f=7&t=8082#p84942
Site Admin
Post by Arcadian » Mon Sep 23, 2019 11:41 pm
lurkio wrote:
Mon Sep 23, 2019 3:09 pm
Arcadian wrote:
Sat Sep 21, 2019 11:06 pm
:shock:
An interesting find!
Was it archivable?
Now here.
Post by Paul » Tue Sep 24, 2019 1:22 am
I may have digitised the other side. I'll take a look over the next few days.
Paul.
Post by Paul » Tue Sep 24, 2019 1:29 am
Is there a way to create a CSW file under Windows 10?
Paul.
Post by CMcDougall » Tue Sep 24, 2019 5:47 pm
/\ only in dos window, from Start >cmd.com or exe can't mind which.
am lazy & use winXP as it does not have updates every 2hrs :x
EDIT, now on win10 lappy, it says "ask vendor for 64bit version" :?
Post by RobC » Tue Sep 24, 2019 10:24 pm
acorn wrote:
Sat Sep 21, 2019 9:50 am
I would like to advocate for the archival/scan of:
CH51971 Investigator III
(possibly CH33988 Investigator)
If they haven't been archived, I think I have Investigator II and Investigator III. I'll check over the next few days.
Prime
Post by Prime » Tue Sep 24, 2019 10:40 pm
If it's a DOS program then you could use Dosbox to run it.
Phill.
leenew
Post by leenew » Fri Oct 04, 2019 9:36 am
Paul.
Hi Paul,
have you got anywhere in creating useable files for the software you archived? [-o<
Lee.
Post by CMcDougall » Sun Oct 06, 2019 9:06 am
/\ I sent a PM 5days ago, still in outbox....
Post by Paul » Mon Oct 07, 2019 8:01 pm
Sorry for the delay. Its the busiest time at work, and as noted, I've not been able to catch up on these bits. I've even got another 4 hours of work before I get to look at this. But I'll try to get to it after or tomorrow.
Cheers!
Paul.
Post by CMcDougall » Sun Feb 02, 2020 10:10 am
hi Paul, did you find time to upload files so could have a bash? please send links here or PM again
8)
Return to “past physical ABug events”
