A3010 Econet
A3010 Econet
So, I bought a relatively clean A3010 at the last RONWUG meeting. Got it cleaned up, fitted an IDE interface, but it just didn't feel right without Econet. Looking at the A3010 and A3020 circuit diagrams, there are only 3 signals that aren't available on the mini-podule interface, and one of them is failrly easy to find on a PCB pad. The other two signals need to be picked up from the ARM250, so soldering those on was a bit hairy. But it works.
Unfortunately the signals on the podule are not the right way round for the Econet module to plug in the right way round, so it's currenyly fitted at an odd angle. The other 14 signals are a one-to-one mapping on SK5.
Using the alternative keybaord connector made this a lot easier.
Just need to tidy it all up so I can fit Econet and IDE together.- flaxcottage
Re: A3010 Econet
Very well done!
- BeebMaster
Re: A3010 Econet
What’s the alternative keyboard header do? I don’t recall the the 3010 having a socket for one but it’s a long time since I saw one.
Re: A3010 Econet
It's a header where you can connect an alternative keyboard. Too obvious?
You can bypass the on-board keyboard controller and connect a standard Archimedes keyboard instead. I think all the Arc's with built in keyboard had that facility (A3000/A3010/A3020). They are usually marked as a "no fit" header on the circuit diagrams, but this A3010 had it fitted and it looks original. You need to change one jumper to use the alternative keyboard, you can't use both at once.
Re: A3010 Econet
You also can't use the built in mouse socket when the link is changed to alternative keyboard... so you need to plug your mouse into the external keyboard rather than into the back of the A3010 (or underneath the A3000)
I suspect the alternative keyboard link was provided for testing/repair purposes (at least that's what I use it for!) - you can't get at much of the computer pcb with the original keyboard fitted...
Re: A3010 Econet
...but back to the topic, that's an excellent piece of work, I'd never considered trying to get econet on the A3010. Other than tapping those lines from the ARM250, is there some additional rewiring going on behind the econet board in the picture? Or are most of the connections in the correct order in the socket (just with the board inverted?).
Presumably this will work on the A3020 and A4000 too...
Re: A3010 Econet
Pins 2-17 of the mini-podule socket are identical pin-for-pin with an Econet module, so no extra wiring. (Obviously the select signal on the mini-podule connector is for podule address space). It sort of makes sense if you look at the first machine with a mini-podule connector, the A3000, and look at where the econet podule plugs in. I guess they did it for ease of routing.steve3000 wrote: ↑Thu Aug 29, 2019 9:04 pm...but back to the topic, that's an excellent piece of work, I'd never considered trying to get econet on the A3010. Other than tapping those lines from the ARM250, is there some additional rewiring going on behind the econet board in the picture? Or are most of the connections in the correct order in the socket (just with the board inverted?).
No point, you can plug a module straight in, the pins from the Arm250 are tracked to the econet connector already.
Re: A3010 Econet
Yes, makes sense!IanS wrote: ↑Thu Aug 29, 2019 9:13 pmPins 2-17 of the mini-podule socket are identical pin-for-pin with an Econet module, so no extra wiring. (Obviously the select signal on the mini-podule connector is for podule address space). It sort of makes sense if you look at the first machine with a mini-podule connector, the A3000, and look at where the econet podule plugs in. I guess they did it for ease of routing.
Re: A3010 Econet
Yes
It didn't occur to me that the built-in keyboard would be in the way.
Re: A3010 Econet
Ian where did you get the cable/connector from for the other keyboard? The cable you connect to the white header ? I have an adelaide A3010 I need to diagnose and being able to plug in an external kboard would help a great deal as reconnecting the ribbon evry time is what made me give up swear lots and leave it in a mess... or at least thast was one of the reasons...IanS wrote: ↑Tue Aug 27, 2019 10:25 pmSo, I bought a relatively clean A3010 at the last RONWUG meeting. Got it cleaned up, fitted an IDE interface, but it just didn't feel right without Econet. Looking at the A3010 and A3020 circuit diagrams, there are only 3 signals that aren't available on the mini-podule interface, and one of them is failrly easy to find on a PCB pad. The other two signals need to be picked up from the ARM250, so soldering those on was a bit hairy. But it works.
Re: A3010 Econet
I cut the end off a PS/2 extension cable and then crimped on a few contacts and added the white housing. So DIY. (You probably need to check that the cable is fully populated as PC PS/2 peripherals don't use all 6 pins)AndyMc1280 wrote: ↑Fri Aug 30, 2019 4:00 pmIan where did you get the cable/connector from for the other keyboard? The cable you connect to the white header ? I have an adelaide A3010 I need to diagnose and being able to plug in an external kboard would help a great deal as reconnecting the ribbon evry time is what made me give up swear lots and leave it in a mess... or at least thast was one of the reasons...![]()
It's amusing to me that the alternative keyboard connection has generated as much comment as the Econet module.
Re: A3010 Econet
More information here: viewtopic.php?f=16&t=13291&p=173332#p173332
Re: A3010 Econet
Does this mean we have an econet solution for all the acorn machines except the phoebe (which no one has anyway)?
Re: A3010 Econet
Pardon my ignorance, but where does the 5 pin econet socket itself go ?
Re: A3010 Econet
At the moment it's just on the end of a cable plugged into the 5 pin header on the module. Long term, not sure, probably attached to a din socket on a podule backplate.WrightStuff wrote: ↑Fri Aug 30, 2019 9:05 pmPardon my ignorance, but where does the 5 pin econet socket itself go ?![]()
Re: A3010 Econet
Re: A3010 Econet
Can put Econet on the network connector and Ethernet on a mini podule.Perhaps it would allow Econet and Ethernet to be fitted at the same time?!
