BeebEm Mac - Info
Re: BeebEm Mac - Info
Post by lurkio »
SpaceFlightOrange wrote:
Thu Apr 25, 2019 12:36 pm
Count me in on this. I'm happy to help out. I have an active Apple developer account also. Can i suggest that look to rebuild the UI out in Swift?
No one is actively working on fixing bugs in Mac BeebEm or on developing it at all.
This is an open call for anyone with the skills and interest to do so to make themselves known, please..!
[-o<
JudgeBeeb
Post by JudgeBeeb »
lurkio wrote:
Thu May 02, 2019 1:11 pm
please do add it to the list of Issues on Github. All potential issues need recording.
Done
I don't believe anyone is actively developing it currently. guddler no longer has time to.
That's a great pity. Hopefully someone will come forward. I would love to assist; but I just don't have the skills.
SpaceFlightOrange
Post by SpaceFlightOrange »
lurkio wrote:
Thu May 02, 2019 1:13 pm
[-o<
I’ll start picking this up. I don’t have a huge amount of time and I’m working (or about to start work on) another project: a new disk image explorer for MacOS, which is mainly a learning exercise for me to get my head around the disk image formats, etc. But once that’s done, i’ll Move on to BeebEm.
Just dont expect anything right away [-X
I really want to work on this though, so I’m pretty motivated :D
Last edited by SpaceFlightOrange on Thu May 02, 2019 2:25 pm, edited 1 time in total.
James
BBC Model A Issue 3 (Upgraded to Model B), IFEL TurboMMC, IFEL ROMRAM-B4, Pi-Zero CoPro, VideoNuLA
Master 128, Watford Quest Mouse, Gotek, Pi-Zero internal CoPro, Pi-1Mhz HDD, RGBtoHDMI
Opus Dual 40/80 FDD
guddler
Post by guddler »
If you want any info regarding where I got to then feel free to PM me.
SpaceFlightOrange
guddler wrote:
Thu May 02, 2019 2:33 pm
Will do. Thanks.
I've forked the repo. Haven't tried building yet. I'll have a look through this weekend and then drop you a message.
James
Opus Dual 40/80 FDD
richmond62
Post by richmond62 »
I can confirm that this:
https://drive.guddler.uk/d/f/443181297079165026
runs without hitch on MacOS 10.14.5 beta 5. :D
guddler
Post by guddler »
That’s good to hear!
Incidentally, I forgot that link was there. It’s the same as the release on the official site now so no need to use my link.
SpaceFlightOrange
Hello.
Just an update. As you know MacOS Catalina is in Beta, and will be released in September. With this release, Apple are dropping support for 32-bit applications.
BeebEm Mac uses the Carbon API to run. This was deprecated in 2012, and as such, Apple never created a 64-bit version of Carbon.
This means that the Current BeebEm will not run on Catalina, you will see this if you try to install and run:
I've finally gotten round to looking at this, but it's going to take a lot of work. It doesn't help that I have no Carbon experience. My thoughts at the moment are to recreate project, and rebuild the UI using storyboards and swift. You can't bridge the C++ code to swift, so, to do this will mean creating an Objective C wrapper.
My first step is to try and understand how the code all fits together currently, I don't know if Jon W or Guddler can help out here?
I'll try and get this done in time for the official release.
James
Opus Dual 40/80 FDD
g7jjf
Post by g7jjf »
I don't know anything about storyboard, Swift or Objective C but if you want to contact me personally, I will try and answer any questions you have about how things fit together at the moment.
Post by Elminster »
A slight aside but going to Catalina is going to be a pain. I have loads of 32bit apps where I either need to find a replacement, as no longer made, or pay money to go to a 64 bit version. And must 64bit versions outside of App Store are going subscription based.
I do have a VM for Mac, will have to upgrade to Catalina and start testing.
guddler
Post by guddler »
Well it’s not like we haven’t known about this for a long, long time now! Pretty sure this is my only 32bit app left although I do need to check the JDK I use for work.
I’ll bow out now as I can’t be of any further help. I only really stepped in to build the current signed version and never got round to digging much deeper.
Post by lurkio »
Well, many thanks to guddler for ensuring that Mac BeebEm works on Mojave. I guess the torch passes to James/SpaceFlightOrange now to see if he can cut a path through the tangle of APIs and knock the app into shape for future versions of macOS. Good luck!
Incidentally, I've finally upgraded to Mojave after years of what I now realise was pointless languishing on Yosemite. A couple of thoughts:
  • JSBeeb doesn't produce any sound in Safari 12.1.1. Is that the same for everyone or is it just me? (I'm seeing the issue in all versions of JSBeeb: the ones on bbcmicro.co.uk and the latest one on bbc.godbolt.org too.) [UPDATE, December 2019: The latest version of JSBeeb has now been updated to produce sound in (some or all versions of) Safari on MacOS.]
  • Thanks to guddler, Mac BeebEm still seems to work fine on Mojave, but so too does the beta of the Windows version of BeebEm 4.15 when it's installed with WineBottler so that it runs under WINE. Does anyone know if WINE and WineBottler will still work in Catalina (the next version of macOS)?
  • Having upgraded to Mojave, I finally have a version of macOS that can comfortably run b2 — Tom Seddon's new Beeb emulator. Looks good! I'll have to play with it a bit more.
SpaceFlightOrange
g7jjf wrote:
Mon Jul 01, 2019 7:16 am
Thanks Jon.
I'll drop you a line when I've got my head into the code properly. Its mainly going to be about Carbon, Nothing about Swift etc.
James
Opus Dual 40/80 FDD
Post by Elminster »
guddler wrote:
Mon Jul 01, 2019 9:20 am
Unfortunately, I can't make people update to 64bit.
I have a few on my Mac:
  • webex plugin
    meeting centre plugin
    Myharmony remote software
    Network config software (I do have an app I can use)
    Steam and a few games.
Loads of others but probably will just delete them/find equiv 64 bit software.
Hopefully as we get closer 64bit versions will come out, I suspect the games will never work though. Not that I ever have time to play them.
But I am happy to test Beebem if/when updated if I upgrade my VM to Catalina.
Edit: one less, I noticed cool term released 64 bit version for Mac
Post by lurkio »
Mon Jul 01, 2019 3:47 pm
Thanks Jon. I'll drop you a line when I've got my head into the code properly. Its mainly going to be about Carbon, Nothing about Swift etc.
Btw, I know it's still early days, but do you want me to request that you be added to the Stardot Mac BeebEm GitHub?:
richmond62
I am currently running Mac OS Mojave and keep getting the Cataline Beta "shoved up my nose", but have no intention of
upgrading as about 75% of the software I use on a daily basis is 32-bit only.
Mind you, I have a PPC G5 iMac running Mac OS 10.4 and 9.2.2 because I've a slew of software I still use that
is dependent on that machine.
SpaceFlightOrange
lurkio wrote:
Sat Jul 06, 2019 1:03 pm
That would be good, but there's no rush. I've Forked and any changes I was going send back via a PR.
James
Opus Dual 40/80 FDD
Post by Elminster »
Been on Catalina a week now, no issues, other than BeebEm doesn't work of course. Only app so far, as there was a flurry of 64bit app updates in the last couple of months.
Was a smooth process. Unlike IOS13 (unlucky for some) which bricked my Ipad air2 (as it did for many people), had to do a DFU restore, the normal restore would not work, even now it is very sluggish (Apple telling me to buy a new iPad maybe).
richmond62
Well: what can I say except:
1. They don't make their products because they love you.
2. If the blatant commercial push of Microsoft and Apple get too much it is probably time to consider Linux.
3. In the light of #2 I should like to point out that this, hypocritically, is being typed on a December 2018 Mac Mini.
4. AND, re #2 as well, (this could run and run), I am well fekked-off with the Ubuntu people giving up on 32-bit
versions as my EFL school runs 10 32-bit computers that are on average about 10 years old that do just fine for
what they are intended (content delivery and reinforcement) . . . so they'll be stuck on Xubuntu 18.04 until
they go "bang." :D
5. Why do so many people get an uncontrollable urge to 'upgrade' their computer systems when it isn't
always in their best interests?
6. Any "Nutty Fruitcakes" round these parts using absolutely neolithic computers such as the BBC Model B
should understand that #5 is a moot point. 8)
7. Still having problems retrieving saved programs from my cassette player: so really haven't got time to worry
about Macintosh 10.15.
Post by Elminster »
richmond62 wrote:
Sat Oct 19, 2019 9:47 am
Well I have been using Linux for 25 years, just after Linus lunched it to the public, I am also an expired RHCE, but I still prefer MacOS as my main desktop, I have Linux on the laptop (but it is 64bit :) )
Edit: before Linux used to play with FreeBSD flavours, but forward thinking techies installed this new Linux thing in several of the labs at uni. I wrote a MUD on them as my final year project.
because you have no choice if you want to talk to other stuff, Apple only release security fixes for last 3 MacOS, and one previous version of IOS. Putting insecure system anywhere near the internet is asking for trouble. On an isolate network that is fine, as long as no usb or other media will be plugged in.
richmond62
That is rather specious, and most of it is propaganda pushed out by Microsoft and Apple.
I stay in Bulgaria (the home of Viruses, Trojans and all sorts of other internet "evils"), and have been
running a load of G5 iMacs running 10.4 and 10.5, Intel iMacs running 10.6 and 10.7, an ancient Mac Mini running 10.4
and so forth for about 12 years now: all connected to the internet, and never once had any trouble: if one is prepared to make
a small effort one can do just fine.
I am continually "talking" to all sorts of other machines. 8)
Post by Elminster »
richmond62 wrote:
Sat Oct 19, 2019 7:35 pm
Most of the succeful hacks on business are usually exploiting vulnerabilities that have already been fixed in new versions of the O/S or patches have been done but not applied. Rather than the zero day hacks. I am afraid it is all true, and I have had to sort a number of hacked system before, as part of my day job, all were avoidable if up to date O/S had been used, or he system had been setup correctly.
Lots of Denial of service bots attacks make use of unpatch machines to launch attackers on networks that are hardened. It is just how things work.
It is it so much that Apple force you to upgrade, it is more that they don’t security patch systems older than 3 years old that is the issue.
I treat my home network like I would a customers.
You can of course do what you want, just don’t launch any bot net attacks my way. :evil:
Edit: I should also point out the hacked system were all Linux, not an issue with Linux per sa, as they hadn’t been patched or hardened correctly.
Post by Elminster »
running a load of G5 iMacs running 10.4 and 10.5, Intel iMacs running 106 and 10.7, an ancient Mac Mini running 10.4
All about the risk you are willing to accept, and how it is managed. Generally people aren’t going to be writing new stuff targeting old architectures and O/Ss,but that doesn’t make it invulnerable. There is always a risk.
But possibly digressing now away from original topic about Beebem..........
richmond62
Gosh, Yes, guilty as charged. :D
ACCORDIONMAN
Post by ACCORDIONMAN »
Sorry to revive an old thread but does anyone know the latest on BBC emulators that might run in Catalina?
I want to upgrade very soon (if not now) and I've just got into using BeebEm. It's lots of fun playing the old games from my 1980's childhood, I don't want to loose that! I know I can do it online but I prefer having the emulator inside my computer.
Any developers working on a 64 bit version?
Many thanks for any info
DavidK
Post by DavidK »
Hi there. I can't answer your question about the compatibility of emulators, but one option you could consider is keeping both OS's (Catalina and Mojave) on your Mac. I'm running both versions as I have a number of legacy apps that aren't compatible with Catalina. I also have a 3rd partition with Windows on, which means I can use the Windows version of BeebEm.
There's plenty of guidance out on the web on how to do this, but these seem to be the clearest:
https://www.macworld.co.uk/how-to/mac-s ... c-3659676/
Post by lurkio »
ACCORDIONMAN wrote:
Sun Dec 29, 2019 9:30 am
I believe that (i) b2 and (ii) Windows BeebEm (under WINE, via WineBottler), which I mentioned above, will both run on Catalina, although I haven't installed Catalina myself -- I'm still on Mojave -- so I can't be 100% sure.
I too like Mac BeebEm, even though it's not the most fully featured or cycle-accurate Beeb emulator around. It's because of its "clean" and simple UI and its general Macishness, I think. If you don't want to lose Mac BeebEm, then don't upgrade to Catalina yet! (Unless you know how to virtualise an installation of Mojave under Catalina -- if that's even possible..?)
This was the very thread where people were talking about updating (i.e. rewriting) Mac BeebEm to be a 64-bit app, but it's gone a bit quiet lately. I'm not aware that anyone's actively working on this at the moment, I'm afraid.
Post by Elminster »
Just confirming what others have said.
Having been in Catalina since it came out it seems very stable. But yes 32 bit apps just don’t run. I think apart from beebem most things had a 64bit version or I didn’t use the app any more.
The biggest killer is if you have a lot of games, as they won’t ever be updated. So either you have to keep an old version of Mac OS kicking about, or have access to windows (sometimes Linux). Same fixes for games apply to Beebem. B2 works from memory.
I use VMware fusion, and also have an old Mac mini kicking about
ACCORDIONMAN
DavidK Lurkio Lminster
Thankyou very much for your replies, I've actually made the jump to Catalina now. The stress level Apple were creating for me by keeping reminding me to update, was just slightly higher than my desire to run the BBC Emulator! I feel like the simplest thing for me to do if I want to play those old games, is just use the online BBC Games Archive site.
This definitely works well on Chrome (at least for Chuckie Egg, which I like!). The only thing I would love is if there was a full screen mode (perhaps I just can't find it) But I can zoom in!
I hope someone makes a 64 bit version, that would be awesome. But for now I think the online site is going to work for me.
Thanks again for your help - this is obviously a friendly forum!
richmond62
Yes, Horizon does . . .
https://www.bannister.org/software/horizon.htm
"I'm delighted to announce that a major update for my emulator shell is now available, adding support for macOS Catalina and significantly improving support for macOS Mojave."
I still haven't worked out why Horizon seems a dirty word and a taboo subject round these parts.
