Please could someone build a new beebdroid
Re: Please could someone build a new beebdroid
Post by tricky » Sat Mar 02, 2019 10:24 pm
I think I found it from a "sped up version" that used wire frame for the keyboard.
Stainy
Post by Stainy » Sun Mar 10, 2019 2:26 am
Are you able to share it??
Possibly? :)
Post by tricky » Sun Mar 10, 2019 10:13 am
I have this APK for the wire-frame version in my dropbox no login should be required.
It does have the bug that was the reason for my original request and this thread, annoyingly, it mostly affects my games!
I won't pass on the b-em based one without the author's consent.
Stainy
Post by Stainy » Sun Apr 07, 2019 6:38 pm
But when I try to install it it says "appears to be corrupt' :(
Stainy
Post by Stainy » Thu May 23, 2019 11:42 am
I finally got it installed on my GPD XD+. ( silly Admin thing in security was blocking it )
But I get no sound.. and there`s no settings to speak of...
derek
Post by derek » Fri May 24, 2019 11:54 am
I downloaded the new beebdroid and installed on a Samsung SM-T530 Galaxy Tab 10, it work much better than the plsystore version.
I like that local ssd files can loaded anb self written programmes can be saved easily.
Regards,
Derek
Stainy
Post by Stainy » Sun Jun 09, 2019 2:04 pm
I get no sound on my LG V20 and GPD XD+ :(
Warwick
Post by Warwick » Tue Jan 07, 2020 7:51 am
I've been working on a fork of Little Fluffy Toys' Beebdroid on GitHub - user sleekweasel - over the past couple of months.
It complies under Android Studio and fixes the position independent code issue that probably stopped most people working on it.
It also makes it work properly with Bluetooth keyboards for programming (taking over the 'no keyboard' mode) which does weird things to the shift key, though it would be easy enough to create a new no keyboard mouse if that's a problem.
I've also restored the machine image save/restore code and have plumbed adval 1 and 2 into the mouse x and y coordinates, though it needs some trickery to avoid mixing last x with the current y (I'm planning to set the lower bit as a simple timestamp).
There's an APK under the releases tab.
Post by tricky » Tue Jan 07, 2020 7:48 pm
Not sure about position independent code, my main problem was the bug in the ARM ASM for I think a sbc ZP,X instruction (or something like that).
Warwick
Post by Warwick » Wed Jan 29, 2020 10:43 pm
There's a patch for that; I haven't encountered anything triggering it, but it was on my radar to check. Kenton has reached out to me, so hopefully we'll update on the play store (and probably Amazon, since it's deeply amusing to have a Beeb appear from the Firestick, and use a Bluetooth keyboard with it).
If you look in my GitHub - sleekweasel - you'll find a couple of APKs in releases. Give me a test case for the SBC instruction, and I'll get a fix up.
