Mainframe - Talk To Me
msknight
Post by msknight » Fri Jul 20, 2018 9:38 pm
Hi Folks,
My BBC related activities have been quiet for a while as I've been digitising my record collection and doing my cack handed repair of walkmans and things.
Anyway, I came across, "Talk To Me," by a short lived group called, "Mainframe." They released code on the B side of the record which basically turns the computer into a simple colour display that reacts to the tape in port, if I remember.
I've put it up here for those interested - http://msknight.com/bbc/mainframe.html - audio files are recorded as flac.
Re: Mainframe - Talk To Me
Post by lurkio » Thu May 16, 2019 7:45 pm
Some more info about the band Mainframe and their computer programs on vinyl, from the January 1984 issue of Computer Answers magazine. (Content warning! You wouldn't get away with this sort of language in Micro User...):
Article
Has anyone tried to load and run the program in the audio file linked from msknight's original post, above?
Post by CMcDougall » Thu May 16, 2019 10:42 pm
^just seen this, will give it a 'spin' tomorrow after 7pm... don't get hopes up as it says only cost £1.50 for the vinyl :shock:
Post by CMcDougall » Fri May 17, 2019 5:39 pm
here we are :
BBCB-TalkToMe.uef
uef
(1.48 KiB) Downloaded 22 times
Post by lurkio » Fri May 17, 2019 10:13 pm
here we are :
Cheers! The program was designed to react to audio signals coming into the tape socket on the Beeb, and the idea was that you were supposed to plug a cassette recorder or record player into your Beeb to get a sound-and-light show.
I'm not with my Beebs at the mo, and I can't play music into a real machine, so the only way I could see if the program worked was by trying to find an emulator that would play a UEF even when no CHAIN or *RUN command had been issued. The only one I tried that did was B-Em:
Post by Pernod » Fri May 17, 2019 10:22 pm
There was a similar program published in C&VG called Disco Lights. It's on my Graphic and Drawing Programs disc at viewtopic.php?f=32&t=5802&p=73044#p73044
PS. You'll need a Watford DFS supporting 62 files for some of the menu items.
Post by lurkio » Sat May 18, 2019 1:25 am
Thanks. Looks like the C+VG program was also the work of Colin Holgate of Mainframe (as was the program on the LP):
