Acorn Graphics Extension ROM (GXR) User Guide [Remastered PDF]
avoid work duplication! collaborate on the archival of acorn literature!
dv8
Post by dv8 » Mon Apr 01, 2019 10:29 pm
Attached is a remastered PDF of the Acorn Graphics Extension ROM user guide along with the reference card and keystrip.
The included zip file contains:
  • two GXR ROMs (version 1.20 for the Model B and version 2.00 for the B+)
  • two SSD disc images containing the above ROMs, listings from the manual and extra programs from a cassette originally supplied with the GXR. The Sprite disc also contains the Master Sprite ROM. Both discs can be booted with Shift+Break to show a menu of available programs.
Graphics_Extension_ROM.pdf
(266.73 KiB) Downloaded 956 times
Graphics_Extension_ROM_Reference.pdf
(46.54 KiB) Downloaded 254 times
Graphics_Extension_ROM_KeyStrip.pdf
(14.67 KiB) Downloaded 163 times
Graphics_Extension_ROM.zip
(70.46 KiB) Downloaded 78 times
Other remastered user guides you may be interested in:
Computer Concepts Graphics ROM User Guide
BBC Micro User Guide (Model B and B+ editions)
Advanced User Guide
New Advanced User Guide
jms2
Re: Acorn Graphics Extension ROM User Guide
Post by jms2 » Mon Apr 01, 2019 11:11 pm
That looks terrific! It must have taken ages to get it that good!
I may have the card.
Post by lurkio » Mon Apr 01, 2019 11:37 pm
Attached is a remastered PDF of the Acorn Graphics Extension ROM user guide.
Superb! This has prompted me to do a quick rewrite of the circles/interference program using the GXR ROM:
Lardo Boffin
Post by Lardo Boffin » Tue Apr 02, 2019 7:22 am
I have the reference card and will take some photos later on when it is a bit lighter.
You may need to pm me an email address to send the photos to otherwise they will be compressed if put as attachments on here.
Adventure Language on GitHub
Atom, issue 5
Elk
Post by tricky » Tue Apr 02, 2019 8:32 am
Thanks for these, does it happen to mention any differences between this and the built in version on the master?
Lardo Boffin
Post by Lardo Boffin » Tue Apr 02, 2019 9:07 am
The card is 13MB scanned at 250DPI.
Atom, issue 5
Elk
dv8
Post by dv8 » Tue Apr 02, 2019 10:22 am
Thanks. Short books like this really don't take too long, especially when they have a bunch of listings that can just be copy+pasted.
It predates the Master so no mention of it. As far as I know the Master MOS contains everything except the sprite routines and editor. These are available as a separate file on the Welcome disc that needs to be loaded into sideways RAM.
The file size can often be reduced dramatically by scanning in black+white or even better in 1-bit monochrome (often called 'text' or 'line-art' mode in scanner software) and saving to a lossless format such as PNG.
I usually scan text documents at 600 DPI mono and they come out at a few hundred K per page.
Failing that the scans could always be uploaded to a file sharing site like DropBox.
Post by flaxcottage » Tue Apr 02, 2019 10:38 am
That is brilliant quality. =D> =D>
Lardo Boffin
Post by Lardo Boffin » Tue Apr 02, 2019 12:03 pm
I only have a cheap and cheerful scanner but here goes. If these are not good enough I can re-do and put them on Dropbox or similar.
GXR02.zip
Inside
(265.48 KiB) Downloaded 56 times
GXR_01.zip
Front and back cover
(144.29 KiB) Downloaded 52 times
Atom, issue 5
Elk
dv8
Post by dv8 » Tue Apr 02, 2019 12:15 pm
Perfect, thanks.
I should be able to get the PDF done later today.
Lardo Boffin
Post by Lardo Boffin » Tue Apr 02, 2019 2:30 pm
For completeness here is the key strip.
KeyStrip.zip
(57.14 KiB) Downloaded 59 times
Atom, issue 5
Elk
dv8
Post by dv8 » Tue Apr 02, 2019 4:44 pm
I've now added PDFs for the Reference Card and keystrip to the opening post. Thanks to Lardo for the scans.
Lurkio has also found an error on page 16 of the main guide. I'll leave it a day or two to see if any other errors are discovered and then reissue a corrected PDF.
Lardo Boffin
Post by Lardo Boffin » Tue Apr 02, 2019 8:27 pm
Nice PDFs! Top stuff. =D>
Atom, issue 5
Elk
dv8
Post by dv8 » Fri Apr 05, 2019 12:41 pm
A corrected version of the main user guide has now been added to the opening post.
pixelblip
Post by pixelblip » Thu Apr 11, 2019 12:56 pm
Thank you all of you for your brilliant effort. Much easier to read than the txt version.
This rom is so awesome with so many shades and colours. A lot of life left in it yet!
elkrepair
Re: Acorn Graphics Extension ROM (GXR) User Guide
Post by elkrepair » Thu Jan 23, 2020 9:35 pm
Hi.
I have a Graphics ROM, but when I type *HELP it doesn't appear. Also, when I type *GXR the Beeb just hangs.
I guess the ROM has gone to the great silicon repository in the sky. :(
Elk rev 4 & Plus1
BBC B rev 7 & Cumana Disc Drive
BBC micro:bit
RaspberryPi B+ & 3B & Zero
Abit BP6
dv8
Post by dv8 » Thu Jan 23, 2020 11:06 pm
It might be the Computer Concepts Graphics ROM rather than the Acorn GXR.
Try entering *FX162 then *HELP. If it's the CC ROM it will be listed as GRAPHICS EXTENSION 2.09
*HELP GRAPHICS will then show a list of supported commands.
elkrepair
Post by elkrepair » Sun Jan 26, 2020 11:49 pm
Yup, that did it, and that's exactly what appeared. Many thanks.
I can't find a manual for it though. Does anyone know of a link please?
Elk rev 4 & Plus1
BBC micro:bit
Abit BP6
dv8
Post by dv8 » Mon Jan 27, 2020 12:10 am
I couldn't find one either so I've scanned my copy of it and am currently putting together a remastered PDF.
Post by jgharston » Mon Jan 27, 2020 1:01 am
Also, the graphics extension ROMs default to disabled or enabled depending on if the ROM slot they are in is odd or even. Try swapping the GXR ROM with the one adjacent to it.
dv8
Post by dv8 » Mon Jan 27, 2020 10:00 am
That's true for the Acorn GXR. For the CC Graphics ROM, versions 1.xx are enabled by default, versions 2.xx are disabled.
The telltale sign that elkrepair has the CC ROM is the fact there was no output from *HELP.
The Acorn GXR still responds to *HELP when disabled.
elkrepair
Post by elkrepair » Mon Jan 27, 2020 7:14 pm
Yup, defo the CC Graphics ROM.
I did as DV8 explained and everything behaved as described.
Until I see a manual, the only way to use the commands within a program is to use OSCLI, which isn't great. I'm hoping the manual explains PLOT commands similar to the Acorn GXR.
Elk rev 4 & Plus1
BBC micro:bit
Abit BP6
Post by flaxcottage » Mon Feb 03, 2020 8:05 pm
There is a low quality scan here but the commands are visible - http://www.flaxcottage.com/gxr/AcornSoftGFX.zip
I found this somewhere on the internet and just hoarded it. I am a bit of a magpie that way. :lol:
dv8
Re: Acorn Graphics Extension ROM (GXR) User Guide [Remastered PDF]
Post by dv8 » Fri May 29, 2020 3:35 pm
I've uploaded a new zip file (containing ROMs and disc images) to the top post.
(The PDFs have not been updated).
Changes:
  • added both Model B and B+ versions of the GXR.
  • disc images now also include these ROM files.
  • sprite programs split off onto their own disc image.
  • sprite disc image includes Master Sprite ROM.
  • discs now have a menu and are bootable with Shift+Break.
mlouka
Post by mlouka » Fri May 29, 2020 7:40 pm
Nice. Thanks for your effort.
BBC Master 128, BBC Model B i7, PMS B2P-6502 2nd proc., PiTubeDirect (both internal and external), RetroClinic Multi-OS Selector, Sundby 256k RAM/ROM card, MMFS, Gotek, Music 500, ...
jregel
Post by jregel » Sat May 30, 2020 11:41 am
Really good job. Thanks for contributing this.
pixelblip
Post by pixelblip » Sun May 31, 2020 8:29 pm
Thank you dv8. The Graphics Extension Rom rocks.
Return to “scanning of books, magazines, ads and letters”
