Beeb 1MHz Bus FPGA Adaptor
Post by hoglet » Wed Mar 06, 2019 3:19 pm
Current PCB Order Status:
I've decided to ask £10 for a bare PCB, including UK postage.
This might seem quite a lot for a bare board, but I need to try to recoup some of my development costs, which have grown somewhat alarmingly over the last couple of months. I'm also factoring in some time for helping people getting their boards up and running, and answering general FPGA design questions. I hope people feel I'm not being completely unreasonable.
Current Orders:
Batch 1:
#01 - Hoglet (Paid)
#02 - BigEd (Paid)
#03 - Revaldinho (Paid)
#04 - FordP (Paid, Posted)
#05 - marcusjambler (Paid, Posted)
#06 - SirMorris (Paid, Posted)
#07 - dominicbeesley (Paid, Posted)
#08 - Stewie66 (Paid, Posted)
#09 - KenLowe (Paid, Posted)
#10 - Roland (Paid, Posted)
Batch 2:
#11 - Elminster (Paid, Posted)
#12 - paulv (Paid, Posted)
#13 - jasonl (Paid, Posted)
#14 - Budgie  (Paid, Posted)
#15-#17 dominicbeesley (Paid, Posted)
#18 - anightin (Paid, Posted)
Introduction
I've started working on a Beeb 1MHz Bus to FPGA Adapter board.
The goals for this project are as follows:
  • create a general purpose platform for a variety of Beeb 1MHz Bus FPGA projects
  • get more people playing with FPGAs
  • use through-hole technology where possible, so anyone with basic soldering skills can build one
  • use a standard/cheap FPGA module for the Xilinx XC6SLX9 chip (to avoid fine pitch soldering)
  • try to keep the costs as low as possible
Here's the current PCB layout for the adapter:
And the bottom side is mostly just a solid ground plane:
Here's a summary of what's actually on there:
  • a standard 1MHz bus connector with terminators (which could be socketed)
  • links to enable IRQ and NMI (driven by transistors)
  • three 74LVC245A level shifters
  • female headers for the eepizza LX9 Core board (which also supplies 3.3V to the board)
  • a fast 512Kx8 SRAM (36-pin SOJ, such as the IDT 71V424S12). This is the only SMT component, and it's 1.27mm pitch so easy to solder.
  • an MCP4822 SPI DAC (12-bit stereo) feeding two phono outputs
  • two general purpose PMOD connectors
  • two push switches
  • one power LED
  • one user LED
The FPGA board is this one:
It can be bought on ebay for £23 and saves having to do any fine pitch soldering:
https://www.ebay.com/itm/Xilinx-XC6SLX9 ... 1640406811
(ignore the fact the board on ebay looks slightly different)
The PMOD connectors allow all sorts of interesting hardware to be added. See Digilent's pmod catalog. I already have one of these:
so one idea was to design a high res VGA display adaptor.
It's also possible to boot software from the 1MHz bus, which might be fun to play with.
Current status is that I've just sent the board design off to JLCPCB so I should have prototypes back in ~2 weeks.
I've got the combined Music 5000/3000 design already to go as an initial test:
https://github.com/hoglet67/Music5000/b ... x9core.vhd
I'll update this thread as things progress.
Re: Beeb 1MHz Bus FPGA Adaptor
Post by hoglet » Wed Mar 06, 2019 3:29 pm
Oops, I keep forgetting there are two hardware forums.
Could some kind moderator move this thread and the Music 5000 FPGA thread into the 8-bit hardware forum?
Ta very much,
myelin
Post by myelin » Wed Mar 06, 2019 5:57 pm
Very nice! I've been feeling for a long time that the 1MHz Bus is the most interesting interface on the Beeb; between this and dp11's Pi adapter, it looks like we're about to see some very clever stuff there :)
Post by hoglet » Wed Mar 06, 2019 6:52 pm
Thanks! I've just done another little experiment...
...and here's the result - an Owl pulled out of the 1MHz Bus on power up:
(All credit to dv8 for his wonderful Owl Logo)
It uses the &FDFE 1MHz Bus reset hook, which is called automatically if a device asserts IRQ on reset:
DA77	CLI         ;briefly allow interrupts to clear anything pending
DA78	SEI         ;disallow again N.B. All VIA IRQs are disabled
DA79	BIT &FC     ;if bit 6=1 then JSR &F055 (normally 0)
DA7B	BVC &DA80   ;else DA80
DA7D	JSR &F055   ;F055 JMP (&FDFE) probably causes a BRK unless
   		    ;hardware there redirects it.
Here's the fragment of code than needs to be placed on Jim to do this:
https://github.com/hoglet67/Music5000/b ... e_test.asm
No Paged ROMs involved!
mr-macrisc
Post by mr-macrisc » Wed Mar 06, 2019 7:04 pm
Cool =D>
dp11
Post by dp11 » Wed Mar 06, 2019 7:15 pm
Dam you have beeten me. I've been planning this for ages
Post by hoglet » Wed Mar 06, 2019 7:54 pm
Dam you have beaten me. I've been planning this for ages
You mean the Owl? You should have said something when we chatted last week. :(
How about an animated startup logo from the Pi then? Maybe a mode 7 owl flapping it's wings, now that would be cool!
Will the Pi be fast enough on first boot? The Model B boots very quickly I think. I'll try to measure it tomorrow.
Post by roland » Wed Mar 06, 2019 8:58 pm
Nice board, good idea. But why did you use a SMD memory chip? There are still plenty of 32 pin DIP memories available (although Farnell only sells them until the end of stock).
And as my Atom has a 1 MHz compatible bus, this could also be connected to my Atom \:D/
Post by hoglet » Wed Mar 06, 2019 9:08 pm
I wanted a very fast SRAM. i.e. around 10ns access time. This can make up for the width being only 8-bits.
The AS6C4008 (the 32 pin DIP alternative) is 55ns.
Post by BigEd » Wed Mar 06, 2019 9:52 pm
The 1MHz Owl Dongle might be the killer app.
Post by hoglet » Wed Mar 06, 2019 10:18 pm
A ROM is probably cheaper (and simpler). :D
Post by hoglet » Wed Mar 06, 2019 10:42 pm
To expand on this a bit.
I'd like to implement a VGA (640x480) frame buffer (with 8 bits/pixel) and a palette. The size of the frame buffer is 300KB, which is too large to fit in internal block RAM (which is 64KB for the FPGA I'm using).
VGA runs at a 25MHz pixel clock, so ideally the RAM would run at 50MHz, leaving plenty of bandwidth for updates. To run at 50MHz you really need a 10ns access time SRAM, as it takes time for the signals to get on and off the FPGA. Even then, it's pushing it a bit.
Now, the Beeb might not be able to make use of this bandwidth directly (at it can only access at 1MHz), but an on-chip blitter could. There's enough spare RAM (212KB) to store fonts, sprites, etc. There's an open source implementation of the Atari blitter that could be used for inspiration. As, of course, could Dominic's work: A blitter for the beeb?
I was also very impressed by Radical Brad's Vulcan project. Something like this (but in the FPGA) would be very possible.
fordp
Post by fordp » Thu Mar 07, 2019 8:43 am
Do you have a github repository yet Dave?
I would like to work on the a Wiki for 1MHz bus devices and this would seem like a good place for it. I do not need access to "code" I would do all that on a fork with push requests.
I will take a board/kit if one becomes available too, ta!
FordP (Simon Ellwood)
marcusjambler
Post by marcusjambler » Thu Mar 07, 2019 9:00 am
This sounds like a very interesting project =D>
Please put me down for a board/kit
Marcus
Post by hoglet » Thu Mar 07, 2019 9:27 am
I do now:
https://github.com/hoglet67/Beeb1MHzBusFpga
See if you can edit the wiki?
My plan is to just make the bare PCBs available.
Post by hoglet » Thu Mar 07, 2019 9:28 am
It would just be the bare boards.
fordp
Post by fordp » Thu Mar 07, 2019 10:04 am
I do not seem to be able to edit/open the WIki. I thought you could open just the Wiki to the whole of Github but I could be wrong on that!
https://help.github.com/en/articles/cha ... -for-wikis
Post by danielj » Thu Mar 07, 2019 10:11 am
These look fab!! - possibly worth socketing the resistor packs to allow other things to terminate the chain?
marcusjambler
Post by marcusjambler » Thu Mar 07, 2019 10:23 am
I will learn SMD soldering for this project :D
Marcus
sirmorris
Post by sirmorris » Thu Mar 07, 2019 10:47 am
I'd like a board please Dave. I'll be happy to solder the smd bits for anyone unwilling.
Post by danielj » Thu Mar 07, 2019 10:48 am
Are you still using Old Crafty Hen in lieu of flux? :)
dominicbeesley
Post by dominicbeesley » Thu Mar 07, 2019 10:53 am
Cool, if you're making more of these please put me down for one!
[I thought you'd already done a framebuffer and genlock to get the owl then I spotted it was Mode 7!]
D
Post by hoglet » Thu Mar 07, 2019 11:46 am
I do not seems to be able to edit/open the WIki.
Try again now Ford.
Post by hoglet » Thu Mar 07, 2019 12:16 pm
Some quick measurements on a Model B:
  • From the 5V rail coming up to the 6502 starting to run is 112ms.
  • From the 5V rail coming to to the 1MHz Bus being accessed in the reset sequence is 369ms.
Those are both, I think, much faster than I've ever seen a Pi boot.
The LX9 FPGA has a bitstream size of 2,742,528 bits. You have some control of the configuration clock speed, but at 22MHz it should configure in about 125ms, which should be be fast enough.
fordp
Post by fordp » Thu Mar 07, 2019 6:04 pm
Try again now Ford.
Thanks Dave,
It works!
Stewie66
Post by Stewie66 » Fri Mar 08, 2019 3:48 am
I’d be interested in a board
Post by hoglet » Fri Mar 08, 2019 7:36 am
I will make blank PCBs available, but I have yet to even build up the prototype PCB. These have just shipped from JLCPCB, so should arrive in ~2 weeks. So expect some more progress towards the end of March.
fordp
Post by fordp » Fri Mar 08, 2019 9:25 am
The FPGA board on ebay looks like the JTAG connector will clash with your PCB Dave. Maybe it will have to be taken out and soldered on the other side of the PCB?
Alnitak
Post by Alnitak » Fri Mar 08, 2019 9:38 am
The guys coming up with a lousy design for a display module for the "8 bit guy's" project to build a modern 65xx computer (aka "Commander 16") could learn a thing or two from this...
Post by hoglet » Fri Mar 08, 2019 9:51 am
Are you going from the picture on eBay? That's not actually accurate. The board that is now shipped is slightly different.
Look at the picture I posted in the first post. It uses a header for the JTAG connector, which can easily be bent over so you can attach a cable while the board is plugged in. If you don't want to do this, you can always program the FPGA with the adapter board unplugged. In all cases, power is sup[plied directly to the FPGA board.
