FreeFi-232 v2
Re: FreeFi-232 v2
Weird. NodeMCU is a strange thing to be on there - I wonder if your supplier was removing them from NodeMCU boards? Or they were destined for them?
Re: FreeFi-232 v2
No idea. Some random supplied from China on ebay.
You would get gibberish if you went to a serial console unless you set it to 9600 then you would get the message
And not a human error as Arduino IDE was still setup from programming the last ESP board, so it opened with correct code and settings (although I double checked all that after it failed). And I soldered a header onto RTS yesterday and that was connected, and I never touched the code or the cable between it not working and working. All I tried messing with was changing the reset method, after a few times of not working, but I am not sure that made any difference. All a bit weird but recorded here incase any one else hits issues, I have no intention of making any more
NodeMCU 0.9.6 build 20150406 powered by Lua 5.1.4
Re: FreeFi-232 v2
USB connectors swapped. I now never have to touch it again
Re: FreeFi-232 v2
They look absolutely fab!
Re: FreeFi-232 v2
Wish I had realised this a while ago. There is a bug in arduino ide 1.8.5 which means that every time you upload the sketch it invalidates the cache and compiles from scratch. The result being that it took ages to flash the esp board. Now on 1.8.7 is is really fast.
Trap for young players.
Edit: And another trap, if you test using the DB25 and leave the programmer plugged you can get gibberish coming out when you typed. Thought I has screw the code.
Re: FreeFi-232 v2
I did a fork and had a play, new bits in bold.
FreeFi232 Firmware v0.2 (WiFiManager Edition)
Based on ESP8266 Virtual Modem (C) 2016 Jussi Salin
Additions (C) 2018 Daniel Jameson and Stardot Contributors
Connect to WIFI: ATWIFI<ssid>,<key>
Scan for Available Networks: ATSCAN
Change terminal baud rate: AT<baud>
Connect by TCP: ATDT<host>:<port>
See my IP address: ATIP
See my Network: ATNET
Disable telnet command handling: ATNET0
HTTP GET: ATGET<URL>
MAC:84:F3:EB:73:DA:C8
Hardware Flow control: ON
Listening to connections at port 23, which result in RING and you can answer with ATA.
OK
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 0
Entered config mode
192.168.4.1
APFreeFi232
*WM:
*WM: Configuring access point...
*WM: APFreeFi232
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started
*WM: Request redirected to captive portal
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Scan done
*WM: Sent config page
*WM: Handle root
*WM: WiFi save
*WM: Sent wifi save page
*WM: Connecting to new AP
*WM: 3
connected to network ...
*WM: freeing allocated params!
OK
*WM:
*WM: AutoConnect
*WM: 0
Entered config mode
192.168.4.1
APFreeFi232
*WM:
*WM: APFreeFi232
*WM: AP IP address:
*WM: 192.168.4.1
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Scan done
*WM: Handle root
*WM: WiFi save
*WM: 3
Re: FreeFi-232 v2
Screen shot on smart phone
Re: FreeFi-232 v2
Tried my hacked up firmware and still seems to work in original lolin board, not actually tested on a beeb. So I guess I should probably post anything interesting I come up with in the original viewtopic.php?f=3&t=15076 thread. So this one stays specifically about freefi232 hardware.
Re: FreeFi-232 v2
In the viewdata service thread I reported that my freefi232 modem did not seem to like the Telstar servers anymore and connecting to them just resulted in the page going mad and continually refreshing at high speed.
I seem to have found out how to correct this. After entering terminal chat and resetting the freefi232 I can issue the following commands:
ATNET0
AT2400
AT
If I then ATDTGLASSTTY.COM:6503 it connects ok without going haywire. Setting Commstar to Prestel mode and then going back to chat enables me to use Telstar like normal, as before at the correct speed.
So does anyone know why I now have to issue the commands above to get this service to work, whereas before I didn’t have to? Should my freefi232 remember those settings between power off/on? Has something changed on Telstar which now demands that those settings are set before connecting?
ATNET0
AT2400
AT
Re: FreeFi-232 v2
Honestly no idea about the telnet thing - must be something that changed on the telstar end. Issuing AT2400 will flush the buffers and restart the serial communication. 2400 is the default BPS iirc (but it does depend what yours got flashed with, I didn't build it, so I don't know I'm afraid) Typing AT will do nothing other than print "OK".
Will it not work if you omit the ATNET0 step and just do everything else?
Re: FreeFi-232 v2
If I don’t issue the ATNET0 command before I connect to Telstar it just seems to go bonkers.
If I do issue ATNET0 but not AT2400 then it doesn’t go bonkers but it does load pages at an absolute crawl.
So it seems to require both ATNET0 and AT2400 to get Telstar running ok an back at ‘normal’ speed.
Re: FreeFi-232 v2
Does anybody have any of the latest version bare boards for sale by any chance ?
Andy
Andy
Re: FreeFi-232 v2
Thanks. PM Sent.
Re: FreeFi-232 v2
Okay,
I can do 4 more partial kits containing:
1x PCB
1x ESP-12E
2x Tant caps
1x voltage reg
1x USB connector
6x 100nF ceramic caps
5x 10k resistors
1x 470R resistor
1x 1N5819 diode
£10.50 posted. I'll also need to get something set up to test the ESP-12Es before I send them out!
You'll need to add:
Pin headers
Panasonic EVPAA SMD switch
25way female DSUB
MAX3237
1x PCB
1x ESP-12E
2x Tant caps
1x voltage reg
1x USB connector
5x 10k resistors
1x 470R resistor
1x 1N5819 diode
You'll need to add:
Pin headers
25way female DSUB
MAX3237
Re: FreeFi-232 v2
Hi
can someone suggest a suitable cable ? I have a freefi-232 and a master to get working together - I need a cable from the RS432 on the master to the 25pin female on the freefi
its about time i had it working on the bbc!
cheers!
cheers!
Re: FreeFi-232 v2
I use a 25pin to 9pin converter, then a DIY'd rs423 din to 9 pin jobby...
Re: FreeFi-232 v2
I can solder but dont enjoy it. would rather find a ready made cable if i could!
thanks daniel -I'll start by looing up the din plug. ive definitely got a converter
Re: FreeFi-232 v2
I think I asked this already but can’t find where I asked. Was a 3D printable case ever designed for this board? Now I have the Huxley modded up I am actually printing useful stuff. Or is this a design in 3D package of your choice task?
Re: FreeFi-232 v2
I will assume not.
Anyway I am no expert, it isn't pretty (only second thing I have designed from scatch) but it does the job (stops me shorting it against stuff). Will upload to thingiverse if anyone interested.
Re: FreeFi-232 v2
Nice!
Re: FreeFi-232 v2
Thanks. Huxley friendly as well.
I think I will be spending the next 10 years designing cases for all the naked boards I seem to have collected.
Re: FreeFi-232 v2
Have you stuck it on thingiverse?
Re: FreeFi-232 v2
The pressure.. Just the Top of the case as I just noticed where I dropped hole 1mm on the front I forgot to do the same on the rear, so the board sits at weird angle and might put pressure on the solder joint of the D connector. Will sort that out and upload.
But the half an entry is here https://www.thingiverse.com/thing:4540983
Edit: Modified bottom part of case & uploaded. Not printed it but should be okay, a few million intersections but all manifold.
