Moon Patrol for the beeb (New port, just starting)
Post by tricky » Fri Jan 04, 2019 9:14 pm
I've been thinking about doing moon patrol, I wasn't a big fan and the beeb version really put me off, but I'm coming around to the idea.
The ground is a bit boring at the mo' and this isn't a beebem version :(
I also need to improve my music converter.
MoonPatrol.zip
(6.4 KiB) Downloaded 54 times
Re: Moon Patrol for the beeb (New port, just starting)
Post by RobC » Fri Jan 04, 2019 10:36 pm
Looking good =D> =D> :D
AndyF
Post by AndyF » Sun Jan 06, 2019 10:52 am
I concur that is a very promising start. =D>
Andy
Post by tricky » Sun Jan 06, 2019 2:55 pm
Thanks.
I had to tweak my VGM converter as the VGM for the music that I had found seemed to have been converted from ~60Hz to ~50Hz and back to ~60Hz and my converter was finding a 61.75Hz pattern! Anyway, reduced from 1K to 400 bytes and now plays at a speed much closer to the original (now a bit too fast). The "drums" repeat the same pattern, so I could reduce that to 200 bytes!
I have a few minor compromises in mind, but the result should feel very close.
I'm trying to think of a good encoding for the map between exactly the same ground/aliens vs random whilst still making it possible and predictable.
Memory is looking OK, but there won't be much to spare and I doubt that I will have room for the buildings or any extras, but I am open to suggestions.
MoonPatrol.zip
Not suitable for beebem!
(6.08 KiB) Downloaded 34 times
Site Admin
Post by Arcadian » Fri Jan 11, 2019 10:50 pm
Tried both demos. Impressed! Eagerly looking forward to the next (and the next and the next and the next! :) ).
Post by tricky » Fri Jan 11, 2019 11:37 pm
Stalled a bit, just can't seem to stay awake!
I'll try to get a new demo by the end of the weekend.
Post by tricky » Sat Jan 12, 2019 9:19 pm
Managed to get a couple of hours to add a longer tune and the buggy - can't be controlled but does have suspension :D
4.5K free :cry:
PS If you have an old beebem, the sound will be awful due to a beebem bug - I will try to remember to work-a-round it for the next demo!
MoonPatrol.zip
(9.63 KiB) Downloaded 32 times
Post by tricky » Sun Jan 13, 2019 4:13 pm
URL:https://youtu.be/ISyFwWREmjM View at 720p+ for 50hz.
BeebEm version attached - sound is correct in some versions but way off in others!
MoonPatroBeebEm.zip
(8.44 KiB) Downloaded 33 times
Post by FourthStone » Sun Jan 13, 2019 7:51 pm
Looking good Tricky =D>
One of my favorite arcade games that I'd play at the local milk bar.
I'd collect soft drink bottles to collect the deposit, buy some lollies and then have a few plays on moon patrol, good times.
Post by tricky » Thu Jan 17, 2019 12:24 am
I've been having trouble sleeping and waking up!
Added moving SHIFT/RETURN and shooting up Z.
Debug output says 7K left.
MoonPatrol.zip
(8.78 KiB) Downloaded 38 times
Post by jms2 » Thu Jan 17, 2019 7:01 am
That suspension is mesmerising....
Post by tricky » Sat Jan 26, 2019 8:55 pm
I've eventually managed to get back to MoonPatrol and got slightly sidetracked with why beebem's timing is off and it took about one second to "fix" it in the version I have!
void VideoDoScanLine(void) {
VideoState.VSyncState=(CRTC_SyncWidth>>4)+1;
I removed the +1 in the line above as the vsync ends one scan line too late.
I don't think this is the correct solution, and that it is more a case of two wrongs making a right as the colour changes are still one scan line off compared to b-em and real hardware.
Post by tricky » Mon Jan 28, 2019 6:25 pm
Added shots up and forward and alien bombs (but no aliens), so there is a bit of a game there.
I still need to tidy things up and order them correctly, but is should start to feel like MoonPatrol.
I might have to make it easier to dodge the bombs.
Z/X slower/faster
RETURN shoot up
SHIFT shoot forward (can't hit anything with this gun).
MoonPatrol.zip
(9.72 KiB) Downloaded 45 times
Post by tricky » Sat Feb 02, 2019 12:07 pm
Not getting very far very fast, so thought I would do something quick to get me going, so here is the VideoNuLA comparison screenshot.
Left: native beeb, Centre: Arcade, Right: beeb+NuLA
The beeb version currently has a slightly wider and taller play area but I have skimped a bit on the scenery and UI.
I moved the UI to the bottom so that the warning !!! are close to where you are looking for holes and not because it was easier to code :---)
I will probably tweak the UI area a bit more, but it should be OK for now.
Dethmunk
Post by Dethmunk » Sat Feb 16, 2019 6:37 pm
:shock: Looks awesome Tricky. :)
I personally prefer the native BBC version for colour options. LOL :D Great stuff though loving it.
Post by tricky » Sat Feb 16, 2019 10:02 pm
Sorry it has stalled, I've been trying to get over a cold for a fortnight and am still having trouble breathing.
Dethmunk
Post by Dethmunk » Sat Feb 23, 2019 4:00 pm
Get well soon Tricky. Moon Patrol is looking awesome. :D
Post by tricky » Sat May 25, 2019 11:31 am
Minor progress update:
URL:https://youtu.be/nZaieTuQ4bg View at 720p+ for 50hz.
Post by lurkio » Sat May 25, 2019 12:19 pm
Absolutely ridiculous!
=D> =D> =D>
Muddyfunster
Post by Muddyfunster » Sat May 25, 2019 8:16 pm
This is looking great!
simonm
Post by simonm » Sun May 26, 2019 3:40 am
Love it. So smooth and the colours are great! Plus I'm a big fan of how you use the arcade fonts too. =D>
JudgeBeeb
Post by JudgeBeeb » Sun May 26, 2019 11:19 am
Marvellous =D> =D> =D>
mlouka
Post by mlouka » Sun May 26, 2019 4:52 pm
Excellent stuff -- great to see the progress you are making! =D>
BBC Master 128, BBC Model B i7, Watford Electronics Solderless Sideways ROM board, PMS B2P-6502 2nd proc., PiTubeDirect (both internal and external), RetroClinic Multi-OS Selector, Sundby 256k RAM/ROM card, MMFS, Gotek, Music 500, ...
Post by tricky » Sun May 26, 2019 5:20 pm
Thanks for all the kind words.
I got a bit bogged down writing different sprite routines for every object, most of them have multiple routines!
Now I have plenty of frame time, but not much memory and will have to combine a few of them to get the memory back!
I'm currently prepping for Revival and discovering that most of my "spare" beebs have developed faults, but I think I have enough now and will be able to get back to this after Revival.
0xC0DE
Post by 0xC0DE » Sun May 26, 2019 6:08 pm
Great work! Very smooth scrolling indeed.
0xC0DE
:arrow: Follow me on Twitter
:arrow: Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
Post by Rich Talbot-Watkins » Sun May 26, 2019 6:13 pm
I know I say it every time, but I think this is probably your best conversion yet! Absolutely amazing bit of work!
rmbrowngr
Post by rmbrowngr » Sun May 26, 2019 8:24 pm
Very impressive. Very well done. =D>
Richard B
Muddyfunster
Post by Muddyfunster » Mon May 27, 2019 3:09 pm
Thanks for the reminder on Revival!
Post by tricky » Sun Feb 23, 2020 8:04 pm
Sorry, another minor progress update:
URL:https://youtu.be/Iq_jZaJs_8w View at 720p+ for 50hz.
Post by lurkio » Sun Feb 23, 2020 9:42 pm
Sorry, another minor progress update: URL:https://youtu.be/Iq_jZaJs_8w View at 720p+ for 50hz.
:shock: :D =D> =D> =D>
This simply cannot be a Beeb! It just can't. It's bananas! :wink:
Fantastic!
