fading characters
eXne
fading characters
Post by eXne » Sun Jan 13, 2019 8:36 pm
Folks,recently I purchased a BBC from the UK and started the normal process by first checking the PSU caps which needed to be replaced.
When I turned the Beeb on I was puzzled as I saw fading characters.
fading characters
After browsing the forum and google I found nothing similar, or I entered the wrong keywords :wink:
Memory seems to be ok, video ULA seems to be fine as well,
The 'puzzling graphics glitch on my Beeb' here was the base for the soluction.. and yes after some thinking: has this maybe something to do with the PSU not being earthed? As this is a UK machine I used an adapter with no earthing...
Installed an Earth connection and voila..
normal characters
Normally everybody starts with questions, this time I wanted to share
Etienne
Acorn BBC + 6502 and Z80 2nd proc and CoPro, Master 128, 512 + 80186. Atom Prophet
Re: fading characters
Post by tricky » Sun Jan 13, 2019 11:47 pm
Does that mean that your video connection is missing a GND?
eXne
Post by eXne » Mon Jan 14, 2019 7:37 pm
I need to dig into that part.
I have my beeb hooked through the RGB port to a TV Scart input.
