Hello. New forum user. BBC master
thefool1983
Post by thefool1983 » Fri Jan 11, 2019 7:16 pm
Found this old (circa ~1986) BBC Master in my mother's roof space.
A bit of history: my father (sadly no longer with us) was an IT teacher at a local secondary school and he rescued this machine and quite a few periphals when the school were disposing of out dated hardware.
I have been meaning for sometime now to try and get it up and running for the first time since about 1997.
My dad had shown me certain things about these old machines back in the day and I knew the CMOS battery back up can fail on these. So I set about replacing. There was a little corrosion but not too much.
I followed the guide here:http://lionels.orpheusweb.co.uk/CompNyb ... onfig.html
Then plugged in and managed to get one disc loaded using my limited memory of BBC keyboard functions (ctrl + A + BREAK)
Oh, I also had to fiddle with the disc drive. Disconnected the internal power connector and reseated. Before the unit would power up.
My future plans are to get some more of the other kit from the roofspace and get it workin also. Ultimately I would like my kids to experience some of the fun I had on this tech when I was a lad.
Hope this interests a few & brings a bit of nostalgia as it does for me.
Kev
Multiwizard
Re: Hello. New forum user. BBC master
Post by Multiwizard » Fri Jan 11, 2019 7:27 pm
Hi Kev,
Greetings from my little Dutch Atom Attic, Wim... :-)
Lardo Boffin
Post by Lardo Boffin » Fri Jan 11, 2019 7:52 pm
Nice job. Another beeb brought back to life!
Adventure Language on GitHub
Atom, issue 5
Elk
Post by CMcDougall » Fri Jan 11, 2019 8:25 pm
welcome Kev :)
looks like you also have a econet board on it too (top right) so that's a bonus!
Post by flaxcottage » Fri Jan 11, 2019 8:30 pm
Welcome, Kev. :D
Nice tool bench by the way. One thing, is the monkey wrench essential for computer maintenance? :lol:
thefool1983
Post by thefool1983 » Fri Jan 11, 2019 8:41 pm
Thanks guys
[welcome Kev :)
I noticed that. But have no idea the capability or function of an econet!
Welcome, Kev. :D
Well spotted. The garage is the designated area for my "various useless projects" as the wife would see them!
Post by daveejhitchins » Fri Jan 11, 2019 9:04 pm
Welcome to the Forum, Kev . . . Enjoy . . .
Looking forward to see what else you have in the loft :wink:
SimonSideburns
Post by SimonSideburns » Fri Jan 11, 2019 10:33 pm
Have you replaced the capacitors in the power supply? If not, you will at some point (unless it has already done so) fill the garage with magic smoke.
Various people on ebay and here sell kits of the three capacitors along with instructions.
Post by tricky » Fri Jan 11, 2019 11:33 pm
Welcome,
While you are getting things working, you can take a trip down memory lane at bbcmicro.co.uk and maybe have a look at the new hardware available for your "beeb". You might like to start with a look at GOTEKs as you have a working disc controller.
Post by davidb » Sat Jan 12, 2019 12:52 pm
Welcome! :D
Post by DutchAcorn » Sat Jan 12, 2019 1:59 pm
Welcome! And good luck with your Master and the rest of the treasures!
If your floppies are mostly ADFS formatted it may be convenient to configure the filing system to default to ADFS instead of DFS. Use
*configure file 13
To do that.
flowsnake
Post by flowsnake » Sun Jan 13, 2019 7:00 am
Great to see the old machine back in action!
To echo the comments above definitely consider replacing capacitors asap. They have a limited lifespan and tend to fail in unexpected and exciting ways.
thefool1983
Post by thefool1983 » Sun Jan 13, 2019 9:15 am
Thanks to all for the advice.
I will look into the capacitor replacement asap
I think I need to give the disc drive a bit of a clean also. Seem to be getting random errors on discs that were previously working
Post by tricky » Sun Jan 13, 2019 9:18 am
The caps shouldn't kill it, but they will "stink it up"!
If one of your discs had mould on it, it is probably on the head causing problems and spreading to the other discs!
There are plenty of threads on here about both and loads on mouldy floppies on the general web.
thefool1983
Post by thefool1983 » Sun Jan 13, 2019 9:25 am
Yeah have been reading about the dreaded mould. The 3 discs I have used so far look ok. But will try and clean the head some how. The drive sort of sounds "sluggish" compared to the 2nd drive. Was thinking of possibly swapping the two around and making the secondary primary if possible. This probably involves changing dip switches or something.
Have read that there are different versions of PSUs so will pull it out and have a look. It's worth noting I checked the output voltage of the PSU using a digital multimeter and it was bang on 4.97V.
Post by tricky » Sun Jan 13, 2019 10:31 am
I would consider swapping one of the drives for a gotek with the opensource FlashFloppy firmware (they usually come in 3.5" cases).
You would still have a real floppy, but it would be much easier to backup your old discs and add new ones.
thefool1983
Post by thefool1983 » Sun Jan 13, 2019 12:09 pm
Ok. Thanks I will look into that!
JudgeBeeb
Post by JudgeBeeb » Sun Jan 13, 2019 12:27 pm
Of course it is:
JudgeBeeb
Post by JudgeBeeb » Sun Jan 13, 2019 12:29 pm
Greetings.
I don't know what part of the world you hail from, but if you are local and free next weekend, you could always come along to the next ABUG event. Details here.
thefool1983
Post by thefool1983 » Sun Jan 13, 2019 7:34 pm
Greetings.
Thanks. I am in Belfast so a bit far from the event.
Thanks for the invite though
