Looking for a 6502 disassembler for reverse engineering
Helping someone to reverse engineer a 6502 SBC. It has a 6052 processor, a 2K EPROM from F800-FFF, and a 2K Ram and 6522 "somewhere in the memory map". The memory decoding prom (82S129) is still to be read.
Any suggestion of a disassembler/emulator ?. I have the monitor in .HEX and .BIN format. For the rest no docuentation whatsoever.
Googling on MPS65 doesnt bring me anythig
Thanks in advance, Bram
Re: Looking for a 6502 disassembler for reverse engineering
What are you trying to find out about it?
If you post the monitor then I could create a simple driver in MAME for it.
Same board is also discussed at http://forum.6502.org/viewtopic.php?f=3&t=3023
Looks like a machine somewhat like this is the subject of this thread, which includes a ROM dump:
As for a disassembler, there are many listed here, but this one might be a good start:
Thanks for the responses so far, looks indeed like the same board.
Try to reverse engineer it.What are you trying to find out about it?
I'll be interested to see the results! I see the auction listing over on 6502.org promises some notes on how to use the monitor - I suppose you don't any documentation at all?
It's a nice board, two sided, through hole, and a big multi-way connector for expansion.
I have the ROM from the other forum running, the 6522 is at A000-A00F, and it's also expecting something at E003.
No keyboard or LED output yet so nothing to show.
Some more info (its a Facebook discussion at 6502 Homebrew Hardware and Programming group where Bram and I participate about this SBC, photos and video shown while operating, now broken)
The memory decode PROM has been read out by the owner Ian Day
00000000 -> 0 -> 1011
00000001 -> 1 -> 1011
00000010 -> 2 -> 1011
00000011 -> 3 -> 1011
00000100 -> 4 -> 1011
00000101 -> 5 -> 1011
00000110 -> 6 -> 1011
00000111 -> 7 -> 1011
10100000 -> 160 -> 1101
11110000 -> 240 -> 0111
11110001 -> 241 -> 0111
11110010 -> 242 -> 0111
11110011 -> 243 -> 0111
11110100 -> 244 -> 0111
11110101 -> 245 -> 0111
11110110 -> 246 -> 0111
11110111 -> 247 -> 0111
11111000 -> 248 -> 0111
11111001 -> 249 -> 0111
11111010 -> 250 -> 0111
11111011 -> 251 -> 0111
11111100 -> 252 -> 0111
11111101 -> 253 -> 0111
11111110 -> 254 -> 0111
11111111 -> 255 -> 0111
So three Chip select lines, unknown which one is RAM or ROM. The one liner will be the 6522.
I looked at the disassembled ROM dump from 6502.org, I see the 6522 at address A000. I did not see other I/O yet.
What I see from the disassembly and the photos is:
65C02 at 2 MHz
RAM 6116 2K at 0000
6522 at A000
ROM 2K at F800 (pure 6502 code afaik in the ROM)
24 key keyboard/ 6 led matrix with 7400 and 7442 decoder and transistor for every led display
RS307-109 Darligton Driver Array
82S129 as show above
Transistor for reset?
65C02 at 2 MHz
RAM 6116 2K at 0000
6522 at A000
<plug> http://mdfs.net/Software/Assembler/DisAssem/ </plug>
Jonathan, the MkSrc.txt file on that page is a dead link - which is a pity because I'd be interested to try out mksrc65. I've never found any program which allows you to interactively disassemble 6502 code such that you end up with usable source code, but it looks like this might do it.
Fixed.jms2 wrote: ↑Sun Dec 30, 2018 9:00 amJonathan, the MkSrc.txt file on that page is a dead link - which is a pity because I'd be interested to try out mksrc65. I've never found any program which allows you to interactively disassemble 6502 code such that you end up with usable source code, but it looks like this might do it.
I've been having another play with the latest version of Beebdis, but I'm struggling to get it to use the standard LABELS.TXT file (or any other list of labels for that matter). My control file looks like this:
I know I have got the "load", "save" and "symbols" commands in the right order and correctly at the start of the control file, but whilst there are no errors it doesn't seem to recognise the symbol definitions - all the symbols are auto-generated.
What am I missing?
load $8000 filename.rom
save filename_dis.asm
symbols LABELS.TXT
cpu 6502
entry $8003
What am I missing?
Can you show us the contents of your LABELS.TXT please?
Phill.
It's just the standard one from the Beebdis zipfile. So this:
; OS routines BBC A/B/B+/Master/Electron
OSCLI $FFF7
OSBYTE $FFF4
OSWORD $FFF1
OSWRCH $FFEE
OSNEWL $FFE7
OSASCI $FFE3
OSRDCH $FFE0
OSFILE $FFDD
OSARGS $FFDA
OSBGET $FFD7
OSBPUT $FFD4
OSGBPB $FFD1
OSFIND $FFCE
NNWRCH $FFCB
NVRDCH $FFC8
GSREAD $FFC5
GSINIT $FFC2
OSEVEN $FFBF
OSRDSC $FFB9
OSWRSC $FFB3
; Vectors
USERV $0200
BRKV $0202
IRQ1V $0204
IRQ2V $0206
CLIV $0208
BYTEV $020A
WORDV $020C
WRCHV $020E
RDCHV $0210
FILEV $0212
ARGSV $0214
BGETV $0216
BPUTV $0218
GBPBV $021A
FINDV $021C
FSCV $021E
EVENTV $0220
UPTV $0222
NETV $0224
VDUV $0226
KEYV $0228
INSV $022A
REMV $022C
CNPV $022E
INDV1 $0230
INDV2 $0232
INDV3 $0234
Thanks Dave! I can see that it has worked perfectly in your example (and appended its list of symbols onto the list of auto-generated ones), but it doesn't work for me. I've done the following things (all of which have had no effect):
- Use the .sym ending on my labels file, and reference that.
- Call up MCMON.sym instead (having copied it into the folder, obviously)
- Move the "symbols" directive in between "load" and "save", as in your example
- Shorten the filenames to less than 8 characters.
- Putting the "symbols" directive first in the control file (I know this is not what the manual says, but I'm clutching at straws!).
One thing did have an effect - I had the directive "cpu 6502" in my control file, but yours lacked it. So I deleted it out of mine as well. This resulted in no disassembly at all!
This is with BeebDis 1.20. I thought I had better try re-running your MCMON disassembly to see if that worked - but it didn't, instead it produced the hexdump preceded by what looks to be a list of all the assembler mnemonics used in the program.
Seems that was working with a much older version:
Here's another example using symbols that works with version 1.10:
https://github.com/hoglet67/BBCBasic4r3 ... isassembly
I would try with 1.20, but I can't remember how to re-build this on Linux
C:\Users\David Banks\Documents\LEVEL9\BeebDis>BeebDis.exe
BeebDis V0.91 2013-03, PhillHarvey-Smith.
Error: no control file
I think there may be a bug with 1.20 where it is not loading the symbols correctly.
Please standby for a fix.....
Phill.
Phill.
Right I've hopefully fixed the bug with the symbol files not being read.
I've also added a verbosity system so you can set how much output you get whilst processing files.
Just uploaded to github.
Phill.
Phill.
Great, thanks!
I've been wanting to get somewhere with Beebdis for a while, and realising that it generates Beebasm output is an even better reason to experiment with it. This was my first serious attempt and the symbols problem was a bit puzzling!
Just tried v1.25. I really like the slightly more verbose output at the command line - it helps a lot to see what the program is doing.
It reports that it loads the file to disassemble, says it is loading the symbols file, and then saves the result; but guess what... it still doesn't actually seem to import the labels.
I tried with the two labels files that I have (one being Hoglet's, the other being the original file).
I also need to use the "cpu 6502" directive, otherwise I get nothing. Perhaps this is intentional though (it makes sense).
I was banging my head against a wall trying to use this file and it just wouldn't work for me, I'm running BeebDis 1.25 on Linux, but messing around I found that if I put an equals sign between the variable and the value it works...jms2 wrote: ↑Mon Jan 21, 2019 10:30 pmIt's just the standard one from the Beebdis zipfile. So this:
; OS routines BBC A/B/B+/Master/Electron OSCLI $FFF7 OSBYTE $FFF4 OSWORD $FFF1 OSWRCH $FFEE OSNEWL $FFE7 OSASCI $FFE3 OSRDCH $FFE0 OSFILE $FFDD OSARGS $FFDA OSBGET $FFD7 OSBPUT $FFD4 OSGBPB $FFD1 OSFIND $FFCE NNWRCH $FFCB NVRDCH $FFC8 GSREAD $FFC5 GSINIT $FFC2 OSEVEN $FFBF OSRDSC $FFB9 OSWRSC $FFB3 ; Vectors USERV $0200 BRKV $0202 IRQ1V $0204 IRQ2V $0206 CLIV $0208 BYTEV $020A WORDV $020C WRCHV $020E RDCHV $0210 FILEV $0212 ARGSV $0214 BGETV $0216 BPUTV $0218 GBPBV $021A FINDV $021C FSCV $021E EVENTV $0220 UPTV $0222 NETV $0224 VDUV $0226 KEYV $0228 INSV $022A REMV $022C CNPV $022E INDV1 $0230 INDV2 $0232 INDV3 $0234
e.g.
OSBYTE = $FFF4
Just putting this out there in-case it helps anyone else.... and just like jms2 said I also need to include the line "cpu 6502" to get any output.
Perhaps I should have the control file loader bail, or at least warn the user if no cpu is defined.
Or maybe default to 6502 and also issue a warning, in case you where trying to process 6809 code.....
Phill.
Phill.
Personally I'd prefer it to throw up an error message if the cpu type is not defined in the control file rather than it defaults to xxx type cpu.
Perhaps you could include a few example files that are well commentated to get people started with this amazing program. If your too busy I'd be happy to have a stab at it.
