The Dreaded goto
The Dreaded goto
Post by Coeus » Fri Nov 02, 2018 10:54 pm
I don't usually feel the call of the goto statement but what about this function:
int mmb_find(const char *name)
    const char *cat_ptr = mmb_cat + 16;
    const char *cat_end = mmb_cat + MMB_CAT_SIZE;
    const char *cat_nxt, *nam_ptr;
    int cat_ch, nam_ch, i;
    while (cat_ptr < cat_end) {
        cat_nxt = cat_ptr + 16;
        nam_ptr = name;
        do {
            if (cat_ptr == cat_nxt)
                goto found;
            cat_ch = *cat_ptr++;
            nam_ch = *nam_ptr++;
            if (!cat_ch && !nam_ch)
                goto found;
        } while (!((cat_ch ^ nam_ch) & 0x5f));
        cat_ptr = cat_nxt;
    return -1;
found:
    i = (cat_nxt - mmb_cat) / 16 - 2;
    log_debug("mmb: found MMB SSD '%s' at %d", name, i);
    return i;
this could be re-written without the gotos, keeping the same logic:
        nam_ptr = name;
        do {
            if (cat_ptr == cat_nxt|| (!(cat_ch = *cat_ptr++) && !(nam_ch = *nam_ptr++))) {
                return i;
        cat_ptr = cat_nxt;
    return -1;
Clearer? If not, any other alternatives?
Re: The Dreaded goto
Post by flaxcottage » Sat Nov 03, 2018 9:59 am
Best not to jump out of a loop. The second way is technically better.
paulv
Post by paulv » Sat Nov 03, 2018 10:06 am
The if evaluation took me a couple of reads as you have equality and assignation in the statement so on first read, it looks like you've missed a couple of = symbols out accidentally but they're actually correct as they are.
For clarity, it may be worth doing the assignation before the if rather than inline to avoid confusion.
EDIT: but that then means the code changes its behaviour so I see why you've done it inline. Just makes for the need for a more attentive read through the code.
Phlamethrower
Post by Phlamethrower » Sat Nov 03, 2018 1:15 pm
When goto's become ugly/confusing I tend to try and restructure the code into a subroutine, so that the goto's become return's:
static inline int cat_name_cmp(const char *nam_ptr, const char *cat_ptr)
    const char *cat_nxt = cat_ptr + 16;
    do {
        char cat_ch = *cat_ptr++;
        char nam_ch = *nam_ptr++;
            break;
        if ((cat_ch ^ nam_ch) & 0x5f)
            return -1;
    } while (cat_nxt != cat_ptr);
    return (cat_nxt - mmb_cat) / 16 - 2;
    int i;
    do {
        i = cat_name_cmp(name, cat_ptr);
        cat_ptr += 16;
    } while ((i == -1) && (cat_ptr < cat_end));
    if (i != -1)
    return i;
If the compiler's any good it should be able to inline the function, avoiding any inefficiencies that an actual function call would introduce. Of course if you're using a vintage compiler then it's not likely to be that good at optimisation, so if you're concerned about code size/speed then an ugly/confusing function may be the best option.
Diminished
Post by Diminished » Sat Nov 03, 2018 3:42 pm
I've sometimes resorted to "do { } while (0);" to avoid a goto (in which a break statement will jump you to the end of the block).
It's messy if you want to jump out of multiple blocks, though. The goto is probably clearer.
Return to “programming”
