Post by Elminster » Sun Oct 14, 2018 5:56 pm
I just follow instruction for Hoglet’s ice-t whenever I build anything with a Xilinx. So far that has always worked. :)
Post by hoglet » Sun Oct 14, 2018 6:08 pm
IanB wrote:
Sun Oct 14, 2018 5:39 pm
No, I'm not sure what version to download
You are in for a treat then..... the Xilinx tools, especially on Windows, are a complete nightmare.
Some basics:
- you need ISE 14.7, not Vivado (which is for more recent devices)
- the recent ISE 14.7 Windows 10 release only supports Spartan 6 devices, not older devices like CPLD
- the complete ISE 14.7 package (which allows you to compile the VHDL files) is 8GB of download.
- the ISE 14.7 lab tools package (which will let you program devices) is only 1GB.
So for programming, your best bet is Windows 7 and install the Lab Tools package. Here's the link:
https://www.xilinx.com/member/forms/dow ... 1015_1.tar
(although it's a tar file, it is multi-platform)
Once you have this installed and can run the programmer software (impact) give me a shout.
IanB
Post by IanB » Sun Oct 14, 2018 7:34 pm
Ok I've installed that
I'm also downloading the full non-windows10 version but that will take a while...
Post by hoglet » Sun Oct 14, 2018 7:53 pm
Can you find/launch a program called "impact" without it crashing?
Do you actually have the programming cable now?
In the next post, I'll write down the steps you need to follow. It will take me a few minutes to do this...
IanB
Post by IanB » Sun Oct 14, 2018 8:06 pm
Yes I found my old cable and I've already programmed the CPLD, finding the right software to install was my main problem but I suggest you post your steps anyway for the others that are building one.
Testing shortly once I've finished building the RGB cable...
Post by hoglet » Sun Oct 14, 2018 8:27 pm
Programming the RGBtoHDMI CPLD
Content moved to the wiki:
https://github.com/hoglet67/RGBtoHDMI/w ... rogramming
IanB
Post by IanB » Sun Oct 14, 2018 9:11 pm
Thanks, that's basically what I did.
Well... It mostly works but I'm getting tearing which looks like horizontal sync detection issues
This is on a Master 128.
Post by hoglet » Sun Oct 14, 2018 9:18 pm
Hmmm, not seen this before. A few questions...
Do you see this in all screen modes?
Is this using a Pi Zero or a Pi Zero W?
Is this with your own kernel, or with the standard distribution?
How long is your cable?
Do you have a different machine you could try it on?
I assume you are powering this from the Master via the RGB cable, and that there is no other power supply involved.
IanB
Post by IanB » Sun Oct 14, 2018 10:00 pm
Yes, but it's not so noticeable in Modes 2 & 5 and gets a lot worse when using inverted video (col.129,col.0)
Also very noticeable when moving the mouse or holding a key down.
My gut feeling is noise on the +5v supply. I tried removing some internal expansions and that varied but didn't eliminate the problem
It's a Pi Zero but I have some Zero W's as well and another hat so plenty of combinations to try
I tried adjusting the Mux setting but it didn't make any difference
Standard file:
RGBtoHDMI_20180723_156dec8.zip
30cm
Yes I just tried it on a standard BBC and it was OK
Yes via the RGB cable
Is it OK to disconnect the +5v and power it from a standard PI supply?
Post by hoglet » Sun Oct 14, 2018 10:31 pm
I don't see why not, but it's not something I've tried myself. The reason being you would then need to be very careful about power supply sequencing, i.e. don't ever have the Beeb on and the Pi off, otherwise you risk damaging the CPLD.
Anyway, I don't think this a +5V power supply issue, as both the Pi and CPLD run of 3.3V, so there is a regulator in the way.
I think it's a problem with noise on the CSYNC signal. This signal goes directly into the CPLD so it's quite sensitive to noise. There is some digital de-glitching in the CPLD to suppress noise, but it sounds like this is not sufficient in your case.
I've seen significant CSYNC glitches on one other Master (BigEd's). The effect was similar. It causes the pixel counter in the CPLD to be spuriously reset, which shifts the position of the current line over to the left. This looks like what you are seeing. On BigEd's system the deglitching we added to the CPLD resolved the issue completely.
If you have a scope, connect it up to CSYNC and set it to trigger on low-going pulses shorter than say 1us, with trigger level of about 2.0V. This should catch any glitches.
The source of this noise seems to be data bus contention when the data bus is switched between processor data and video data. In some Masters it seems the timing is off slightly, and bus contention can exist for a short period each clock cycle. The severity of this depends on the screen memory contents - filling with 0xFF makes things significantly worse.
It's possible some RC filtering on CSYNC would help here. But a digital solution might be better. Trouble is, there's pretty much no space left in the CPLD.
Anyway, have a play with the scope, and see if you can catch any glitches. Depending how long they are, we can decide what to do next.
Post by hoglet » Sun Oct 14, 2018 10:34 pm
There are some pictures of the CSYNC noise we captured on BigEd's Master in this post:
viewtopic.php?f=3&t=13973&p=207057&hili ... se#p207057
The glitches were ~10ns wide, so you might struggle to see them depending on your scope bandwidth.
IanB
Post by IanB » Sun Oct 14, 2018 10:36 pm
Yes, I tried putting a 100uF low esr capacitor across the +5v supply on the hat and that made it worse so definitely not the supply.
I agree, I put a 1nF capacitor from the sync line to ground and that got rid of it so it's likely HF noise on the sync line.
It doesn't seem to affect the picture when connected via a scart cable to a standard TV but then TVs usually filter the sync signal to get rid of any noise.
Post by hoglet » Sun Oct 14, 2018 10:47 pm
Do you have a scope? If so, what model is it?
It would be great if you could capture a trace of the glitch (without the 1nF capacitor).
This is the current VHDL for glitch suppression:
https://github.com/hoglet67/RGBtoHDMI/b ... .vhdl#L187
It will reject a pulses shorter than 3 samples (i.e. ~20ns or less) which twice what we observed on BigEd's master. Your's must be worse than this.
There are ~6 free macrocells, so I might be able to beef this up a bit.
IanB
Post by IanB » Sun Oct 14, 2018 11:18 pm
They were very obvious and frequent on my M128:
Spot the sync pulse!
Looks to be around 15ns normally so your filter mostly works but that blip at the end might indicate a second glitch so maybe it's occasionally around 30ns which would cause the problems I'm seeing
Edit: replaced images with better captures
IanB
Post by IanB » Mon Oct 15, 2018 1:59 am
Now I've got it more or less running with the capacitor workaround I noticed that the image was still a bit soft on my 1600*1200 monitor so I experimented with the GPU scaling kernel and got it using nearest neighbour instead which results in really sharp edged pixels.
Edit the Config.txt file and add the following line:
scaling_kernel = 8
This setting should be OK on 1920x1080, 1920x1200, 1600x1200 & 720x576 resolutions but will look terrible on other resolutions that force non-integer scaling.
The available options are 1 to 8 with 6 being the default.
The values are:
SCALERLIB_KERNELS_TYPES_SINC=1,
SCALERLIB_KERNELS_TYPES_SINC_BLACKMAN=2,
SCALERLIB_KERNELS_TYPES_SINC_NO_SIDE_LOBES=3,
SCALERLIB_KERNELS_TYPES_SINC_HALF_FIRST_SIDE_LOBE=4,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING=5,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING_3PI=6,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING_2_5PI=7,
SCALERLIB_KERNELS_TYPES_NEAREST_NEIGHBOUR=8,
The other values give varying compromises between sharpness and unevenness when non integer scaling.
Post by hoglet » Mon Oct 15, 2018 9:03 am
Ian,
Those glitches are similar to what we saw on BigEd's Master - only a bit more aggressive!
What I will do this morning is see if I can squeeze a few more registers into the CPLD to make the glitch detection more robust. If this works, it may be better then the capacitor, as you really want a well defined edge for CSYNC, otherwise it adds jitter to the sampling points.
Can you do a quick test for me (with the capacitor). Put up a fairy busy MODE 7 screen (e.g. the STH archive Menu screen), or failing that just a load of text. Hit auto calibrate. Once done, clear the screen (Ctrl-L) and bring up the error statistics (which I think is left button then right button). I'd like to compare them with what I get.
I'll also try your scaling_kernel setting, I haven't experimented with that before.
I also have a 1600x1200 monitor (a HP2065). Are you using the standard setting for 1600x1200 in the config file:
## 1600x1200 @ 50Hz
## Scale by 1:2 - 672x540 => 1344x1080
##   l/r overscan = (1600-1344)/2 = 128
##   t/b overscan = (1200-1080)/2 =  60
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1600 1200 50 1 0 0 0
overscan_left=128
overscan_right=128
overscan_top=60
overscan_bottom=60
But it's great to see an independently build unit up and working so quickly.
Post by hoglet » Mon Oct 15, 2018 11:26 am
scaling_kernel = 8
Gosh, that certainly makes an improvement in Modes 0..6.
In Mode 7 I think it's subjective whether it's better or not.
Anyway, onto the subject of de-glitching CSYNC.
I've re-worked the de-glitching logic to use a 4-bit counter, so it should suppress CSYNC glitches of up to ~150ns.
As I don't have a Master with this behaviour myself, would you mind giving this CPLD a try?
RGBtoHDMI.zip
(8.06 KiB) Downloaded 10 times
You'll need to remove the 1nF capacitor of course.
IanB
Post by IanB » Mon Oct 15, 2018 12:08 pm
Yes I am using that mode, the default scaling kernel produces very soft results even on a 2:1 scale.
Note this setting will produce some horizontal unevenness in mode 7 as that isn't scaled 2:1 but it doesn't seeem to be that noticeable.
If you need some interpolation, I found that a setting of 2 provided a good compromise for Mode 7 so if you can switch this setting on the fly, perhaps use 8 for modes 0-6 and 2 for mode 7
I can't get the above mode to lock using the hdmi clock adjustment, the red bar always moves down the screen even at the lowest 623 setting (although it is very slow on that value)
Seems to have made it worse
I noticed there were inverted glitches in the sync signal itself, are you filtering those?
Thats two vertical lines BTW with 4 ghosts each.
Post by hoglet » Mon Oct 15, 2018 3:22 pm
Ah no, those won't currently be filtered. I don't think we saw those on Ed's Master.
Let me have another think, but we are very short of registers so this may not be possible.
It does seem strange how this issue affects some Master but not others. On the other thread, Dominic said he had a similar issue, which turned out to be cracking / a dry joint on one of the power connections into the main board. It might be worth checking your connections are sound.
Post by hoglet » Mon Oct 15, 2018 5:03 pm
Ian,
Here's another version to try....
RGBtoHDMI.zip
(7.61 KiB) Downloaded 9 times
It may not be the final version, and indeed it may not even work!
I have tested it on my Master, but as it doesn't have any glitches that's not very conclusive.
In this version, de-glitching is applied to both csync=0 and csync=1 states. A change in csync will only be registered if it remains in the new state for N consecutive samples. At the moment, N is set to 15 samples, which is 156ns. This may in fact be way too long.
You can see the VHDL here:
https://github.com/hoglet67/RGBtoHDMI/b ... .vhdl#L184
Now, the ideal value for N is slightly more than the longest glitch you want to swallow. Any longer than this may be counter productive. In particular, if a glitch happens with N samples of the true edge, then it's effect will be to delay recognition of that edge. That would introduce one or two pixels worth of jitter on that line.
It would be very useful if you could use your scope in persistence mode (with minimum hold-off) and try to better characterise the maximum duration of both positive going and negative going glitches. In my experience they are worse on a mostly white screen than a mostly black screen (i.e. when screen memory is full of 0xFF)
Anyway, see if this is any better.
IanB
Post by IanB » Mon Oct 15, 2018 5:39 pm
That worked, so it looks like maybe filtering the +ve going pulses in the h-sync was the solution, maybe it would now work with just a 20nS filter.
Looking at the above screen cap with the 'ghosts', they are separated from the actual sync edge by something of the order of multiples of 1uS and in fact that block seems to be about 4uS wide which is about the width of a sync pulse. This means that a glitch may not happen close to the leading or trailing edge of the actual H-sync pulse.
Are you triggering off the falling or rising edge of the sync pulse?
Post by hoglet » Mon Oct 15, 2018 5:51 pm
Good to hear that helped.
Initially I was triggering on the rising edge. But then switched to the falling edge, based on advice from others that:
a) It was the correct thing to do
b) It's needed to support Tricky's smooth horizontal scrolling, which varies the sync pulse width (in the same way a CRT would)
Would you like to try builds with smaller values of N, say N=7 and N=3?
IanB
Post by IanB » Mon Oct 15, 2018 5:55 pm
Would you like to try builds with smaller value of N, say N=7 and N=3?
Yes.
Probably best to get the detect period as short as possible as a variable sync width might get close to one of the glitch periods.
Post by hoglet » Mon Oct 15, 2018 6:13 pm
Yes.
Here you go: N=15, N=7 and N=3 to try:
RGBtoHDMI.zip
(22.75 KiB) Downloaded 7 times
Other intermediate values would be possible.
I think the nominal sync pulse width is 4us. A shorter pulse was 3us or 3.5us. A longer pulse was 4.5us or 5.0us.
So we are a long way from considering that a glitch (<150ns at N=15)
IanB
Post by IanB » Mon Oct 15, 2018 7:47 pm
N=3 works fine so I haven't bothered with the N=7 as that is bound to work too.
It seems my problem was likely the inverted glitches in the h sync rather than the length of the glitches.
Do you want me to try N=1 & 2 to determine the safety margin?
Post by hoglet » Mon Oct 15, 2018 8:43 pm
Why not....
RGBtoHDMI.zip
(37.85 KiB) Downloaded 7 times
I wonder if it's worth making this software configurable from the Pi. There might just be the space to do that for up to n=7. This would cost 3 extra registers in the CPLD.
Edit: Yup, just.....
Function    Mcells      FB Inps     Pterms      IO
Block       Used/Tot    Used/Tot    Used/Tot    Used/Tot
FB1          18/18*      31/54       45/90       6/ 9
FB2          18/18*      27/54       38/90       8/ 9
FB3          18/18*      29/54       79/90       9/ 9*
FB4          18/18*      49/54       75/90       5/ 7
             72/72      136/216     237/360     28/34
IanB
Post by IanB » Mon Oct 15, 2018 9:30 pm
Why not....
Both 1 & 2 work OK so they are very short glitches
I would say that 2 or 3 would be optimum values
Doesn't seem that necessary, you had the right solution and timing but just missed the inverted glitches.
I had another play around with scaling_kernel and I think you should add that to config.txt, perhaps with different values for each mode so that the integer modes had a sharp scaler and the non-integer ones had a soft one.
I wonder if it's possible to change this setting on the fly as you could then have different settings for modes0-6 and mode 7 (modes 0-6 look great with a setting of 8 and mode 7 looks good with a setting of 2)
I would suggest a default of 2 or 8 for integer modes and 6 for non-integer ones.
There also appears to be a scaling_sharpness setting but I couldn't find any info about it.
Also as mentioned above, the vsync / hdmi freq. optimisation doesn't seem to be working for me as the red bar is always moving.
The error is shown as 301ppm beeb slower than pi.
Post by hoglet » Mon Oct 15, 2018 10:01 pm
OK, lets go with a fixed value of 3, to give a small amount of extra margin.
I'll test this with BigEd's Master (hopefully Wednesday) and then merge this into Master.
On the other point, I don't think it's documented how to change scaling_kernel dynamically from bare metal code.
I will add it to the config files, and people can include it or not as they see fit.
IanB
Post by IanB » Mon Oct 15, 2018 10:22 pm
OK
If you're tweaking the config file, perhaps you could add another couple of default resolutions:
800x600 50Hz and 1024x600 50Hz
There are various 4:3 12" monitors with a resolution of 800x600 and many HDMI LCD panels of 1024x600 available on amazon and ebay and they would work with no scaling so good quality images (as long as they work at 50Hz). I intend to use one of the latter panels to replace a 6" CRT in one of the old prisma 2 based graphics systems I have and it looks like the 4:3 area of the lcd will just fill the 4:3 opening in the case.
Any thoughts on the vsync issue I mentioned above?
Post by hoglet » Mon Oct 15, 2018 10:24 pm
It was quite experimental, and I didn't get much feedback. It's quite possible there are bugs.
On my system I get 439ppm (Beeb slower than Pi)
I'll need to refresh my memory of how this was meant to work. But I think the calibration is currently done just once, immediately after the Pi boots. So if you want to re-calibrate then you need to press the reset button. It does drift after a while.
Does changing the HDMI clock setting affect the rate that the red line is moving?
- For interlaced modes 624 should be the best setting
- For non-interlaced modes 623 should be the best setting
The default is HDMI Original, which puts the HDMI clock back to the standard for the Pi Mode.
On the best setting, how long does it take to cover the complete screen?
The aim was not that this be perfect. Rather that when used with double/triple buffering the rate of buffer skipping would be once every few minutes or better.
