MAME: Tube devices
Re: MAME: Tube devices
Post by hoglet »
Just noticed something a little strange....
Your Client ROM trace doesn't seem to match the disassembly on JGH's site for v1.00:
http://mdfs.net/Software/Tube/ARM/v100.zip
And the SHA-1 sum is different:
dmb@greenhog:~$ wget http://mdfs.net/Software/Tube/ARM/Eval100.rom
dmb@greenhog:~$ sha1sum Eval100.rom
f0b184bb530615daa3fa2f557f1848be30ad3997  Eval100.rom
Where did it originate from?
It's not worth me trying to compare traces until we are running the same ROM!
Can you post it and I'll check it works in PiTubeDirect.
Post by hoglet »
Ah, it's this one:
https://github.com/hoglet67/b-em/blob/m ... al_100.rom
Brazil version -.005 (8th August 1986)
I'm now slightly confused as to what this is exactly....
But it does seem to work OK in PiTubeDirect.
To make comparing traces easier, is there any chance you could make a new one:
- without any manual edits (yes, I know it will be big!)
- with a single *HELP and nothing else
Post by Pernod »
I didn't make any manual edits, this is what the MAME debugger produces by default. I see I can use noloop to disable loop detection.
The attached is using the same Brazil -.005 ROM, with a single *HELP. I now have 7 ROMs that all vary slightly, some more than others, and all have the same outcome.
It has to be something very subtle.
- If the ROM paging was incorrect it wouldn't start.
- If the RAM was incorrect it also wouldn't start and it even detects the correct amount.
- Maybe how the Tube is mapped from 8bit to 32bit? But wouldn't expect it to get as far as it does if this was the case.
trace_arm005nl.zip
(963.16 KiB) Downloaded 59 times
Post by hoglet »
Thanks, I'll work with that trace for now.
It looks like it is actually from v100, as the reset vector jumps to 0x3001730
But that's fine, as we have a disassembly for this version.
Post by Pernod »
I tried changing how the device starts, by copying the ROM into RAM instead of paging it, and now it works. This isn't how the hardware works so I still need to find out why it failed before and fix it, but I now know where to look.
Thanks for the help, but no need to continue comparing traces.
Post by hoglet »
Pernod wrote:I tried changing how the device starts, by copying the ROM into RAM instead of paging it, and now it works. This isn't how the hardware works so I still need to find out why it failed before and fix it, but I now know where to look.
That's interesting.... because we do the same in PiTubeDirect:
https://github.com/hoglet67/PiTubeDirec ... rm2.c#L184
One thing you might like to try is setting rd/wr watch points on the tube data registers:
- 1000004
- 100000C
- 1000014
- 100001C
You should see a trace like this:
Mem Wr watchpoint hit at cdf            : 1000004 = a       R1: Reset message
Mem Wr watchpoint hit at cdf            : 1000004 = d
Mem Wr watchpoint hit at cdf            : 1000004 = 41
Mem Wr watchpoint hit at cdf            : 1000004 = 63
Mem Wr watchpoint hit at cdf            : 1000004 = 6f
Mem Wr watchpoint hit at cdf            : 1000004 = 72
Mem Wr watchpoint hit at cdf            : 1000004 = 6e
Mem Wr watchpoint hit at cdf            : 1000004 = 20
Mem Wr watchpoint hit at cdf            : 1000004 = 52
Mem Wr watchpoint hit at cdf            : 1000004 = 4d
Mem Wr watchpoint hit at cdf            : 1000004 = 53
Mem Wr watchpoint hit at cdf            : 1000004 = 65
Mem Wr watchpoint hit at cdf            : 1000004 = 64
Mem Wr watchpoint hit at cdf            : 1000004 = 50
Mem Wr watchpoint hit at cdf            : 1000004 = 73
Mem Wr watchpoint hit at f3             : 1000004 = 34
Mem Wr watchpoint hit at f3             : 1000004 = 30
Mem Wr watchpoint hit at f3             : 1000004 = 39
Mem Wr watchpoint hit at f3             : 1000004 = 36
Mem Wr watchpoint hit at cdf            : 1000004 = 4b
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 0
Mem Rd watchpoint hit at 28000bb6       : 100001c = 5       R4: Tube Release
Mem Rd watchpoint hit at 8000d86        : 100001c = 80
Mem Rd watchpoint hit at 3000d73        : 100000c = 80      R2: Reset Response - enter language ?
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       R2: OSBYTE A=&87
Mem Wr watchpoint hit at 20000d33       : 100000c = 90
Mem Wr watchpoint hit at 20000d33       : 100000c = 0
Mem Wr watchpoint hit at 20000d33       : 100000c = 87
Mem Rd watchpoint hit at d73            : 100000c = d
Mem Rd watchpoint hit at d73            : 100000c = 3       Mode 3
Mem Rd watchpoint hit at d73            : 100000c = 20
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       R2: OSBYTE A=&EC
Mem Wr watchpoint hit at 20000d33       : 100000c = 14
Mem Wr watchpoint hit at 20000d33       : 100000c = eb
Mem Wr watchpoint hit at 20000d33       : 100000c = ec
Mem Rd watchpoint hit at 20000d73       : 100000c = b8
Mem Rd watchpoint hit at 20000d73       : 100000c = 0
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 17      VDU 23,255,...
Mem Wr watchpoint hit at 20000cdf       : 1000004 = ff
Mem Wr watchpoint hit at f3             : 1000004 = 0
Mem Wr watchpoint hit at f3             : 1000004 = 2a
Mem Wr watchpoint hit at f3             : 1000004 = 7f
Mem Wr watchpoint hit at f3             : 1000004 = ab
Mem Wr watchpoint hit at f3             : 1000004 = e
Mem Wr watchpoint hit at f3             : 1000004 = 38
Mem Wr watchpoint hit at f3             : 1000004 = ba
Mem Wr watchpoint hit at f3             : 1000004 = ff
Mem Wr watchpoint hit at f3             : 1000004 = aa
Mem Wr watchpoint hit at f3             : 1000004 = e0
Mem Wr watchpoint hit at f3             : 1000004 = b0
Mem Wr watchpoint hit at f3             : 1000004 = 1
Mem Wr watchpoint hit at f3             : 1000004 = 80
Mem Wr watchpoint hit at f3             : 1000004 = b6
Mem Wr watchpoint hit at f3             : 1000004 = fc
Mem Wr watchpoint hit at f3             : 1000004 = 78
Mem Wr watchpoint hit at cdf            : 1000004 = 17      VDU 23,255,...
Mem Wr watchpoint hit at cdf            : 1000004 = ff
Mem Wr watchpoint hit at d33            : 100000c = 4       OSBYTE A=&03
Mem Wr watchpoint hit at d33            : 100000c = 0
Mem Wr watchpoint hit at d33            : 100000c = 3
Mem Rd watchpoint hit at d73            : 100000c = 14
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&D9
Mem Wr watchpoint hit at 20000d33       : 100000c = d9
Mem Rd watchpoint hit at 20000d73       : 100000c = a2
Mem Wr watchpoint hit at d33            : 100000c = 0       OSRDCH
Mem Rd watchpoint hit at d73            : 100000c = 24
Mem Rd watchpoint hit at d73            : 100000c = 48      H
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&DA
Mem Wr watchpoint hit at 20000d33       : 100000c = ff
Mem Wr watchpoint hit at 20000d33       : 100000c = da
Mem Rd watchpoint hit at 20000d73       : 100000c = a3
Mem Rd watchpoint hit at 20000d73       : 100000c = 9
Mem Wr watchpoint hit at f3             : 1000004 = 48      OSWRCH H
Mem Rd watchpoint hit at d73            : 100000c = 22
Mem Rd watchpoint hit at d73            : 100000c = 45      E
Mem Wr watchpoint hit at f3             : 1000004 = 45      OSWRCH E
Mem Rd watchpoint hit at d73            : 100000c = 26
Mem Rd watchpoint hit at d73            : 100000c = 4c      L
Mem Wr watchpoint hit at f3             : 1000004 = 4c      OSWRCH L
Mem Rd watchpoint hit at d73            : 100000c = 28
Mem Rd watchpoint hit at d73            : 100000c = 50      P
Mem Wr watchpoint hit at f3             : 1000004 = 50      OSWRCH P
Mem Rd watchpoint hit at d73            : 100000c = 6
Mem Rd watchpoint hit at d73            : 100000c = d       <cr>
Mem Wr watchpoint hit at cdf            : 1000004 = a       Supervisor 1.00 ....
Mem Wr watchpoint hit at cdf            : 1000004 = 75
Mem Wr watchpoint hit at cdf            : 1000004 = 70
Mem Wr watchpoint hit at cdf            : 1000004 = 76
Mem Wr watchpoint hit at cdf            : 1000004 = 69
Mem Wr watchpoint hit at cdf            : 1000004 = 31
Mem Wr watchpoint hit at cdf            : 1000004 = 2e
Mem Wr watchpoint hit at cdf            : 1000004 = 30
Mem Wr watchpoint hit at cdf            : 1000004 = 45
Mem Wr watchpoint hit at cdf            : 1000004 = 78
Mem Wr watchpoint hit at cdf            : 1000004 = 74
Mem Wr watchpoint hit at cdf            : 1000004 = 28
Mem Wr watchpoint hit at cdf            : 1000004 = 36
Mem Wr watchpoint hit at cdf            : 1000004 = 68
Mem Wr watchpoint hit at cdf            : 1000004 = 4a
Mem Wr watchpoint hit at cdf            : 1000004 = 39
Mem Wr watchpoint hit at cdf            : 1000004 = 38
Mem Wr watchpoint hit at cdf            : 1000004 = 29
Mem Wr watchpoint hit at d33            : 100000c = 2       OSCLI
Mem Wr watchpoint hit at d5b            : 100000c = 48      H
Mem Wr watchpoint hit at d5b            : 100000c = 45      E
Mem Wr watchpoint hit at d5b            : 100000c = 4c      L
Mem Wr watchpoint hit at d5b            : 100000c = 50      P
Mem Wr watchpoint hit at 40000d5b       : 100000c = d       <cr>
Mem Rd watchpoint hit at d73            : 100000c = 7f      don't execute
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&87
Mem Wr watchpoint hit at 20000d33       : 100000c = 48
Mem Wr watchpoint hit at 20000d33       : 100000c = b4
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&EC
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 17      VDU 23,255,... as above
Mem Rd watchpoint hit at 20000d73       : 100000c = 12
This might help you see where it's going wrong...
Post by Pernod »
It's now working with the ROM paging, yay! My problem was using 32bit handlers for the RAM, now using 8bit.
Now which ROMs are known to be good? I have 7 different versions.
ROM_SYSTEM_BIOS(0, "100jgh", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("Eval100.rom", CRC(e59e469d) SHA1(f0b184bb530615daa3fa2f557f1848be30ad3997) // JGH
ROM_SYSTEM_BIOS(1, "101jgh", "Executive v1.00 (14th August 1986)")
ROMX_LOAD("Eval101.rom", CRC(d6ab1a06) SHA1(3b16cd35dd1d86932499728336547e37d5222ebc) // JGH
ROM_SYSTEM_BIOS(2, "005jgh", "Brazil v-.005 (8th August 1986)")
ROMX_LOAD("Brazil005.rom", CRC(d294f888) SHA1(5b051d0afad9b46a32801aa5ef262536adf2a921)// JGH
ROM_SYSTEM_BIOS(3, "100h", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("ARM Evaluation System 1.00.rom", CRC(cb29a585) SHA1(15e15c78db34cfa22a83689be0de30704b7a4c67) // huininga
ROM_SYSTEM_BIOS(4, "101h", "Executive v1.00 (14th August 1986)")
ROMX_LOAD("ARM Evaluation System 1.01.rom", CRC(cab85473) SHA1(f86bbc4894e62725b8ef22d44e7f44d37c98ac14) // huininga
ROM_SYSTEM_BIOS(5, "100b", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("ARMeval_100h.rom", CRC(ed80462a) SHA1(ba33eaf1a23cfef6fc1b88aa516ca2b3693e69d9) // BeebEm/huininga
ROM_SYSTEM_BIOS(6, "005", "Brazil v-.005 (8th August 1986)")
ROMX_LOAD("ARMeval_100.rom", CRC(7c27c098) SHA1(abcc71cbc43489e89a87aac64e67b17daef5895a) // b-em
I've tried most of the available software on the 6 ARM discs and looks good so far. Is there anything else I should be using to give it a thorough test?
Post by Pernod »
Something a little unusual ...
Post by jgharston »
hoglet wrote:Just noticed something a little strange....
There are several versions of various versions(!) of the ARM Client ROM. For instance, the A500 we were looking at at ABUG is also Brazil 005/Supervisor 1.00, but a different "version". It looks very much like people built their own ROM set by including whatever modules they wanted. I think I now have three 005/1.00s, a 0.99 and two 1.01s.
Post by Pernod »
I'm playing with the ROMs for the Torch Communicator that are for the Master (ABM) and BBC 1770 (ABW), but can't get them to read a floppy. Has anyone used these ROMs on real hardware? Probably an emulation issue, but wondered if I need to do something different for the 1770 controllers.
The CBL and ABL ROMs work fine with the 8271, just 1770 variants I'm having trouble with.
This is MAME running a Master with Torch Communicator and ROM MCP v1.22 (ABM).
Post by jgharston »
Pernod wrote:
Thu Sep 20, 2018 7:30 pm
I had Torches working back at Uni in the late 1980s, but they all had 8271 floppy hardware.
Post by Pernod »
Been looking at the ReCo6502 and now have it running with either a 65C02 or 65C816.
Configuring the clock with the soft options also works, but still to implement the configuration links and some testing.
Post by Pernod »
Seems to have been awhile since I added any new Tube devices, so taking a look at this...
Not quite there with it yet, but is there any software that makes use of it, apart from running BASIC very fast?
Post by BigEd »
There's a C compiler - but whether it will run on ARM7, I don't know.
viewtopic.php?t=13419
Site Admin
Post by Arcadian »
IIRC Greg Cook's rotating BBC Micro demo was written for the ARM7TDMI:
http://regregex.bbcmicro.net/
Please subscribe to the ABug YouTube channel!
hjalfi
Post by hjalfi »
What OS does the ARM coprocessor run? Is it a TubeOS-style stub which forwards system calls to the I/O processor?
If so, and if you can find me an emulator, I can probably do you a compiler, given a little work...
David Given
http://cowlark.com
Post by Pernod »
Arcadian wrote:
Sat Jun 20, 2020 1:44 pm
Thanks for the suggestions. I'm surprised that such a capable copro hasn't been utilised more. Could the Doom port be made to run on this?
A little more progress, but have been stuck with this for a few days now.
It boots, and was able to apply the patch to update the OS to 0.45:
But fails to run the beeb35 demo. It's loaded into RAM on the copro but then hangs on an interrupt :?
I see it's also supported in the latest BeebEm, but the option to select it is always disabled even though the ROM exists. Does it actually work in BeebEm?
Edit: Think it's time to contact Mr.Sprow.
Post by Pernod »
A little teaser:
An Electron with AP6 expansion, with AP3/4, AP5 cartridges, and 32016 co-processor.
dudleysoft71
Post by dudleysoft71 »
Pernod wrote:
Fri Jun 19, 2020 11:04 pm
Both Frontier viewtopic.php?f=53&t=19832 and BAGI viewtopic.php?f=65&t=20059 work with the ARM7TDMI co-processor, I implemented support to make testing easier, rather than having to copy the HDD image over to SD card every time I changed the file.
My Smacker player also supports the ARM7TDMI core, but I haven't released a version of that yet.
James Watson - DudleySoft
BBC Model B 32K - PiTubeDirect, Pi1Mhz, Smally Mouse, Gotek, DFS/ADFS, 4xSWRAM.
Post by Pernod »
dudleysoft71 wrote:
Thu Sep 10, 2020 4:03 pm
My ARM7TDMI is not quite ready yet, but did post some Frontier screenshots over at https://forums.bannister.org/ubbthreads ... Post117795. Haven't looked at BAGI yet but looking forward to seeing Smacker.
Post by daveejhitchins »
Pernod wrote:
Thu Sep 10, 2020 3:13 pm
A little teaser:
Nigel . . . You shouldn't need a Tube ROM as the Tube code is in the AP6/Plus Support ROM.
Dave H.
Post by Pernod »
daveejhitchins wrote:
Thu Sep 10, 2020 7:45 pm
I know, but the AP5 device has the Tube ROM pre-fitted.
Pernod wrote:
Thu Sep 10, 2020 8:15 pm
Ah! I see . . . For when the AP6, P.R.E.S. Plus 1 ROM or JGH's Plus 1 support ROM isn't fitted ? Does the Plus 1 always have the original ROM fitted then?
Dave H.
Post by Pernod »
Thu Sep 10, 2020 10:07 pm
In the next release you'll have the option of 3 variants of the Plus 1:
- original Acorn Plus 1 (plus1) with original ROM.
- PRES AP1 (ap1) same functionality as plus1 but with AP2 ROM.
- PRES AP6 (ap6) with extra sockets filled with RAM by default and the JGH AP6 ROM.
Pernod wrote:
Fri Sep 11, 2020 1:29 am
=D> Brilliant . . .
Dave H.
Post by Pernod »
Fri Sep 11, 2020 7:34 am
=D> Brilliant . . .
Knew you'd like that. The AP6 is now my preferred expansion device, rather than the RomBox+. Even in emulation it feels much more complete, adding so much more flexibility. Every Electron owner should have one =D>
I should add that the previous Electron Tube issues have been resolved, had to tighten the timing so that some bytes weren't missed during transfer from host to parasite over the Tube. The improved timing also fixed the AP3/4 cartridges which had never previously worked, they also rely on polling rather than interrupts so were previously missing byte transfers.
fordp
Post by fordp »
A little teaser:
I did some of the work on the 32016 SoftCore (with lots of work by Hoglet and others) it will be great if it makes it into Mame. I wonder if there are other 32xxx machines that will use the code?
FordP (Simon Ellwood)
Post by Pernod »
fordp wrote:
Fri Sep 11, 2020 2:39 pm
I wrote the 32016 disassembler for MAME about 18 months ago, but never actually implemented the CPU. It's now being written from scratch by another team member, which is making steady progress.
It's also used by the E-mu Emulator III synthesizer, and the Whitechapel MG-1 workstation which is currently being developed.
fordp
Post by fordp »
Pernod wrote:
Fri Sep 11, 2020 2:47 pm
Ooh if you are not using the one from b-em that will be fun to see how somebody else codes it. b-em also has a disassembler of course which I did some work on.
Post by Pernod »
fordp wrote:
Fri Sep 11, 2020 3:02 pm
See https://github.com/mamedev/mame/blob/ma ... s32000.cpp
