Educational Archive not in STH
OneSwitch
Re: Educational Archive not in STH
Post by OneSwitch » Wed Sep 19, 2018 9:59 pm
flaxcottage wrote:
Fri Sep 14, 2018 10:12 am
OneSwitch wrote:
Thu Sep 13, 2018 10:24 pm
@Flaxcottage - are you planning to upload the Brilliant Computing and other Special Needs educational stuff too?
Yes it is on my list.
I do take requests but I cannot guarantee I'll honour them in a reasonable time frame. :? :lol:
:) Good man. Fair enough.
OneSwitch
Post by OneSwitch » Wed Sep 19, 2018 10:01 pm
Really like that Tent game @Kenelm, thanks for sharing. I'd be interested in the others too.
I've now realised most of the others are already on here, see here and here.
Nice one. Good to preserve this stuff.
Kenelm
Post by Kenelm » Wed Sep 19, 2018 10:23 pm
These are my final Longman titles.
Aural 5 - "Aural Test Preparation for grade five music examinations".
Aural 5.ssd
(15 KiB) Downloaded 26 times
Terrible Tales - stories about giants and monsters.
Terrible Tales.ssd
(61 KiB) Downloaded 26 times
I have found all the software I have uploaded so far to be mostly or entirely usable without printed documentation, unfortunately this isn't the case for the final titles below. I'm uploading them just in case the documentation can be found.
Micro Map 1 & 2 - all exercises require a printed map.
Micro Map 1.ssd
(20.75 KiB) Downloaded 24 times
Micro Map 2.ssd
(26.5 KiB) Downloaded 24 times
Choosing Sites - somewhat usable, but confusing without the documentation. I didn't initially list this with my Longman titles. The disk label says 'MESU Software' with Longman in smaller lettering underneath. In the program itself only 'Longman Micro Software' is displayed.
Choosing Sites.ssd
(61 KiB) Downloaded 24 times
billcarr2005
Post by billcarr2005 » Thu Sep 20, 2018 7:10 am
Kenelm wrote:
Wed Sep 19, 2018 12:22 pm
I have managed to circumvent the protection. In all cases the protection was as you describe. flaxcottage's post here saved me a lot of time.
Except it's better to skip the redundant read entirely, rather than ignore it's result :)
Kenelm
Post by Kenelm » Sat Oct 06, 2018 11:09 pm
Today I've been looking at five discs from Cambridge Micro Software (Cambridge University Press/Homerton College). I created SSDs for these a while ago, but found they wouldn't boot. They turned out to contain copy protection in machine code !BOOT files. Most of the other files were written in BASIC and the protection does not prevent these from running. However, I did sometimes encounter crashes due to lack of memory, and so wanted to check what the boot files were doing before sharing.
My knowledge of assembly code is somewhat limited, but I like a challenge, so have spent a while working out what the disassembled !BOOT files do. For all the disks they are very similar. My understanding is that they first read sector IDs from the disk and then only proceed if the correct value is found. After this a block of data is EORed using the result of the sector ID check and the resulting code is then executed. The EORed code is BASIC and just sets PAGE before CHAINing one of the BASIC files.
To make the !BOOT files run correctly I have changed the first instructions to set memory location &81 to &AB (used for the EORing) before JMPing over the disk read and subsequent check. As I mentioned I'm far from experienced at doing this, so point out if anything appears wrong. I have tested all four programs and encountered no problems.
First up...
Granville
The premise is that you have won a five-day holiday in the town of Granville in Normandy. You have a set amount of prize money which can be spent in shops, to buy food and drink, to visit tourist sites, and so on. The dialogue is in French and the idea is presumably to improve French language comprehension.
There are some tasks that reference printed materials that I don't have, although these don't prevent you from getting a good idea what the program is about. It is a bit repetitive, but I think an interesting idea for an educational game.
Introduction
Newspaper
Drinks menu
Granville.ssd
(100 KiB) Downloaded 21 times
Post by flaxcottage » Sat Oct 06, 2018 11:21 pm
Thanks for that. I had heard of the title but never seen the package.
The protection sounds interesting. I have met setting &81 before in a protection method.
The only Cambridge Micro Software titles I have were all unprotected.
Did the disc(s) have the date on them?
Kenelm
Post by Kenelm » Sat Oct 06, 2018 11:43 pm
Here's the disc -
'(c) CET 1986'
Kenelm
Post by Kenelm » Sat Oct 06, 2018 11:48 pm
Chemical Collisions
Simulates collisions of particles during a chemical reaction (collision theory).
Chemical Collisions.ssd
(18.75 KiB) Downloaded 21 times
Kenelm
Post by Kenelm » Sun Oct 07, 2018 12:51 am
Tessellations
A package for drawing tessellating patterns.
There is a library disc with additional patterns. I haven't worked out how these were intended to be loaded.
Tessellations.zip
(26.19 KiB) Downloaded 21 times
Post by flaxcottage » Sun Oct 07, 2018 10:00 am
Thanks. =D> =D> =D>
Kenelm
Post by Kenelm » Sun Oct 07, 2018 4:47 pm
Lift
Requires a joystick.
A small figure called Mabel can be moved up and dropped down a lift shaft. Scales below measure the force. It is possible to plot the velocity, acceleration and displacement.
Lift.ssd
(21.75 KiB) Downloaded 20 times
Kenelm
Post by Kenelm » Sun Oct 07, 2018 4:55 pm
Floater
"Displays the displacement, velocity and acceleration of a frictionless particle in a two-dimensional system."
Floater.ssd
(21.25 KiB) Downloaded 21 times
Kenelm
Post by Kenelm » Sun Oct 07, 2018 11:54 pm
Sand Harvest
MESU Software (Centre for World Development Education/Longman)
Simulation set in the Sahel. You can assume the role of nomad, government officer or villager.
Disc write access required.
Sand Harvest.ssd
(85 KiB) Downloaded 20 times
AndyF
Post by AndyF » Mon Oct 08, 2018 3:15 pm
Its very pleasing (to me at least!) to see simulations such as this see the "light of day" again, on a variety of subjects. I recall 'Millionaire' (its in the archive anyway) and the like.
Andy
Post by lurkio » Mon Oct 08, 2018 5:04 pm
A lot of this is new to me. Amazing how much Beeb eduware there was, and how little of it is widely known or remembered!
Brilliant work, Kenelm! Thanks for preserving this software history.
=D> =D> =D>
billcarr2005
Post by billcarr2005 » Tue Oct 09, 2018 1:33 pm
Seems like it's been mentioned before, albeit briefly, in a disc that Colin supplied. As Kenelm said, the disk can easily be imaged, since it's the standard layout, just with the head value in the sector header being abnormal
viewtopic.php?f=2&t=7190&start=450#p189279
Kenelm
Post by Kenelm » Tue Oct 09, 2018 10:47 pm
I'm glad the software is of interest. I've now managed to archive almost all of the 150 of so educational discs I have. In only two cases have I found the discs to be too damaged or deteriorated to recover. One of these is 'XOR for Schools', does anybody else have a copy?
There are also a small number with copy protection that has prevented me from creating working SSDs. Of these, only two appear not to have already been archived by other people. They are:
  • The Dudley Programs – Ballooning
  • The Dudley Programs – Understanding the Weather
Both are by Heinemann Computers/Fiveways Software. The type of protection used is exactly the same as described on the flaxcottage.com archive site under 'Protection'. It's defeated my attempts to crack it so far and I've reached the stage where I'd be happy for someone else to have a go.
Kenelm
Post by Kenelm » Tue Oct 09, 2018 11:00 pm
Language Work in the Classroom
Capital Media, written by Anita Straker
Three of the programs here are definitely already archived (Mallory Manor, Storyline and Wordplay), but I haven't seen the others listed anywhere (Maths Talk 1, Maths Talk 2 and Master).
Captial Media - Language Work in the Classroom.ssd
(48 KiB) Downloaded 20 times
Post by lurkio » Tue Oct 09, 2018 11:22 pm
I've now managed to archive almost all of the 150 of so educational discs I have. In only two cases have I found the discs to be too damaged or deteriorated to recover. One of these is 'XOR for Schools'...
Paging the Kryoflux Wizard... Paging the Kryoflux Wizard...
danielj wrote:
Mon Oct 31, 2016 6:37 pm
... Just for interest, here are a few screenshots from the kryoflux dump ...
Kenelm
Post by Kenelm » Wed Oct 10, 2018 12:04 am
Pipistrelle
MESU Software/Newman College
Fly around as a pipistrelle bat. Use echolocation to identify man-made features and catch insects.
Pipistrelle.ssd
(27.75 KiB) Downloaded 21 times
Post by danielj » Wed Oct 10, 2018 6:28 am
Hello! Am I required for a dump?
billcarr2005
Post by billcarr2005 » Wed Oct 10, 2018 7:37 am
I'd be happy to image / deprotect these! :)
Post by flaxcottage » Wed Oct 10, 2018 9:56 am
[*]The Dudley Programs – Ballooning
[*]The Dudley Programs – Understanding the Weather[/list]
At the moment billcarr2005 is the expert on the Hieneman/Fiveways protection. 8)
Thanks for all the software posted. Nearly all of it was MIA. =D> =D> =D>
Kenelm
Post by Kenelm » Wed Oct 10, 2018 10:31 am
I'd be happy to send you the XOR for Schools disc if you want to try, but I'm not sure it's worth it, because the disc surface shows signs of serious damage.
PM sent.
Post by danielj » Wed Oct 10, 2018 11:03 am
Hi Ken, if it's properly toasted then I'm not going to fair any better I suspect. I'd also prefer not to put disintegrating discs in my drive :D Can you do a picture of the damage?
Post by klintworth » Wed Oct 10, 2018 1:40 pm
Pipistrelle manual
Pipistrelle.pdf
(1.51 MiB) Downloaded 23 times
Kenelm
Post by Kenelm » Wed Oct 10, 2018 10:57 pm
There is a line right around the surface of the disc about 5mm from the outer edge where the surface has got scraped. When I first tried the disc the drive made a horrible grinding sound and I immediately took it out and gave it a good clean with alcohol solution and a cotton bud. I then tried again, but couldn't recover much more than the file table, and unfortunately when I took it out the scraping damage had got worse. I would be reluctant to put it in my drive again.
Pipistrelle manual
Pipistrelle.pdf
Thanks! :D
Kenelm
Post by Kenelm » Wed Oct 10, 2018 11:17 pm
Chemistry in Action: Iron & Steel
Granada Television/GSN Educational Software
Iron and Steel.ssd
(99.5 KiB) Downloaded 22 times
Kenelm
Post by Kenelm » Thu Oct 11, 2018 12:05 am
Kidnap!
NCET/MESU Software
Master 128 only. Requires disc write access.
Subject: French
The premise is that your friend has been kidnapped. In the first part, you give descriptions of your friend and the kidnapper to the police. The second part is a bit confusing without access to the documentation, but as far as I can work out, you first look at possible sightings and identify the correct one from descriptions given. You then try to find your friend and the kidnapper ("le suspect") by entering the names of French towns from clues given. Finally there is a database of the towns included.
The function keys can be used to enter accented characters.
Kidnap.ssd
(61 KiB) Downloaded 20 times
