Today I received.....
Re: Today I received.....
Post by 1024MAK » Sun Aug 12, 2018 10:34 am
IanS wrote:
Fri Aug 10, 2018 11:59 pm
myelin wrote:
Fri Aug 10, 2018 11:37 pm
Nice work! This is the latest version of your own design, I take it?
Just a small evolution, 374 buffers replaced with 574's to make the layout easier. Swapped the 245's around so I can use R/W signal from podule bus rather than having to invert it, saving a GAL pin. Clock pins for the latches are combined saving me another pin on thr GAL, together that made enough room for a 3 bit page latch for the ROM in the GAL, so removed the seperate page latch chip. Still uses the same ZIDEFS software.
Nice bit of rationalisation =D>
kieranhj
Post by kieranhj » Sun Aug 12, 2018 7:40 pm
I never find any Acorn stuff in the charity shops (nor any retro computer equipment at all, frankly) but I did bag this beauty today for the measily sum of £10 - has to be the bargain of the year, surely?!
Herman Miller Aeron Chair
I was a bit dusty but in fantastic nick and has cleaned up nicely - the mesh is all intact and the mechanism works. Lovely for the office!
Lardo Boffin
Post by Lardo Boffin » Tue Aug 21, 2018 10:19 am
An ABR thanks Dave! Now I have Beebug C permanently available without having to load it into sideways RAM each time (it was very much a 1st world problem...).
Adventure Language on GitHub
Atom, issue 5
Elk
Post by Elminster » Tue Aug 28, 2018 8:55 pm
I like these cheap solder holder so much I now have 3, just a few quid from ebay, bargain. And work better than a lot of the more expensive branded ones.
mattdy4
Post by mattdy4 » Thu Sep 06, 2018 9:41 am
Wow! They really are beautiful chairs too
mattdy4
Post by mattdy4 » Thu Sep 06, 2018 9:49 am
Picked up a boxed Master and Cub monitor today locally. Been after either for a while at none-eBay prices and picked up both with boxes and manuals. Master is a bit yellow and needs recap but still... Even got some sealed 5.25" floppies chucked in
Once that is done time to upgrade it. Hope to get some inspiration for that down at ABUG on Sat
kieranhj
Post by kieranhj » Thu Sep 06, 2018 10:32 am
I forgot to post this last week - I won a 1990's JAMMA arcade cabinet on eBay justified as a birthday present to myself:
JAMMA cab
It needs a bit of TLC but has a sweet Hantarex CRT monitor in there with no screen burn and nice straight edges to the image. It looks a bit sad in the utility room for the moment but will find somewhere in the house to fit it! Next I need to work out what I'm going to put in it - currently has a 19-in-1 horizontal multigame JAMMA board but leaning towards a Raspberry PI with JAMMA interface for the 15KHz monitor.
Soruk
Post by Soruk » Thu Sep 06, 2018 1:25 pm
Got to second this. Sitting on one right now at work.
jonb
Post by jonb » Thu Sep 06, 2018 1:58 pm
I read that they were never designed as orthopaedic chairs, yet they're the most comfy desk char I have ever used, and I have a pair of fused vertebrae in my lower back so I'm quite sensitive to desk furniture.
SimonSideburns
Post by SimonSideburns » Thu Sep 06, 2018 9:38 pm
For 50p in a charity shop today I picked up a 12" CD Video disc. Not to be confused with Video Cd or other similarly named and wholly incompatible formats, e.g. LaserDisc. I don't believe the charity chop even knew nor cared what it was they had.
I've never seen one before, and probably won't ever see another one in the wild. I can find very basic information about the format via searching online, so I was wondering if any of you had heard of or knew anything further about these.
The one thing I have found out is that it is likely suffering from rot due to the way they were manufactured, so will likely not play even if I can find a player for the CD Video format.
I'll post a picture if anyone is curious.
Post by davidb » Thu Sep 06, 2018 9:50 pm
Is it the same format featured in this Techmoan video?
SimonSideburns
Post by SimonSideburns » Thu Sep 06, 2018 10:08 pm
Yes. Exactly the same, with exactly the same rot as described in that youtube video.
Post by Kazzie » Fri Sep 07, 2018 6:05 pm
Two tempremental AND01 floppy drives sent to me by Lardo Boffin. They'll be prodded and poked over the next week to try to work out what's up with them.
RiscPC 600 under repair
Multiwizard
Post by Multiwizard » Sun Sep 09, 2018 8:08 pm
I just picked up this... :-D
It also contained a little shiny surprise... :o
Greetings, Wim...
Commie_User
Post by Commie_User » Mon Sep 10, 2018 5:57 pm
A wonderful haul of Archi-ama there! Bit sad too, considering so many expensive pride and joys ended up in landfills a handful of years after they were bought.
I'm glad they did to get to this point but computers in the 80s and 90s came and went from usefulness so very quickly.
Post by sydney » Mon Sep 10, 2018 6:24 pm
A Canon MF5750 laser printer with spare toner cartridge for only £5.
Bargain!
Post by RobC » Mon Sep 10, 2018 6:32 pm
Not sure I agree with this. I've found use for an Archimedes and/or RiscPC pretty much constantly since I first got one in 1990. I still find my A540 (released 1990) useful on a regular basis and, in some cases (e.g. recently creating a banner), it still seems superior to my brand new Windows laptop.
I got back into Beebs back in 2005 because I wanted to learn about microcontrollers for work. It seemed far easier (and less risky!) to interface them to a £5 second-hand Beeb than to my £1000 PC.
Modern computers are obviously vastly more powerful in many ways but much of that power just isn't needed for applications like basic word processing. So 90s (and 80s) machines can still be very useful :)
Commie_User
Post by Commie_User » Wed Sep 12, 2018 10:48 pm
I rather meant usefulness for the general public, rather than we collectors. We always have some specialist use the new machines sometimes can't reach.
Lardo Boffin
Post by Lardo Boffin » Thu Sep 13, 2018 11:46 am
A whole box of Econet goodness!
Expect a noob econet set up thread to follow soon as I have no idea what I am doing.... :D
Atom, issue 5
Elk
Post by flaxcottage » Thu Sep 13, 2018 1:25 pm
A Econet is great fun. Enjoy. :D
Lardo Boffin
Post by Lardo Boffin » Thu Sep 13, 2018 1:32 pm
I have vague memories from school!
Atom, issue 5
Elk
cmorley
Post by cmorley » Thu Sep 13, 2018 5:38 pm
8-bit job lot from eBay I collected today. A super nice chap SE of MK was pleased to save this stuff which was otherwise destined for the tip. He offered me the the teletext adapter too FOC in case I can find a home for it :)
Master (PSU caps have gone) + twin floppies. The master will be repairable and hopefully the floppy drives work/easy fix too:
Monochrome monitor. I have no use for this so will offer it FOC to forum members. Collection from Oxford, ABUG or I can post. I'll clean it and put a For Sale thread up - please don't post here.:
Back of monitor:
Oooo :) The disks are there too...
Morley teletext adapter - the disk is in there too. Also will be FOC to a forum member. The mouse is in there but the connector got lost at some point in the last 30 years:
PM me or post to the For Sale forum thread I'll start for the bits I'm just going to shift on. I'll go through the disks and manuals and see what there is too. Good haul :)
AndyMc1280
Post by AndyMc1280 » Fri Sep 14, 2018 1:11 pm
Agreement to be "Given" a 33mhz Alpha A5000 +£250
In exchange for an Atari Falcon 030 @14 Mhz with Fpu and internal CF etc...
From a friend who is an atari guy, like I am an Arc nut.
He never uses the A5000 and I never use the Falcon so fair doos.
Neither of us wanted to sell out. Yes I could have held on to the falcon for years and years and put it on ebay.
BUT... an 8MB RO3.1 machine is nice too. It is currently 4MB but I have an upgrade from my previous A5000, plus I have network cards etc... so it can go on my network and talk to the R260 in the back room ROFL.
Pretty happy tbh. Both machines going to good new homes next month.
iamaran
Post by iamaran » Fri Sep 14, 2018 1:15 pm
Today I collected an Acorn Electron and some related miscellany. I always said that emulators were fine for me, I don’t have the space, etc. etc. But this was free, so…
I had a Model B back in the day so I don’t know much about the Elk. Won’t be able to switch it on until later this evening.
jonb
Post by jonb » Fri Sep 14, 2018 5:00 pm
Well done Andy. Better that these machines stay in the hands of enthusiasts than collect dust in a "collection". :)
Post by Elminster » Fri Sep 14, 2018 9:55 pm
Today I received the best cheap Signal Gen my budget would stretch to ...
Post by tricky » Sat Sep 15, 2018 8:16 am
I was tempted to bid on that one, but glad I didn't.
You know what would make it look less sad, if you decorated the room as an arcade and to make it less lonely, get it a friend ;)
roganjosh
Post by roganjosh » Sat Sep 15, 2018 9:57 am
Very useful pieces of kit. One slight problem to be aware of with a lot of these things is that you can get AC line voltages on the outside of the BNC connectors because of the floating switch mode power supplies used. That can cause a leakage current reportedly sufficient to blow FETs. I gather that the JDS 6600 is powered by an external brick so you might want to replace that power supply with a linear one at some stage. Alternatively you could always ground the BNC connectors (just as long as the circuit under test doesn't mind being grounded).
I have the FY 6600. I wanted the probe to be able to float so the first thing I did was to replace its internal switch mode supply with a simple linear internal one of my own design. I also isolated its USB connection using a magnetic coupler. It brought home how difficult it can be these days to get an old-fashioned transformer.
Alan
Post by Elminster » Sat Sep 15, 2018 10:08 am
I followed fy6600 stuff on eevblog forum, but in the end went for the jds6600 in the end as it seemed easier to sort. Yes externally supplied.
Building power supplies is on my todo list.
I wanted a usable one before saving up for an expensive one, if I don’t use it as much as I thought I have save myself at least £400
Return to “general”
