Electron overheating video
Re: Electron overheating video
Post by Coeus »
Is the PSU inside the main case (sorry don't have an Electron)? If so, drawing more current from the PSU may not be causing problems with voltage sag, just causing the PSU to generate more heat and contribute to the inside the case temperature.
Post by daveejhitchins »
Coeus wrote:
Sun Jul 22, 2018 11:18 am
Yes, the PSU is inside the Electrons case with the AC brick outside. So could still be a heat related issue. I'm sure the DC lead, from the PSU is long enough to allow it to sit outside of the case - may be worth a go?
Post by Elminster »
The issue is more getting it to flicker on demand, and then keep it going while measuring anything. Oddly yesterday while testing the RGB hdmi it didn’t do it at all, even though spending a couple of hours messing with games on MGC.
Won’t have much time for testing for a couple of weeks, but I am sure it hasn’t cured itself, so will carry on diags soon.
MartinB
Post by MartinB »
Duncan wrote:Now if Martin get the i2c clock module inside he Electron that has a built in temperature sensor on the board
He already has! If you look about half-way down Page 4 of the ‘I2C 4 U’ thread where the rom downloads are, you’ll see there’s an Electron version of the I2C rom ready and waiting for all your sensing needs. Can’t believe you haven’t done it already! There’s even a nice ready-made BASIC temperature-over-time graphing program in my user-guide that’s just perfect for your requirements and you already have the RTC/Temperatue module... :D
(You’ll of course need a Plus 1 and then either an EUP or an AP5 for a User Port.)
(( Actually, I’m sure you already know all of the above because you must have tested your AP5 with the Elk I2C rom. Anyways, just sit the RTC module loose on the ULA or wherever in a bit of cling film to avoid shorts and pass the cable out wherever you can make least gap. I’ve done it fine on Beebs for monitoring the 6502 operating temperature as you’ll see in one of the videos.))
Post by hoglet »
Elminster wrote:
Sun Jul 22, 2018 1:25 pm
Oddl6 yesterday while testing the RGB hdmi it didn’t do it at all, even though spending a couple of hours messing with games on MGC.
That could be a big clue..... Not exactly sure what it means, but try to test if it's really the case.
Post by Elminster »
Many clues, just not consistant clues. I did leave it running on composite for sometime as well and it didn’t flicker. And it has flicker on RGB before. Never tested uhf. And it has certain had issue with MGC plugged in before.
It may have been because I was wearing my lucky underwear.
Post by Elminster »
MartinB wrote:
Sun Jul 22, 2018 3:39 pm
I was waiting for the professional finish not requiring clingfilm :) although could use it to drive a fan when the reach x degrees.
I also have, as well as the multimeter temp sensor, a logit with loads of temp sensors.
vanekp
Post by vanekp »
I also found the ULA runs far to warm for my liking so put a heatsink and fan on mine to keep it cool.
Peter.
Post by Elminster »
I have a load of raspberry pi heatsink that have never be used. But don’t want to stick until I am sure. I thin’ I have some small fan but I general don’t use them as very noisy. I usually prefer to use large fans but be hard to get one of them inside.
