Elminster wrote: ↑Sun Sep 02, 2018 10:57 pm
If all the 'enhanced' features of videonula were hacked out, could you lose any of the hardware/reduce costs and would it be 100% backwards compatiable.
I think it would probably only reduce the component count slightly as you would only really lose the 12 resistors from the DACs. It may be possible to use a slightly cheaper CPLD - I chose the EPM570 as I wanted space for the extra palette so didn't consider smaller designs. If the original ULA fits into something like the EPM240, it would knock a few pounds off the price.
However, about half the cost is in the time taken to build, test, clean and re-test the boards. This still takes a fair bit of time per board even though I've gradually got quicker at the soldering part!
On compatibility, it's possible to put the VideoNuLA in a fully-compatible mode by issuing *VNDISABLE ROM command (or by a simple poke if you don't have the ROM installed). This effectively tells the hardware to ignore writes to the additional registers so it behaves like the original ULA.
What I am sort of saying is how hard/cost would it be to produce a VULA replacement as opposed to the endhance version.
It wouldn't be that hard but I'm not sure there'd be enough of a price differential to make it worthwhile. If it's something that enough people are interested in, I'd be happy to look into it in more detail.
Not sure if my rambling make sense, made sense in my head.
Makes perfect sense
