30th Anniversary BBC and Electron Collection
crj
Re: 30th Anniversary BBC and Electron Collection
Post by crj » Sat Nov 04, 2017 3:42 am
Michael Brown wrote: Copter by Eben Upton
That would presumably be the Eben Upton!
Michael Brown
Post by Michael Brown » Fri Nov 10, 2017 10:36 am
:evil: Post removed
Michael Brown
Post by Michael Brown » Wed Nov 22, 2017 8:14 am
:D Post removed
Michael Brown
Post by Michael Brown » Fri Nov 24, 2017 5:43 pm
:lol: Post removed
Michael Brown
Post by Michael Brown » Mon Dec 04, 2017 12:03 pm
Created in December 2017... here is Games Disc 118.
Disc118.zip
(112.37 KiB) Downloaded 39 times
The disc is called Disc118.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
The 18 games on this disc include...
Sqwhere? from The Micro User (2.06).
World War I (STD) from M. C. Lothlorien.
Connect Four from Your Computer (4.03).
Road Racer from The Micro User (2.04).
Pontoon from Beebug (3.04).
Planetfall (2P) from ASP Software.
Christmas Lights (Christmas Crackers) from The Micro User.
Aces High from Beebug (8.04).
Othello from Your Computer (3.09).
Christmas Box from The Micro User (4.10).
Know Your Own Psi-Q (STD) from Mirrorsoft (Ivan Berg).
767 Advanced Flight Simulator from Flightdeck Software.
Simon (Games Compendium B1) from Salamander Software.
Santa And The Snowman (2P) from The Micro User (5.10).
The White Barrows from ASP Software.
Reversi from Beebug (2.06).
Snow Plough! (Christmas Crackers) from The Micro User.
Paras (AKA Paranoids) from Acorn User (#026).
NOTE: World War I has had the Shift Lock key changed to Caps Lock in order to work with a QWERTY keyboard. It also allows you to save your score/position to disc.
Also, Know Your Own Psi-Q allows you to save your data to disc.
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This only works on 767 Advanced Flight Simulator.
All original filenames have been kept where possible, but some have been changed where they conflict with the limitations of the Disc Filing System. Copy protection routines have been removed.
This disc has also been checked for *KEY related issues and is OK.
Regards,
Mick.
Last edited by Michael Brown on Fri Mar 20, 2020 12:44 pm, edited 13 times in total.
Michael Brown
Post by Michael Brown » Thu Dec 07, 2017 1:52 pm
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 08, 2017 9:28 am
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 08, 2017 9:40 am
:D Post removed.
Michael Brown
Post by Michael Brown » Sun Dec 17, 2017 8:34 am
:D Post removed
Michael Brown
Post by Michael Brown » Thu Dec 21, 2017 8:44 am
:D Post removed
Michael Brown
Post by Michael Brown » Thu Dec 21, 2017 8:50 am
:D Post removed
Michael Brown
Post by Michael Brown » Thu Dec 21, 2017 2:30 pm
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 22, 2017 7:57 am
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 22, 2017 6:05 pm
:D Post removed
Michael Brown
Post by Michael Brown » Thu Dec 28, 2017 4:52 pm
:D Post removed
Michael Brown
Post by Michael Brown » Thu Dec 28, 2017 4:59 pm
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 29, 2017 7:17 am
:D Post removed
Michael Brown
Post by Michael Brown » Fri Dec 29, 2017 12:41 pm
:D Post removed
Michael Brown
Post by Michael Brown » Sat Dec 30, 2017 9:04 am
:D Post removed
Michael Brown
Post by Michael Brown » Sat Dec 30, 2017 9:07 am
:D Post removed
Michael Brown
Post by Michael Brown » Mon Jan 01, 2018 9:20 am
Created in January 2018... here is Games Disc 119.
Disc119.zip
(155.58 KiB) Downloaded 37 times
The disc is called Disc119.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
4-Site from The Micro User(4.03).
Rat Race (RAM) from STL.
Killer Dice from Beebug (2.07).
3D Noughts And Crosses (Compox) from The Micro User (3.05).
Backgammon from Your Computer (4.09).
Curly! (2P) from Beebug (9.06).
Jackpot! from The Micro User (3.06).
Blackjack from Your Computer (5.03).
Colour-Cube (Games Of Deduction) from Clemoes Software.
Royal Wedding from The Micro User (4.05).
Apocalypse (2P) (STD) (D) from Red Shift Ltd.
Emperor from Molimerx Limited.
Duel (2P) from The Micro User (2.09).
Twiddle from Beebug (8.05).
Entrapment (2P) from Computer & Video Games.
Fred The Needle by Jubbernaut.
Reversi from BBC PD (Games #5).
Orbit from Practical Computing (6.08).
NOTE: Rat Race is loaded from disc but is then stored as a ROM image (so you must have a spare bank of Sideways RAM available for it to work).
Also, Apocalypse is the tape version but has been amended to work from disc and you can save your score/position to disc. It resets the disc drive (so requires *DTRAP on a real BBC Micro with a Datacentre fitted).
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This only works on Apocalypse.
Regards,
Mick.
Last edited by Michael Brown on Fri Mar 20, 2020 12:47 pm, edited 23 times in total.
billcarr2005
Post by billcarr2005 » Mon Jan 01, 2018 1:23 pm
Is Apocalypse posted on the disk as an alternative version?
You're aware that http://www.stairwaytohell.com/bbc/archi ... ommand.zip is the same game, but a native disk version which requires no amendments and has more scenarios to play...
Michael Brown
Post by Michael Brown » Mon Jan 01, 2018 4:26 pm
Hi Bill,
The version of Apocalypse I have included is the Red Shift tape copy, but I have borrowed the disc fix from the larger Command Software version and added that to it.
I have tried to create a version that is as close to the tape version as possible.
regards,
Mick.
Michael Brown
Post by Michael Brown » Thu Jan 04, 2018 6:31 pm
:D Post removed
Michael Brown
Post by Michael Brown » Fri Jan 05, 2018 1:21 pm
:D Post removed
Post by tricky » Fri Jan 05, 2018 1:46 pm
I don't know where you find the enthusiasm for this, but I'm glad you do. =D>
Michael Brown
Post by Michael Brown » Fri Jan 12, 2018 4:50 pm
:D Post removed
Michael Brown
Post by Michael Brown » Thu Jan 18, 2018 5:23 pm
:D Post removed
Michael Brown
Post by Michael Brown » Mon Jan 22, 2018 7:55 am
:D Post removed
Last edited by Michael Brown on Mon Apr 30, 2018 1:29 pm, edited 2 times in total.
Michael Brown
Post by Michael Brown » Thu Feb 01, 2018 3:54 pm
Created in February 2018... here is Games Disc 120.
Disc120.zip
(115.27 KiB) Downloaded 36 times
The disc is called Disc120.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
Golf from The Micro User (2.02).
Shuzzle from Beebug (9.07).
Star-Trek from Your Computer 3.07).
Hunt The Wampus from The Micro User (2.08).
Roundheads And Cavaliers (STD) from M. C. Lothlorien.
The Enchanted Castle from Computer & Video Games.
The Dodeca Game from Beebug (7.10).
Blackjack (2P) from The Micro User (1.09).
Darts from A & B Computing (3.03).
Invasion (AKA Invaders) from Acorn Programs (Vol.1).
Chinese Chess from The Micro User (6.03).
Aircraft Landing Simulator from PCW Software.
Haggis-Bash from Computer & Video Games.
Solitaire from The Micro User (3.08).
Midway from Design People Software.
Orchard Wall from Acorn Programs (Vol.4).
Treasure Trail from The Micro User (6.06).
Cockpit from A & B Computing (1.03).
NOTE: Round Heads and Cavaliers allows you to save your score/position to disc. It has also had the Shift Lock key changed to Caps Lock in order to work with a QWERTY keyboard.
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This works on Blackjack, Midway and Treasure Trail.
Regards,
Mick.
Last edited by Michael Brown on Fri Mar 20, 2020 12:49 pm, edited 15 times in total.
