BBC Micro: writes to ROM?
crj
Post by crj » Wed Dec 06, 2017 5:23 pm
In an interesting discussion away from the forums, somebody pointed out an interesting thing to me: the processor's R/~W line features nowhere in the driving of ~CE or ~OE to the ROMs. I've checked this on the schematic and it appears to be true.
Doesn't that mean that there's a bus clash every time an attempt is made to write anywhere between &8000 and &FBFF? That seems like both an unfortunate way to mistreat the hardware and a commonplace occurrence.
Also, it leaves me trying to make sense of my recollection that with the original Solidisk sideways RAM, the one that mounted in the rightmost ROM socket and ran up the edge of the case, you could write to it by writing to &8000-&BFFF regardless of which bank was selected. In particular, you could load a sideways ROM image simply by doing *LOAD without any help from the filing system implementation. Am I misremembering? If not, how on earth did that work if the filing system ROM would have been driving the bus during stores as well as loads?
I feel like I'm missing something, here.
Re: BBC Micro: writes to ROM?
Post by hoglet » Wed Dec 06, 2017 5:37 pm
crj wrote: Doesn't that mean that there's a bus clash every time an attempt is made to write anywhere between &8000 and &FBFF? That seems like both an unfortunate way to mistreat the hardware and a commonplace occurrence.
Yes there is indeed a bus clash in a Model B when accessing the language ROM &8000-&BFFF. Not sure about the OS ROM.
If a ROM board is fitted, then it depends I guess on the design of the ROM board.
I also found (through the use of the 6502 bus analyzer), the Electron apparently suffer the same with slots 10 and 11(Basic).
Post by 1024MAK » Wed Dec 06, 2017 6:01 pm
Despite what the various text books say, it not uncommon for there to be no read/write control in ROM control circuits. The BBC is indeed a computer that is like this. So yes, a write will result in a bus clash for the duration of the memory bus cycle.
crj
Post by crj » Wed Dec 06, 2017 6:15 pm
So... what limits the current that flows if a ROM drives 1 and the CPU drives 0 or vice-versa?
Is that current sustainable? And is the limit by luck or by design?
Post by 1024MAK » Wed Dec 06, 2017 7:24 pm
The combined output impedance of the two chips that are trying to both drive the bus limits the current. Whichever has the higher drive (lowest output impedance) will override the weaker chip. Modern CMOS memory chips are likely to win against an NMOS CPU for example.
But keep in mind that most chips can only output up to around 25mA into a short circuit, or sink a similar amount. And that the bus contention only lasts for one memory cycle. As long as there is only occasional bus clashes, the hardware should survive. However, IMHO, it is a bit of poor design. But the upside, is that it makes sideways RAM and EEPROM/flash ROM relatively easy to fit and use.
Post by tricky » Wed Dec 06, 2017 10:26 pm
crj wrote:...
That sideways RAM used the low three bits of the user port to select which "socket" got written to, so setting write to a sideways RAM "just worked" as the DFS tried to overwrite itself.
Really upsets the various MMC options though! (SmartSPI allows you to connect to lines 01, 23, 45 or 67, which helps).
crj
Post by crj » Thu Dec 07, 2017 12:54 am
1024MAK wrote:But keep in mind that most chips can only output up to around 25mA into a short circuit, or sink a similar amount.
Hmm. I may have misconstrued.
I thought those limits meant the chip would break if you ever tried to source/sink more, not that it would current-limit!
Post by 1024MAK » Thu Dec 07, 2017 3:49 pm
Well, strangely enough, the various manufacturers specify the maximum current, but don't say what the consequences would be if you exceed the figure. However, some manufacturers also give the expected voltage at a specified current. From this, it is clear that there is a low, but significant impedance in the chips output drivers. Shorting out an output will result in increased localised heating in that part of the chip, but as the short circuit is only for a very short duration, for the most part, it does not cause problems.
Having said that, IMHO it's something that should be avoided, so I include read/write control in my own designs. Further, it is possible that a continuous (or long duration) short circuit (to the supply rail or to ground) will cause damage. The quickest way to kill a chip remains connecting a high voltage (greater than VCC+0.7V) or a negative voltage (less than -0.7V) to a chip pin (unless the chip is designed with this in mind, like some EPROM chip inputs).
It should also be noted that this bus contention problem is not restricted to ROMs. It also affects some (often, but not always low cost) I/O input devices, for example, the First Byte Digital Joystick interface has no connection to the R/W line. Some joystick interfaces for the ZX Spectrum also have no /RD control line connections.
flynnjs
Post by flynnjs » Thu Dec 07, 2017 5:46 pm
As a rule of thumb, unless a datasheet says that an output can survive a short then I would avoid it.
As you draw more current the pin will gradually "let go" and eventually the voltage will no longer
be within the valid voltage range for the connection standard (TTL/CMOS etc). Drawing yet more
current will result either in just "wrong level detected", gradual degradation of drive ability or
potentially immediate catastrophic failure.
As Mark says, driving a line above or below the supply rails is more likely to cause major damage
but for many FPGAs the precise characterics of amount and duration of excursion vs expected
lifetime is published by the manufacturer as it is a "fact" that many high speed signals ring and
to over/undershoot. In such systems it is therefore implicit that the circuit has a finite lifetime
although in conservative designs this may be decades of power on and less conservate designs
for disposible kit it could be only hours.
Post by Kazzie » Fri Dec 08, 2017 12:32 pm
crj wrote:Also, it leaves me trying to make sense of my recollection that with the original Solidisk sideways RAM, the one that mounted in the rightmost ROM socket and ran up the edge of the case, you could write to it by writing to &8000-&BFFF regardless of which bank was selected. In particular, you could load a sideways ROM image simply by doing *LOAD without any help from the filing system implementation. Am I misremembering? If not, how on earth did that work if the filing system ROM would have been driving the bus during stores as well as loads?
As another data point, the ATPL Sidewise does the same. Quoting from the manual:
As supplied, SIDEWISE will accept up to 16K RAM in the two special sockets 15a and 15b. The RAM is written to by any write instruction to the SIDEWAYS ROM area, addresses in the range 8000 - BFFF hex. The write access will override the currently selected SIDEWAYS ROM causing data to be stored on the RAM chips. This data may then only be read by selecting ROM NUMBER 15 in the normal way. This allows a FILING SYSTEM ROM, which may be itself a SIDEWAYS ROM, to control the loading of a file to this RAM area, without affecting itself.
A not altogether useful example might be the BASIC line
FORX=&8000 TO &BFFF:?X=?X:NEXT
This will make a copy of the BASIC ROM in the SIDEWAYS RAM.
crj
Post by crj » Fri Dec 08, 2017 3:08 pm
Ah, the ATPL Sidewise.
That was a solid bit of kit, what I selected for my own BBC B at home. Which sadly got burgled so I no longer have it. The silver lining was BBC Master being launched between the burglary and the insurance payout!
