BBC BASIC & Introducing BBC BASIC [Remastered PDFs]
avoid work duplication! collaborate on the archival of acorn literature!
dv8
Post by dv8 »
Attached are two programming books: BBC BASIC and Introducing BBC BASIC, both by R.B. Coats.
'Introducing' is pretty much a cut-down version of the larger book. It does, however, have some extra content in the chapters on graphics, sound and procedures. It also includes an additional set of questions and answers.
An SSD containing the listings is also provided for each book.
BBC_BASIC.zip
(1.28 MiB) Downloaded 217 times
Introducing_BBC_BASIC.zip
(283.73 KiB) Downloaded 195 times
Other remastered books you may be interested in:
BBC Micro User Guide (Model B and B+ editions)
dv8
Re: Books: BBC BASIC & Introducing BBC BASIC
Post by dv8 »
Thanks!
Yes, I scanned them in. Then they were put through OCR and re-created in a DTP package.
Post by lurkio »
dv8 wrote:Thanks! Yes, I scanned them in. Then they were put through OCR and re-created in a DTP package.
:shock: =D> =D>
Which OCR program did you use?
dv8
Post by dv8 »
lurkio wrote:Which OCR program did you use?
Nuance OmniPage.
The whole sordid story of how these books are created is in the Assembly Language Programming book thread.
Post by daveejhitchins »
dv8 wrote:The whole sordid story of how these books are created is in the Assembly Language Programming book thread.
Wow . . . Just gone back and read you procedure =D> Well done and, please, keep up the good work . . . You must have an abundance of patience - again =D>
dv8
Post by dv8 »
daveejhitchins wrote:Well done and, please, keep up the good work
Thanks! Several other books are already in production and will be posted soon :-)
and wrote:You must have an abundance of patience
It's not as bad as I probably made it sound! Usually I just work on them a bit at a time while watching TV or listening to podcasts. That way it doesn't feel like too much of a slog.
Return to “scanning of books, magazines, ads and letters”
