Problem Solver by Shibumi
Post by Pernod » Sat Sep 09, 2017 8:31 pm
Not much was released for the Master 512 but I see we have documentation for this Problem Solver at http://stardot.org.uk/mirrors/www.bbcdo ... &Itemid=63
Anyone have an image of the disc?
billcarr2005
Re: Problem Solver by Shibumi
Post by billcarr2005 » Sun Sep 10, 2017 8:20 pm
I''ve got Problem Solver 1.0 and 2.0, along with a Shibumi disk titled Rat Driver.
I'll have to hook my datacentre up to my BBC Master, but will attempt to get an image from the disks asap, corruption and / or protection permitting!
Post by Pernod » Mon Sep 11, 2017 12:45 am
billcarr2005 wrote:I've got Problem Solver 1.0 and 2.0, along with a Shibumi disk titled Rat Driver.
Never heard of Rat Driver and can't find any reference to it so am curious to see what it is.
I doubt Problem Solver would be protected but it will be in some kind of DOS format, maybe Acorn 800K DOS. Could you also scan/photo the disc labels for reference. Thanks.
billcarr2005
Post by billcarr2005 » Sun Sep 24, 2017 3:24 pm
I've managed to catalogue all 3 disks using some software called BAKSOFT DOSCOPY, which would allow me to copy the files from the disk to a BBC disk.
This software won't let me image the disk though, as far as i can see. It's identified as an Acorn 800K disk though.
Is there any software that runs on a BBC Master that will happily copy this over to USB?
Tried Disk2USB but couldn't get it working, perhaps because it expects native BBC formats?
Post by Pernod » Mon Sep 25, 2017 8:22 am
I guess the best way to image these is with Omniflop on a PC, I don't have any suitable hardware though.
billcarr2005
Post by billcarr2005 » Sun Jan 14, 2018 12:28 pm
Pernod wrote:Anyone have an image of the disc?
Eventually imaged!
Finally cobbled together some code that managed to happily (hopefully) load the code on a BBC Master and then WRF to the Datacentre in the correct way.
Problem Solver 2.0 and Rat Driver 1.0 are (presumably) standard 80 track, 800KB disks
Side 0 - 1
Track 0 - 79
Sector 1 - 5 (1024 bytes each)
Problem Solver 1.0 had errors when attempting to read Side 0, Track 1, Sectors 1 to 5 ... maybe it's unformatted?
The imaging program just wrote the previous good sector.
They appear to load up correctly on B-Em 2.2
Didn't have any documentation, just the disks.
Rat Driver 1.0.zip
Rat Driver 1.0
(1.76 KiB) Downloaded 35 times
Problem Solver 2.0.zip
Problem Solver 2.0
(5.59 KiB) Downloaded 39 times
Problem Solver 1.0.zip
Problem Solver 1.0
(6.19 KiB) Downloaded 36 times
Post by Pernod » Sun Jan 14, 2018 10:34 pm
billcarr2005 wrote:Problem Solver 1.0 had errors when attempting to read Side 0, Track 1, Sectors 1 to 5 ... maybe it's unformatted?
Thanks for those. It looks like Problem Solver 1.0 is corrupt though, causes errors when running some of the exe's.
