Greeting fellow Acrons
Chompalot
Post by Chompalot » Sun Jun 25, 2017 12:52 pm
I've recently bought a BBC B of Ebay, to revisit my youth playing Elite.
After replacing the caps and installing a retroclinic datacentre I'm happily probing the universe, albeit gently at the moment. I dont seem to have got the hang of saving games at the moment so it's groundhog version of Elite..... I've found the @ key but it doesn't seem to save the game, or is it a loading issue?
Also the Beeb seems to have some issues starting up, with the startup screen apearing and disapearing, although it seems to accept inputs from the keyboard whilst the screen is blank, so a video issue. I'm currently using the RGB output to a scart connector again bought off Ebay, to a 40 inch 4K sony TV :D
Simon UK, somewhere near Lave Station, just outside Derby
Re: Greeting fellow Acrons
Post by sydney » Sun Jun 25, 2017 1:51 pm
Hi there.
In elite you can only save when docked.
Your video issues could be caused by your TV being too modern and not liking the signal from the beeb. Have you tried another TV?
Post by Elminster » Sun Jun 25, 2017 1:54 pm
Welcome.
Yes I get flicker with Electrons which I believe puts out lower signal strength. Beeb b so so, masters are rock steady.
Pablos544
Post by Pablos544 » Sun Jun 25, 2017 1:58 pm
or invest in a cheap SCART TV and buy one of these
http://www.ebay.co.uk/itm/Acorn-BBC-B-M ... SwpDdVcWEf
retro computer shack are not bad. had a pretty good experience 8)
Post by Elminster » Sun Jun 25, 2017 2:21 pm
Pablos544 wrote:or invest in a cheap SCART TV and buy one of these
I believe chompalot said he is using an RGB to scary cable from eBay. Although make/model wasn't mentioned.
Multiwizard
Post by Multiwizard » Sun Jun 25, 2017 3:01 pm
Post by DutchAcorn » Sun Jun 25, 2017 5:07 pm
Hi Simon, good luck with Elite and enjoy the forum! :D
Post by tricky » Sun Jun 25, 2017 6:00 pm
Welcome to the forum, there is a thread around here somewhere about attempts to become Elite.
Post by davidb » Sun Jun 25, 2017 6:27 pm
Welcome! :D
Post by roland » Sun Jun 25, 2017 7:40 pm
Welcome to this forum, enjoy your visits here.
Greetings from the south of the Netherlands,
Roland
256K + 6502 Inside
Chompalot
Post by Chompalot » Sun Jun 25, 2017 8:31 pm
Hi all and thanks for the welcome,
Sydney, yup I'd figured that out after stabbing the button multiple times in flight. I've got a slightly older LG TV but it's still a smart 47 inch HDTV, not quite as new as the Sony, but not in the right place to use :(
Elminster - once it's settled down theres no drop out and alls fine, just a startup issue.
Pablos544, yup thats exactly the one I bought Yay.
Elminster, yup Its a scary cable indeed.
Hi Multiwizard and thanks
Hi Dutch Acorn, I've managed to travel from one space station but not managed to get back :( and still not saved, I'm trying to figure out where the game save goes, it a sks for a disc and I've said 5 as thats supposed to be the USB, but when you doe the catalgue option 5 doesn't seem to exist. I may have to ask retroclinic's advice.
Hi Tricky thanks for the pointer I'll have to have a read of that one, but I'm still having dificulty remembering all the buttons to press LOL.
Hi davidb and thanks
Hi roland and Greetings
Post by danielj » Sun Jun 25, 2017 8:59 pm
Hullo there! :)
Post by Elminster » Sun Jun 25, 2017 9:26 pm
Don't think saving to USB will work. You probably need to at least switch on disk trap and save to the compac flash on a DC. Not that I have tried to save Elite save games on one. Others will know better.
Reason: missing bracket on [/quote] tag
Post by flaxcottage » Mon Jun 26, 2017 12:05 am
Welcome :D
Chompalot
Post by Chompalot » Mon Jun 26, 2017 8:53 pm
Ta Flaxcottage
I've no idea what disc trap is or how to turn it on, so more reading of the manual required. I have bought a compact flash card off ebay, but I'm waiting for the inteface board to arrive from China. I saw an example on RetroClinics photos and though that looks line a good idea for local storage.
I found a hint about game saves - at viewtopic.php?t=3414
"Saving your game in Elite and then forgetting to write the disk back to the stick is a pain in the....."
Simon
Post by daveejhitchins » Tue Jun 27, 2017 8:01 am
Welcome to the Forum, Chompalot . . . Enjoy . . .
