I have replaced the SD card interface with a new CF card (512Mb)+interface and run the Risc OS 3.11 version of HDinit.
This has automatically named the disc IDEDisc4.
I have copied across the backed up !Boot + required files.
The previous disc had a different name so the disk references in !Boot.Choices.Boot.Tasks.!Boot are wrong.
The only live options for the disc are Dismount, Share & Free - Rename, etc. are greyed out!
I would prefer to rename the disc.
I have tried editing the items in !Boot to IDEDisc4 but it makes no difference, they don't run.
The configuration is unchanged from the previous working system.
Boot is set but changing the configuration to No Boot does not change the options for the disc.
Any ideas what is wrong here?
Also when booting it used to run Unplugtoolbox, it doesn't now.
Thanks,
Ray
