Vectorlight's A3010 IDE mod : step by step guide
Post by Zarchos » Wed Apr 12, 2017 3:07 pm
1st step : get a naked board :
vectorlight
Re: Vectorlight's A3010 IDE mod : step by step guide
Post by vectorlight » Wed Apr 12, 2017 5:56 pm
Here's a list of the things you'll need to get Zarchos :D , prefixed with the identifier which matches with where they need to go on the board you have. The links are for items on Ebay UK, I didn't look for the best value components so have a look for the same items from a local supplier:
ICs:
IC1-IC2 = RISC OS 3 ROM's (You will already have these!)
IC3 = HC573 - http://www.ebay.co.uk/itm/74HC573-CMOS- ... 1690760883
IC4 = HCT573 - http://www.ebay.co.uk/itm/74HCT573-Octa ... 0552681706
IC5 = HCT14 - http://www.ebay.co.uk/itm/74HCT-CMOS-74 ... 1226775297
SMD 0805 Components:
R1-R8 = 68 ohm Resistor - http://www.ebay.co.uk/itm/SMD-SMT-0603- ... 2092882745
R9-R11 = 33 ohm Resistor
R12, R17 = 22 ohm Resistor
R13-R14 = 10K ohm Resistor
R15 = 4K7 ohm Resistor
R16 = 220 ohm Resistor (Only fit if you want to overclock the CPU)
C1, C2, C5 = 100nF Ceramic Capacitor - http://www.ebay.co.uk/itm/50x-SMD-0805- ... 0973425038
C3 = 100nF Ceramic Capacitor (Only fit if you want to overclock the CPU)
Other Components:
C4 = 100uF Electrolytic Capacitor - http://www.ebay.co.uk/itm/Range-of-Radi ... 1191368791
C6 = 47uF Electrolytic Capacitor
X1 = IDE 44-pin Header - http://www.ebay.co.uk/itm/190533192334
Header Sockets for IC1-IC2 ROM Sockets (The ROM's will sit in these!) = Round Header Sockets (You will need enough for 4 rows x 21 pins) - http://www.ebay.co.uk/itm/381576373379
Board Mounting Pins (These when fitted will allow the board to be plugged into the existing ROM sockets) = Round Header Pins (You will need enough for 4 rows x 21 pins) - http://www.ebay.co.uk/itm/401031627149
X2 = DIP 14 Socket (Only fit if you want to overclock the CPU. Remove pins 2,3,5,6,9,10,12,13) - http://www.ebay.co.uk/itm/10-x-14-Pin-D ... 1769195693
3D Printing and Acorn A3010 Owner!
vectorlight
Post by vectorlight » Sat Apr 29, 2017 11:01 am
Hi Zarchos,
I've taken some pictures to help with the assembly of the board and have written it up here:
http://www.vectorlight.net/retro/comput ... dification
Let me know if you need any more info. :D
Post by Zarchos » Sat Apr 29, 2017 11:32 am
Great !
Thank you.
I'll try all this after my bits of coding are completed. I'm not far from the results I wanted to achieve, now.
Trapper
Post by Trapper » Mon May 01, 2017 9:18 pm
Assume you need an ARM250 to do this?
vectorlight
Post by vectorlight » Tue May 02, 2017 6:08 am
Trapper wrote:Assume you need an ARM250 to do this?
That's right. I did have a quick look at the adelaide schematics and if I recall 1 or the required signals was not tracked out of IOEB making this mod pretty much impossible :(
Post by steve3000 » Tue May 02, 2017 7:14 am
That's interesting, which signal? There are references (in the TRM as i recall) to the Adelaide board design for the A3020 and A4000, which presumably would require all signals for the IDE interface...but I've never heard of such an Adelaide A3020 or A4000 computer actually existing.
Maybe there was something fundamental such as this which excluded any release of an Adelaide A3020 or A4000?
vectorlight
Post by vectorlight » Tue May 02, 2017 8:05 am
I recall looking at it in Jan or Feb, not sure off the top of my head which one it was, maybe I was wrong :shock: I'm not around at the moment but will double check when I get back :D
Post by danielj » Tue May 02, 2017 8:11 am
Just with a cursory glance at the schematics, I'm struggling to find anything missing :?
vectorlight
Post by vectorlight » Tue May 02, 2017 9:17 am
danielj wrote:Just with a cursory glance at the schematics, I'm struggling to find anything missing :?
Perhaps I'm wrong :oops: If anyone wants to give this a try on an adelaide machine let me know :D
Post by danielj » Wed May 03, 2017 9:34 am
And we're off... Typically I'm having to wait an extra day for the 4k7 resistors to turn up *shakes fist at sky*
vectorlight
Post by vectorlight » Wed May 03, 2017 1:13 pm
danielj wrote:And we're off...
Awesome, you got it and have started already :D
Post by danielj » Wed May 03, 2017 1:21 pm
Yup :) Thank you! - hopefully will finish it off over the next couple of days. BTW, where did you take the +5V/GND from?
vectorlight
Post by vectorlight » Wed May 03, 2017 1:54 pm
danielj wrote:BTW, where did you take the +5V/GND from?
Cool! I took the +5V/GND from the test tabs on the left, the same as munchausen did, here is a pic of the board from his thread:
Andy1979
Post by Andy1979 » Wed May 03, 2017 5:42 pm
This is great work Vectorlight - suspect it would have been quite a big seller back in the day.
Afraid I am not brave enough to try it on my Adelaide A3010 as I already have a working IDE podule. Looks from that photo like Munchausen has the same Simtec 2mb -> 4mb upgrade that I do.
Wonder if something like this would work in the Bush IBX100 internet box?
vectorlight
Post by vectorlight » Wed May 03, 2017 7:20 pm
Andy1979 wrote:Afraid I am not brave enough to try it on my Adelaide A3010 as I already have a working IDE podule.
Yeah I can understand, it's a fairly involved mod. That said, when I get my adelaide working again I will have a go :D
Post by Zarchos » Wed May 03, 2017 7:26 pm
@Andy1979 : I've got one of these memory upgrades, and in fact it's a 3 Mbytes RAM upgrade (it's even written on it).
It means if you wanted to install some 50 ns RAM chips, you'd have also to replace the onboard 1 Mbyte. (if you're interested by the other fast A3010 project).
It's OT in this thread but worth noting : it's not a 'true' 4 Mbytes RAM upgrade.
There are no 2 to 4 Mbytes RAM upgrades ... there is either this 3 Mbytes upgrade, to 4, or 4 Mbytes and the onboard 1 Mbyte isn't used.
If some real experts (not me) have different opinions, please tell us.
Andy1979
Post by Andy1979 » Thu May 04, 2017 12:03 am
Zarchos wrote:@Andy1979 : I've got one of these memory upgrades, and in fact it's a 3 Mbytes RAM upgrade (it's even written on it).
@Zarchos - you are correct that the board has 3mb on it now, but my A3010 came with the upgrade to 2mb, with a 512K ram chip in each of the expansion sockets. A few years later Simtec sold me this kit which had 2mb on the PCB and I had to remove the existing 1mb upgrade and reinsert it into the Simtec board to give 3mb plus the onboard RAM. This made it a cheaper way to upgrade to 4mb if you already had 2mb installed. Think it was £89 at the time, whereas the IFEL kits were over £100. Sorry, OT as you say.
Post by danielj » Sat May 13, 2017 7:17 pm
Tell you what, this is slightly intense...
Post by danielj » Sat May 13, 2017 10:12 pm
Right... I'm trying this on an issue 2. Pin 27 of the SuperIO (Iocs16) seems to be wired to Pin 22 (Ided7)... I'm guessing this just makes the disc controller give up doing anything ide-y?
Now, I'm not sure why, but my spidey sense suggests that wherever the track from pin 22 is leading, it should be cut?
(c.f. http://www.chiark.greenend.org.uk/~theo ... 82c711.pdf and attached PDFs...)
Circuits.zip
(1.77 MiB) Downloaded 50 times
vectorlight
Post by vectorlight » Sun May 14, 2017 1:03 am
danielj wrote:Tell you what, this is slightly intense...
Yeah probably the hardest part that bit, looks like you've done it though :D .
Wierd, I haven't noticed them wired together. I'm away for a week so cannot look at mine. Both looked to me to be not tracked at all. In the end I didn't bother with IOCS, though in the other thread theres talk of grounding it to be safe. Have you another A3010 (iss 1) to compare?
Post by danielj » Sun May 14, 2017 6:30 am
No, I've got no other A3010s, just this one. I can see both of them clearly tracked on mine though, and they buzz together. The track *seems* to go somewhere too. I'm guessing it's pulling up or down - I can't see any other use for it. Ensuring Ided7 isn't connected to anything other than the IDE port would seem to be a good idea though. It'd be good to see a schematic of the issue 2 :?
Apart from that I'm getting a blank screen on start up - popping it out and putting the ROMs straight back in it's OK, so something must be holding the processor up. I'll buzz out the board and report back :?
Post by danielj » Sun May 14, 2017 7:13 am
Further - they're both wired to R56, not listed in the TRM, which seems to be a pull up. If Iocs16 is pulled up, my reading of the datasheet is that the controller will never be ready for a data transfer?
I think removing R56 and cutting the Ided7 track would seem to be the best idea. And possibly grounding Iocs16? Although it is wired up on the A3020 interface via a pull up...
Post by danielj » Sun May 14, 2017 1:45 pm
So, snippy a track and remove (or put to one side) resistor:
And we're off!
Brilliant work vectorlight! :D Kudos :D
vectorlight
Post by vectorlight » Sun May 14, 2017 2:47 pm
Awesome, well done! I was beginning to think that the ISS 2 board was going to be a real problem, but looks like you've figured it out :D Why there's a difference on the ISS 2 board I have no idea :?
Have you tried different lengths of IDE cable as one issue I had with mine but could never figure out was that my CF cards would not work with short (5CM) cables but did work perfectly with long (20CM) cables.
The next question is how best to mount the drive :D
Post by danielj » Sun May 14, 2017 3:21 pm
So far I've just tried a real one with a short cable (5cm) and that's fine. I haven't got any CF adaptors to hand yet, but should have some for testing this week.
Ste
Post by Ste » Mon Jun 12, 2017 2:36 pm
Hi, I'd like to give this project a go. Where could I buy the initial board from? Thanks.
Ste
Post by Ste » Thu Jun 29, 2017 3:20 pm
So, I've now got the bare board from Vectorlite! :D
I figured I'd document my progress on here, just as soon as the rest of the parts arrive. Have to admit, this is a little more complicated than I'm used to, but even if I fail I'll still be the envy of the neighbourhood with the most expensive doorstop in town! Yay.
Post by danielj » Thu Jun 29, 2017 3:37 pm
Weee! Good luck!
Nice and slow, and plenty of flux! :D And get a magnifier headset if you don't have one - most useful thing!
Ste
Post by Ste » Thu Jun 29, 2017 7:58 pm
I...don't have one.:? But I'll look it up! Cheers.:D
