Sideways RAM bank selection code
simonm
Post by simonm »
Question for you Beeb Gurus.
Quite possibly a bug in my code, but are there any gotchas when selecting a SWR bank?
My code correctly detects the presence of 4 SWR banks (slots 4,5,6,7) on a Master 128 by cycling through 16 values, selecting bank by poking the bank number to &FE30, then checking if address &8000 is writable or not.
However the same bank selection code, when used later on in my program, doesn't seem to correctly select a SWR bank.
; A contains ROM bank to be selected
.swr_select_bank
    sta &fe30
    sta &f4
    rts
(I'm stashing the bank in &F4 just in case the OS gets involved somewhere).
I've tried wrapping the call to swr_select_bank with SEI/CLI for belts and braces but that made no difference.
I'm running pure machine code rather than BASIC.
I also havent disabled any system interrupts as I didn't think that would be needed.
I'm trying to load data into the SWR banks using OSFILE, so not sure if thats a problem too - it occurred to me that perhaps the DFS is getting paged in and messing things up.
Is there some other voodoo to this? I've forgotten a lot since the old days!
TIA!
Re: Sideways RAM bank selection code
Post by sweh »
FWIW, write to F4 before FE30 just to catch the race condition.
On a Master that's all that is necessary to select a SWR bank.
But you can't necessarily use OSFILE because that will cause the DFS ROM to page in. You either need to read a byte at a time and switch the RAM bank in for each byte read, or else load the data into a low memory location (eg &2000) and then block move the data after it has been loaded. That's what the "Q" option to *SRLOAD does.
geraldholdsworth
Post by geraldholdsworth »
This seems to work - bit long winded, I know, but compiles for most machines, and includes menus, etc.
http://www.geraldholdsworth.co.uk/ExROM.php
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
simonm
Post by simonm »
Thanks all, I rewrote my loading code to use mem copy and all was well. Seems that OSFILE was indeed the problem, which makes sense, but I'd have expected a much more corrupted data upload to SWR if that was getting paged in during the write. It 'appears' OSFILE would successfully load data to the SWR memory, but for some reason it always used the same SWR bank no matter what was selected prior to calling OSFILE.
I've not got much in the way of spare RAM to load into system RAM all in one go, so I opted to use OSGBPB to load/copy 1 page at a time for a 16Kb chunk of data instead and boy that's slow!
Good catch! Done.
 3610DEFFNpagerom(i,c)
 3620IFc>0[OPTi:STA&F4:STA&FE30:]ELSE[OPTi:PHA:LDA#&C:STA&F4:STA&FE05:PLA:STA&F4:STA&FE05:]
 3630=i
Thanks for the reference code Gerald, whats the FE05 bit do?
geraldholdsworth
simonm wrote:Thanks for the reference code Gerald, whats the FE05 bit do?
That's the sideways bank selection address for the Acorn Electron. The code is multi-platform.
Gerald Holdsworth
Post by jgharston »
simonm wrote:My code correctly detects the presence of 4 SWR banks (slots 4,5,6,7) on a Master 128 by cycling through 16 values, selecting bank by poking the bank number to &FE30, then checking if address &8000 is writable or not.
If you're going to do that you must use the binary version number at &8008, not any other location. Imagine what happens if you write to &8000 and before you can manage to restore it a reset happens. Bnag!
simonm wrote:.swr_select_bank
sta &fe30
sta &f4
rts
As others have pointed out, you've got those two the wrong way around. Imagine what happens if an interupt happens between STA &FE30 and STA &F4. The interupt routine pages in whatever it needs, then restores the ROM from what &F4 was.
simonm wrote:I'm trying to load data into the SWR banks using OSFILE, so not sure if thats a problem too - it occurred to me that perhaps the DFS is getting paged in and messing things up.
Without specialist hardware or a specialist filing system that will not work as the filing system is sat on top of the same addresses as the sideways RAM. Without specialist hardware you can only write to a bank of sideways RAM when it is paged in in the same way that you can only read from it when it is paged in. If it is paged in then by definition the filing system is paged out. You load data into sideways RAM by loading is into a buffer then copying it from that buffer to sideways RAM, and vis versa for saving.
Post by sweh »
Although not strictly relevant, here, Solidisk DDFS had a fun feature. The FDC handling code would be copied down to page D and the data load done from there. This meant the ROM could be paged out. They also looked at the 3rd byte of the load address and paged that bank in. So you could do
*LOAD MYROM 48000
And it would be loaded into bank 4.
Totally non-portable, but useful!
simonm
Post by simonm »
geraldholdsworth wrote:That's the sideways bank selection address for the Acorn Electron. The code is multi-platform.
Ah gotcha.
Good tip!
