Pi-based Co-Pro on the cheap - 100MHz 6502 for £10? (now 290MHz)
Re: Pi-based Co-Pro on the cheap - 100MHz 6502 for £10?
Post by hoglet »
Hi Guys,
Time for an update...
For a while now we've had some tricky reliability issues on the single core Pies. There's more details a few posts back:
http://www.stardot.org.uk/forums/viewto ... 70#p150565
hoglet wrote: What does the future hold?
There is a plan afoot to shift the 6502 request handling to a process on the GPU, which we believe will really help. But this is a pretty big change, and Dominic (dp11) who is driving this work hasn't had much spare time. I'd very much like to see this happen, so Dominic if there's anything I can do to help, then please just ask.
Over the last several weeks, Dominic, myself and Ed have been working hard towards this goal.
It turns out the GPU on the Pi is actually far more than just a GPU. It also includes a general purpose ARM-like processor, and the details of it's instruction set have only recently been discovered (through a herculean black-box reverse engineering process). For the brave who want to know more, take a look at this page:
https://github.com/hermanhermitage/vide ... ers-Manual
What we (mostly Dominic) have done is taken the ARM assembler code we had for emulating the front end of the tube chip, and ported it to run on the GPU. This code is massively time critical - when the Beeb reads a tube register this code needs to run and provide the right data within ~300ns (six squares on the scope piccies below). Meeting this requirement 100% of the time proved to be impossible when sharing a single ARM code, hence the desire to offload this to the GPU. Again, if anyone is interested what this actually looks like, then take a look here:
https://github.com/hoglet67/PiTubeDirec ... e/tubevc.s
Just to give an idea of the benefit of this, here is a before and after picture showing the variation in tube-read times:
Original ARM-Only version:
New GPU version:
The Beeb needs tube read data to have settled by the grid line with "50ns" just above it.
I think the pictures speak for themselves!
So now even the lowly Pi Zero can effectively devote one (GPU) core to the tube interface and the other (ARM) core to the various Co Pro emulators. A side effect of offloading the tube handling onto the GPU is that the "fast" 65C02 Co Pro now goes even faster - 225.62MHz on the Pi Zero.
Anyway we're pleased to announce the availability of a "beta" release for testing that includes this new GPU code:
PiTubeDirect_20161023_1834_dmb.zip
(826.04 KiB) Downloaded 125 times
I have tested this on the Pi Zero, Pi One, Pi Two and Pi Three. See the wiki for the recommended config.txt settings:
https://github.com/hoglet67/PiTubeDirec ... xt-options
We're particularly interested in people trying out the non-6502 cores, as these were the ones that were unreliable before on the Pi Zero/One.
But any feedback (positive or negative) is most welcome :D
sirmorris
Post by sirmorris »
=D> 8) =D>
SteveF
Post by SteveF »
I don't have anything useful to add, but congratulations, this sounds excellent!
boba
Post by boba »
Quite a remarkable reverse-engineering task, interesting reading!
I've had a quick play with the new build on a Pi2 on a Master128.
First observation is that the processors all seem to boot more quickly on startup or after an FX151,230. On the previous build it generally took 3 or 4 ctrl-breaks before the processor kicked in after a cold start. It now seems to start reliably on the 2nd. Doesn't start straightaway still because I guess the Master gets up quicker. In particular the 32016 seems to come up quicker and more reliably.
Combined timing on the fast 6502 is 241.98, almost twice as fast as before!
Had a play with both Dos+ on the 286 and Pandora/Panos on the 32016. Both seem stable. No noticeable difference in loading times (IO-bound though). The Fortran check on Panos seems about the same for timing (on my watch!) but probably also IO bound. Nothing convenient for the 286 to hand but running the BASIC timing test on Pandora was a bit of a disappointment - 24.84 for the new build whereas the old build was 31.95 combined speed.
Post by hoglet »
boba wrote: Nothing convenient for the 286 to hand but running the BASIC timing test on Pandora was a bit of a disappointment - 24.84 for the new build whereas the old build was 31.95 combined speed.
Yes, the 32016 will be running a bit slower. It's still 6x faster than the original was I believe. It's the price to be paid for increased reliability I'm afraid. Particularly the issue of not being recognised on BREAK. Apart from the on the initial power up, do you find the 32016 is now recognised on every BREAK, or is it still sometimes missed?
Anyway, it's possible we can claw back some of the performance in the future.
SteveF
Post by SteveF »
Actually I thought of a question now. It's not important, I'm just curious - does this remove all timing constraints on the soft core, or does it still have to respond relatively quickly? If you sprinkled busy loops which just spin for (say) 5 seconds at random throughout the soft core code (not the new bit running on the GPU), would everything still "work"?
Post by hoglet »
SteveF wrote:Actually I thought of a question now. It's not important, I'm just curious - does this remove all timing constraints on the soft core, or does it still have to respond relatively quickly? If you sprinkled busy loops which just spin for (say) 5 seconds at random throughout the soft core code (not the new bit running on the GPU), would everything still "work"?
This is a very interesting and pertinent question. The answer is no, the current GPU doesn't (yet) remove all timing constraints. But it's a step in the right direction...
Tube register reads are handled by the GPU, but writes are still passed through to the ARM core. Some latency is tolerable, but if the Beeb host does a tube register write, followed immediately by a read, then that read needs to return the latest state, or things can go wrong. One of the most challenging cases is detection of the Co Pro on a tube reset, where the Beeb writes the Tube control register, then immediately reads it back again (about 2us later). This sequence currently needs to propagate from the GPU, through at ARM core and back again. So on pretty much all the Co Processors we are emulating a single instruction, then polling a GPU->ARM hardware mailbox for tube requests to process. The Fast 6502 Co Pro is a little different, in that it uses an ARM interrupt from the mailbox, but in a way that's not easily to generalise to the other Co Pros.
Improving this is really one of the next things we need to work on, either by:
- on the ARM side allow the GPU->ARM hardware mailbox to generate in interrupt, and have this process the tube request (in C).
- or, move the C code that handles tube request into the GPU. This part of the Tube chip emulation is written in C (actually borrowed from B-Em - thanks Sarah!). So this either needs porting to GPU assembler, or we need to find a C compiler for the GPU. There is a port of GCC, but haven't tried it yet: https://github.com/puppeh/vc4-toolchain
If we can do one or other of these things, then that will further relax the real time constraints on the emulator side, although not by a huge amount. Certain things on the tube (e.g. NMIs that are part of tube data transfers) need to happen within 10us or data is lost, because there is no host side flow control. But actually 10us is an age when the ARM code is running at 1000MHz!
dp11
Post by dp11 »
I did try to build the gpu c compiler but it failed to build on my machine.
SteveF
Post by SteveF »
Thanks Dave, interesting stuff. I was wondering whether this might open the door (just a crack, even :-) ) to possibly running a lib6502-jit-based emulator on the Pi, but it looks like that's a fair way down the road if it's even remotely feasible.
(I don't know if you can run the LLVM JIT on bare metal, but I would guess in single-threaded mode it's at least a theoretical possibility. But if there are any remotely tight deadlines involved you'd need two threads - one for JITting and one for standard lib6502-style interpreting to keep the worst case response time down - and that would probably be harder still on bare metal.)
I guess a 200MHz+ 6502 is plenty fast enough anyway. :-)
Post by hoglet »
dp11 wrote:I did try to build the gpu c compiler but it failed to build on my machine.
Mine also, I think it need a much more recent version of GCC that comes with Ubuntu 14.04. Maybe it's time to update to 16.04.
boba
Post by boba »
hoglet wrote:Apart from the on the initial power up, do you find the 32016 is now recognised on every BREAK, or is it still sometimes missed?
After *fx151,230,13 with the 32016 recognised and running it reliably restarts on ctrl-break.
There's an interesting oddity:
If the current copro is either the fast or slow 6502, then after *fx151,230,13 the 32016 always takes 2 ctrl-breaks to start.
If the current copro is anything else, then after *fx151,230,13 the 32016 always starts on the first ctrl-break.
(within experimental error because my fingers got tired).
Post by hoglet »
SteveF wrote: I guess a 200MHz+ 6502 is plenty fast enough anyway. :-)
I honestly don't think lib6502-jit would come close to the 225MHz we are currently getting.
But then I would think that I guess and it would be nice to be proved wrong :D
What sort of a speed up do you typically see compared to lib6502?
Post by BigEd »
hoglet wrote:
SteveF wrote:I guess a 200MHz+ 6502 is plenty fast enough anyway. :-)
I honestly don't think lib6502-jit would come anywhere close to the 225MHz we are currently getting.
That could be checked on a Pi running linux - no need for bare metal to benchmark it. I'm inclined to agree though, having seen the micro-optimisations being piled on!
dp11
Post by dp11 »
I did wonder about JIT but with self modifying code making a mess with the cache I'm not sure it would help. I have thought about using another core to try an compile code in advance for the other core, but that sounds a mess.
There is if you look in our github a faster 6502 coming . Currently 6502 250MHz on Raspberry Pi zero running at 1GHz. Now that doesn't give you a lot of ARM cycles to play with.
Post by hoglet »
fast_6502 is what's coming...
dp11
Post by dp11 »
On the web someone tried static compilation of a new game. They did get it going but it was a lot of work to deal with the tricks programmers used.
SteveF
Post by SteveF »
I did actually try this on raspbian a while back, but unfortunately there seemed to be a bug in the llvm JIT on that platform - the example toy JIT didn't work either, so at least lib6502-jit was off the hook :-). (https://bugs.launchpad.net/raspbian/+bug/1527421) I ought to check at some point and see if there's a newer llvm for raspbian, just as a matter of interest; I suspect the technical obstacles to using it as a co-pro are too great even if the performance was better.
boba
Post by boba »
Out of interest tried out the Z80 on the new build, seems completely OK.
Couldn't drum up the energy to port the timing program (yet) but with BASIC on a simple mix of instructions the new build seems to be about 25% faster.
fordp
Post by fordp »
Well done guys. I built my boards this week. I will have to get back to some hacking.
=D> =D> =D> =D> =D> =D> =D> =D>
FordP (Simon Ellwood)
iainjh
Post by iainjh »
just set my master, pi zero and Kjell's master level shifter board up, its working wonderfully . Cheers everyone, you are amazing! :):)
jms2
Post by jms2 »
Top work guys =D>
I can't wait to test mine (including a test to see if it can coexist with the internal turbo board), but I'm away this weekend.
theandylaird
Post by theandylaird »
Hi everyone - long time lurker, first time poster here.
I've just got PiTubeDirect up and running in my Master with a Pi 3.
All works great except for the 80286 core - when I switch to it and CTRL Break I get the startup header, followed by Bad Command error and I then get dropped to a * prompt instead of it booting off the floppy.
I've tried various versions of the M512 boot disks - occasionally I can get one to start booting if I type DOS at the star prompt but they always crash part way through the boot. I've created the boot disks from the images using IMGTODISK and a formatted 640k ADFS floppy.
What on earth am I doing wrong?
Andy
Post by hoglet »
theandylaird wrote: All works great except for the 80286 core - when I switch to it and CTRL Break I get the startup header, followed by Bad Command error and I then get dropped to a * prompt instead of it booting off the floppy.
Probably you are doing nothing wrong.
There is a bug in this core that seems to prevent it booting on Ctrl-Break.
(If you look on the Pi serial console, you'll see warning of an illegal instruction).
You should be able to reliably boot DOS Plus from the * prompt by typing DOS.
What are your overclocking settings?
I'll double-check tomorrow that this is still working correctly for me.
theandylaird
I've now got it working - turns out that the DOS+ boot disk that I created wasn't quite up to scratch. I created a new one using another method and managed to boot to a DOS prompt.
Post by jgharston »
Any chance of the PDP-11 and 6809 being added to the Pi-CoPro?
Post by jgharston »
hoglet wrote:
theandylaird wrote:All works great except for the 80286 core - when I switch to it and CTRL Break I get the startup header, followed by Bad Command error and I then get dropped to a * prompt instead of it booting off the floppy.
I get that sometimes when booting 80x86 DOS on B-Em. I never got around to digging away and seeing what circumstances replicated it, but it seems very similar to that.
Post by hoglet »
What 80x86 Emulator does B-Em use? We're using Fake86 in PiTubeDirect.
Post by hoglet »
jgharston wrote:Any chance of the PDP-11 and 6809 being added to the Pi-CoPro?
These are both on my TODO list, probably 6809 first.
Do you have any recommendations for CPU emulations to leverage? It needs to be vanilla C (or C++ that is close enough).
jms2
Post by jms2 »
I've just tried out the latest build (using the GPU to deal with Tube transfers) on my Master Turbo. This is using an RPi2.
It all works brilliantly. I get 219MHz combined average speed on the 6502. All the CPUs start pretty much perfectly first time, and (this is a big improvement) all of them are able to "beat" the internal co-pro and start up first. =D> Obviously I'm using *Configure Extube (otherwise I'd get the internal copro all the time).
One question: I put copro=14 into the cmdline.txt file, but it doesn't seem to work - I still get the (external) 6502 by default. Is there no "null processor" on this setup?
Post by hoglet »
jms2 wrote: One question: I put copro=14 into the cmdline.txt file, but it doesn't seem to work - I still get the (external) 6502 by default. Is there no "null processor" on this setup?
Hmmm, I just tested that, and I have a different issue. It starts up in Co Pro 14 (the Null Co Pro), but then I can't change away from this.
I've added an issue into github:
https://github.com/hoglet67/PiTubeDirect/issues/13
