Atom Software Archive
Re: Atom Software Archive
Ok, I'll give it a try.
Greetings
Kees
Greetings
Kees
- CMcDougall
evening Dave, cheers for looking further into these for me, as had sweat running off my head just trying to get them to load!hoglet wrote:in batch 3 there was a loader called MUNCH, was there anything following it, or preceding it?.
anyways, nothing after that file, also checked the original tapes to double check, and confirm was only:
jb14 <names of .WAV files I gave when split up 3x sides of the copied TDK D90
QUEST load8200 call8200 lenBFF
jc1
BIORYTHMS 38D
ATOM MUNCH 1B7
HEXPAWN 782
jc2
3D MAZE 10B8
another little extra, I again used *FLOAD to get block A -12eb (started 3300) of "TRENDY TEST"
below, it works if just Load TRENDY, then Goto 795, Questions to find out how cool you are
as porky pig said, that's all folks
- Attachments
- TRENDY.zip
- mmc file
- (1.26 KiB) Downloaded 84 times
I tested some programs from Colins batch:
BNAME:
Database for Names and Birthdays.
- Choose 1) WRITE to enter a few Names and Birthdays
- Choose 2) SAVE and enter a filename to to save this data in a sequential file
- Choose 3) LOAD to search for a Name or Birthday
- Choose 4) QUIT to end the program
The program is working without changes.
EINPUT,EPROC, EPROG, ETAB:
Generate extended Error Messages.
EINPUT is a program to enter the new error messages and is saved as ERRTAB at #8200
EPROG is the new errorhandler code and is saved as ERRPROC at #8700
There was a similar program in Acorn User 1983-02 Error Handling.
I have included a new ERRTAB and ERRPROC file with the right loadaddresses.
*LOAD ERRTAB 8200 and *LOAD ERRPROC 8700
To test it, type: ?#202=0;?#203=#87;DDFR
An error occurs and the extended message 'UNKNOWN OR MISSING FUNCTION' is displayed.
To use it in your program, include ?#202=0;?#203=#87 in your program.
Greetings
Kees
BNAME:
Greetings
Kees
Hi Kees,
Thanks for taking a look at these.
I'll try to package everything we have discussed so far, and release a V10Beta2 over the next few days.
A couple of things have rather surprised me:
- there isn't much in the archive from Acorn User
- there isn't much in the archive from Getting Acquainted with you Acorn Atom
Maybe not for V10 (unless someone is really keen), but beyond that we should make an effort to catalog and capture some of this content.
This thread has an index and PDF copies of all the Atom Acorn User articles:
viewtopic.php?t=7566
It would be good to work through the articles, and annotate the index with any that included significant programs worthy of inclusion.
Just having a quick look through the Acorn User Articles, and GRAFSIGN and DIASSE in from Colin/Johns tapes are from Acorn User!
hoglet wrote:Hi Kees,
Dave, If I get some time over the summer hols, I'll dig out my copy of "Getting Acquainted..." and have a go at keying some of the programs in.
Any requests?
Found S Yewdall ....hoglet wrote:Anyone familiar with these programs, or know who "S YEWDALL" was?
Stephen Yewdall was the author of 'Atom Plotting Power' published in Your Computer 1983-06.
There are also a few Your Computer programs missing:
http://www.stardot.org.uk/forums/viewto ... les#p86730
Greetings
Kees
- Attachments
- YC1983-06 Atom Plotting Power.pdf
- (742.08 KiB) Downloaded 75 times
Some more research .....
Disco Dance is combination of a program published in Acorn User nov.1984 by R.J.Adams named "Dancing Demo" and a program published in Acorn User apr.1984 named "Disco fever" by Tim Pierce .
PS there was a little problem with BNAME, the opened files weren't closed.
Another problem is the DIM command in subroutines which means that at one point there will be a memory shortage.
Will probably not being a problem because the program won't be used frequently ....
Here is an updated version for closing the files.
Greetings
Kees
Greetings
Kees
Note to self:
- Tetris already added
- still need to add Turtle Talk
I'm sorry, I'm a newbie...how can I run this softwares with an emulator? I tried with Atomulator for DOS but the file format is not rcongnized by this emulator. I also change files extension in .TAP but they don't run...
Can you help me? Thanks.
Hi festuceto,
Atomulator is for now the most extended and accurate emulator running in Windows, Linux, RPi and Apple OS.
viewtopic.php?f=44&t=9518&p=144987
Greetings
Kees
Greetings
Kees
PS I think you meant AtomEmulator written by Wouter Ras because Atomulator doesn't run in DOS.
Greetings
Kees
Greetings
Kees
oss003 wrote:PS I think you meant AtomEmulator written by Wouter Ras because Atomulator doesn't run in DOS.
Greetings
Kees
Yes, however I don't know how to run this files from the archive.
The matter is that atomulator runs only .uef or . csw file but files in the Atom Software Archive are not uef or csw!
- CMcDougall
if using Atomulator V1.27 (which is best), make sure under the settings tab at top >RamRom> both are ticked,
then unzip the Archive (1st page of this thread "AtomSoftwareArchive_20151119_V9.zip"), then copy them all into the MMC folder within the Atomulator127 folder.
then type */MENU & off you go!
CMcDougall wrote:if using Atomulator V1.27 (which is best), make sure under the settings tab at top >RamRom> both are ticked,
Ok, so I have to type */MENU ?
I can't find the symbol *
it doesn't exist on emulator it seems...
Press whatever key on your keyboard is two keys to the right of L, with shift held down (on my keyboard this is @)Festuceto wrote: Ok, so I have to type */MENU ?
Shift-F12 also normally launched the menu.
If you still have problems, please post of screen shot of Atomulator.
hoglet wrote:Press whatever key on your keyboard is two keys to the right of L, with shift held down (on my keyboard this is @)Festuceto wrote: Ok, so I have to type */MENU ?
I tried shift-f12 to launch menu, but it says "ERROR - NOT FOUND"
Screen shot / photo please?hoglet wrote: If you still have problems, please post of screen shot of Atomulator.
Can you also post the results of *CAT
The ERROR 94 is a bit unexpected. Can you try:
then:
Also, a directory listing (from Windows) of your Atomulator/mmc directory would be helpful. I suspect you have somehow unpacked the archive into the wrong place.
*HELP
*CAT
I'm sorry, I didn't insert all archives files in the mmc directory. Now it works!
Thank you very much!!!
- Multiwizard
I was testing the 2nd joystick input of my ABM Atom...
It works ok with all the 2 player games except for WARLORDS...
To verify it I tried to play WARLORDS on my 2014 Atom,,, surprisingly the same problem...
Is the WARLORDS program ok?
(for 2 player action)
Greetings, Wim...
Greetings, Wim...
Looks like Warlords is patched for only 1 joystick.
Here is the 2 player joystick version. Greetings
Kees
Kees
- Multiwizard
Yes, it works...oss003 wrote:Looks like Warlords is patched for only 1 joystick.
WARLOR.zip
Greetings
Kees
Thanks Kees...
I have now CATted a few of my old Atom tapes.
I suspect a lof of this software is already well known about.
First is a list from a tape labelled "Acornsoft". I have no idea where I got the software from.
STARGATE. 4-ROW. BREAKOUT. DOGFIGHT. LUNAR LANDER. DODGEMS. INVADERS. OTHELLO. ROBOTS. RAT TRAP.
APPLECOS.SRC. BREAKOUT.
DISASSEMBLER. 3D. TRANSFORM. PICTURES. REVOLVE. ENTOMB. LOAD WARNING. FACSIMILE. VDU-W. VDU-B. FAST COS. MUSIC.
ACORNUSER1. RTTY. MANHUNT. PCWOCT. PCWSEP. PCW2. PCWPAL.
ROADRACE. BREAKOUT. DRIVE. MOONLANDER. SPACE BATTLE. MISSILE DODGE. TALKBACK. MAZE. OTHELLO. HAMMURABI.
INVADERS. NEWTON.
--Gary
INVADERS. NEWTON.
--Gary
Hi Gary,
I have checked your titles with our lists and this is what I found:
Can you upload the files or record the tapes/files as WAV files so we can addd them to the archive?
Thanks.
Greetings
Kees
x = Already in the archive
! = Not in the archive so interesting to checkout
x STARGATE Acornsoft Games 08
x 4-ROW Acornsoft Games 04
x BREAKOUT Acornsoft Games 10
x DOGFIGHT Acornsoft Games 02
x LUNAR LANDER Acornsoft Games 03
x DODGEMS Acornsoft Games 06
x INVADERS Acornsoft Games 05
x OTHELLO Acornsoft Games 05 Probably REVERSI
x ROBOTS Acornsoft Games 08
x RAT TRAP Acornsoft Games 03
! APPLECOS.SRC ???
! BREAKOUT Several versions available so Acornsoft Games 10???
x DISASSEMBLER Acornsoft Utility Pack 1
! 3D ???
! TRANSFORM ???
! PICTURES ???
! REVOLVE ???
! ENTOMB Computer & Video Graphics magazine Vol 5 page 59
! LOAD WARNING Could be Your Computer 1982-3 page 66
! FACSIMILE ???
x VDU-W Acornsoft Soft VDU
x VDU-B Acornsoft Soft VDU
x FAST COS Acornsoft Utility Pack 1
! MUSIC ??? Could be Synthesizer?
! ACORNUSER1 ???
! RTTY ???
! MANHUNT ???
! PCWOCT Personal Computer World Magazine October???
! PCWSEP Personal Computer World Magazine September???
! PCW2 Personal Computer World Magazine???
! PCWPAL Personal Computer World Magazine???
! ROADRACE Could be Software Pro Software Road Race???
! BREAKOUT Several versions available so ???
x DRIVE The Atom Magic book
x MOONLANDER The Atom Magic book
x SPACE BATTLE The Atom Magic book
! MISSILE DODGE ???
x TALKBACK The Atom Magic book
! MAZE The Atom Magic book Probably 3D-MAZE
x OTHELLO The Atom Magic book
x HAMMURABI The Atom Magic book
! INVADERS ???
! NEWTON ???
Thanks.
Greetings
Kees
Hi Kees,
Many thanks for taking the time to identify. There are other programs including my owm Atom Basic compiler, GAZDOS (8 inch floppy OS) and space invaders (which I want to finish off albeit 35 years late
). The PCW files are almost certainly type in programs from the magazine Personal Computer World from the 80's.
Tape loading using the FPGA solution is not working great (not the FPGAs fault, just the bad quality of the recordings) often giving an ERROR 6(?).
I intend to transfer to PC, as suggested by Hoglet, and use his Java code to extract.
I can send you the recordings once I get them onto the PC, errr... let me know your email address via private message(?).
--Gary
--Gary
Hi Gary,
The easiest way is to record the files as WAV files.
The Atom emulator in MAME can read WAV files as if they are tapes but I think Hoglets Java code is the best way to go.
Please try to read them with Hoglets code first and if that's not working, I'll have a look at the WAV files.
Greetings
Kees
Greetings
Kees
Thank you guys this really is ace!
Running all these games on a real Atom, you can't beat it for my money
Martin
Martin
