Atomulator latest version
oss003
Post by oss003 » Mon May 04, 2015 7:46 pm
Version:
The latest version of Atomulator is: v1.28
http://www.acornatom.co.uk
AtomulatorWinV1.28.zip
(2.58 MiB) Downloaded 18 times
Link to other ports:
- Windows/Linux: https://github.com/hoglet67/Atomulator
- OSX: https://github.com/harrowm/Atomulator
- Raspberry Pi->Optima: https://github.com/hoglet67/Optima
Revision history:
v1.28:
- Fixed some crashes with when rewinding and ejecting tapes
- UEF tape input now correctly handles high tone length in UEF
- UEF tape high frequency changed from 2518Hz to 2403Hz
- Fixed a Linux GUI issue in sound settngs menu
- Pollsound now runnng at 31.250KHz - ^G beep much cleaner
v1.27:
- Fixed 8271 writing that was broken in 1.26
v1.26:
- Added 1770 ADOS/GDOS support
- Added main-/video RAM configuration in non RAMROM mode
v1.25:
- Debugger memorydump #0Axx fixed
Revisions.txt
(3.38 KiB) Downloaded 14 times
Manual:
- Latest manual:
Manual.txt
(8.7 KiB) Downloaded 75 times
Software:
- Acorn Atom Archive: viewtopic.php?f=44&t=6544
Useful documentation:
- DOS commands: http://acornatom.nl/atomulator/Atom%20discpack.txt
- AtoMMC commands: http://acornatom.nl/atomulator/AtoMMC2.txt
- ROM manuals: https://drive.google.com/folderview?id= ... sp=sharing
Greetings
Kees
oss003
Re: Atomulator latest version
Post by oss003 » Tue Aug 25, 2015 9:04 pm
25-Aug-2015 Update to v1.24
oss003
Post by oss003 » Sun Sep 13, 2015 7:32 pm
Hi guys,
just want to mention that the site www.atomulator.acornatom.co.uk is updated to v1.24.
Greetings
Kees
Post by hoglet » Sun Sep 13, 2015 7:45 pm
Or even just http://acornatom.co.uk/
Prime
Post by Prime » Wed Dec 02, 2015 4:15 pm
Hi guys,
I've just added updates for Atomulator to support the GDOS-2015 floppy controller. What format do I need to submit patches in. At the present time I have only got it compiling on windows, but will update for Linux. Someone else will have to do Macos, as the Mac that I have at home will only run OSX 10.6.....
I'm also just for completeness planning on adding a RAM config option so that with RAMROM disabled you can set the amount of base RAM I was thinking of the following configs :
1K, very basic Atom, just 1K in the bottom of RAM. #0000-#03ff
6K, basic Atom with all on motherboard base RAM filled, above plus #2800-#3BFF.
9K, basic Atom with 6K motherboard and 3K DOS as above plus #2000-#27ff and #3C00-#3fff
25K basic Atom + DOS + 16K from #4000-#7fff
And of course RAMROM for the full 32K.
What do people think?
Phill.
oss003
Post by oss003 » Wed Dec 02, 2015 7:49 pm
Hi Phill,
Prime wrote:I've just added updates for Atomulator to support the GDOS-2015 floppy controller.
Nice job Phill ...... =D> =D>
Prime wrote:What format do I need to submit patches in. At the present time I have only got it compiling on windows, but will update for Linux. Someone else will have to do Macos, as the Mac that I have at home will only run OSX 10.6.....
You can find/download the latest Atomulator files at https://github.com/hoglet67/Atomulator
If you send Dave or me the changed files, we can upload them to Github.
Maybe Dave can authorize you to upload the files yourself.
Prime wrote:I'm also just for completeness planning on adding a RAM config option so that with RAMROM disabled you can set the amount of base RAM I was thinking of the following configs :
This is a good idea to test programs on a non expanded Atom.
Greetings
Kees
Prime
Post by Prime » Wed Dec 02, 2015 9:14 pm
oss003 wrote:You can find/download the latest Atomulator files at https://github.com/hoglet67/Atomulator
Yep I downloaded the zip archive from there and merged my changes into it....I've been meaning to do that for a while, I made the changes back over the summer whilst I was porting ADOS to the 1770, much easier to work with an emulator than real hardware, especially whilst on holiday in Wales :)
I have added some menu options to allow selecting of the 1770 based controller or the original Atom one, and to select the rom bank from the board.
That was exactly what I was thinking.....
Ok, I'll implement the memory selection and then submit some files.....
Phill.
oss003
Post by oss003 » Wed Dec 02, 2015 9:20 pm
Please check the versions because I updated Atomulator in Github to v1.25 not so long ago.
The problem was that a memorydump at #0A00 returns #FF even when the diskcontroller is disabled.
Greetings
Kees
oss003
Post by oss003 » Tue Mar 01, 2016 9:51 pm
Hi guys,
I have just updated the latest Atomulator version to v1.27.
http://www.stardot.org.uk/forums/viewto ... =44&t=9518
Greetings
Kees
bakoulis
Post by bakoulis » Sat Apr 02, 2016 10:46 am
Last version for Linux is 1.14.
Any chance for update to 1.27?
:roll:
harrowm
Post by harrowm » Sun Apr 03, 2016 12:53 pm
For the Linux version, you should self compile the v1.27 code. Typical instructions (Ubuntu 14.04 64bit):
Check you have a c/c++ compiler
gcc -v
g++ -v
if not, download and install:
sudo apt-get install build-essential
download git
sudo apt-get install git
get the Allegro 4 libraries
sudo apt-get install liballegro-dev
get the dependencies
sudo apt-get install zlib1g-dev
sudo apt-get install libopenal-dev
sudo apt-get install libalut-dev
clone the code from github
cd
git clone https://github.com/hoglet67/Atomulator
compile
cd Atomulator/src
make -f Makefile.linux
run
cd ..
./Atomulator
Malcolm
bakoulis
Post by bakoulis » Sun Apr 03, 2016 2:19 pm
Thank you very much Malcolm!
=D>
oss003
Post by oss003 » Mon Aug 01, 2016 6:25 pm
Ok guys,
Atomulator on the acornatom.co.uk site is updated to v1.27.
Greetings
Kees
oss003
Post by oss003 » Wed Mar 28, 2018 8:48 pm
Hi guys,
Atomulator on the acornatom.co.uk site is updated to v1.28.
See the first post or goto http://www.acornatom.co.uk
Greetings
Kees
