MMFS Development and Support
Post by hoglet » Sun Jan 17, 2016 9:08 pm
Hi Guys,
MMFS is one of several ROMs that allow modern SD Cards to be used on a Beeb with minimal external hardware (others include the original SuperMMC, Steve Picton's TurboMMC and Duikkie's SmartSPI). MMFS was written by Martin Mather in 2012, but seems to have been forgotten about until it was rediscovered in 2015.
MMFS has the following features:
- it's built from simple text source files (BeebASM), rather than patching existing binaries with BBC Basic programs
- it's derived from DFS 2.x rather than DFS 0.9
- the Master and Beeb/Electron SWRAM versions result in PAGE at &E00
- it preserves the current drive on BREAK
- it now supports FAT32 (upto 8GB) as well as FAT16
- I'm motivated to fix any bugs that people find!
MMFS now has it's own github repository.
https://github.com/hoglet67/MMFS/commits/master
I''ve improved the build script, so it builds the following versions:
- Beeb ROM (MMFS)
- Beeb Sideways RAM (SWMMFS)
- Electron ROM (EMMFS)
- Electron Sideways RAM (ESWMMFS)
- Master (MAMMFS)
adds them to a .ssd file, and finally zips everything into a single release file.
Here's the current release (1.36):
https://github.com/hoglet67/MMFS/releases
For an explanation of the release structure, see:
https://github.com/hoglet67/MMFS/wiki/Release-structure
Other threads mentioning MMFS:
The DFS ROM source code thread, where Martin M published the initial version of MMFS.
The BeebFpga thread, where bug fix releases 1.01-1.07 were made.
The TurboMMC / SmartSPI, CoPro, OSWord 7F loads to wrong address thread, where version 1.08 fixed some OSWORD 7F Tube bugs.
The MMC Card Interface thread, where MMFS. SmartSPI and earlier ROMs are compared.
The Simple Electon MMC Interface thread, which shows how to connect a cheap SD card adapter to the Electron Plus One printer port.
This thread discusses the IDTOM and IMTOD utilities that are now bundled with MMFS.
Please use this thread for feature requests and bug reports.
I'll publish new releases here as well.
PhilYoung
Re: MMFS Development and Support
Post by PhilYoung » Sun Jan 17, 2016 10:16 pm
how about adding a quick note listing the intended MMC/SD card to user port connections to help making up a cable - maybe a schematic would be useful as well ? Presumably the target is one of those 99p 'ebay' boards with the level shifters ?
Also, I gather that the IFEL Turbo MMC ROM has some sort of incompatability with Econet but I've not been able to discover in what way exactly. Does the MMFS version have the same problem ?
Thanks for all your work on this (and everything else)
Phil Young
Post by hoglet » Sun Jan 17, 2016 10:40 pm
PhilYoung wrote: how about adding a quick note listing the intended MMC/SD card to user port connections to help making up a cable - maybe a schematic would be useful as well ? Presumably the target is one of those 99p 'ebay' boards with the level shifters ?
It's the same connections as the original, as detailed here:
http://swhs.home.xs4all.nl/bbc/mmbeeb/#mmchardware
Post by hoglet » Sun Jan 17, 2016 10:44 pm
PhilYoung wrote: Also, I gather that the IFEL Turbo MMC ROM has some sort of incompatability with Econet but I've not been able to discover in what way exactly. Does the MMFS version have the same problem ?
Anyone know any more about this problem?
Post by sweh » Sun Jan 17, 2016 11:10 pm
I have two Model Bs (issue 4, issue 7) and a Master 128 all with TurboMMC all working with Econet just fine. (The other Master has a Retroclinic CF adapter and no MMC, and acts as the fileserver)
PhilYoung
Post by PhilYoung » Mon Jan 18, 2016 7:44 am
Thanks,
Phil Young
PhilYoung
Post by PhilYoung » Mon Jan 18, 2016 7:46 am
I'll see if I can find the reference, it was on here somewhere.....
Phil Young
Post by DutchAcorn » Mon Jan 18, 2016 8:43 am
Phil Young
It was discussed here. Stephen mentioned he got it to work, I could not. Duikkie changed Smart SPI to make it work with Econet. See discussion here.
MMFS works fine with Econet.
I have a tape-only Econet fitted model B, I will try to find some time this week to see if this one works with Econet and Turbo MMC.
Stephen did get this combo to work so it may need a little more digging.
Post by hoglet » Mon Jan 18, 2016 9:19 am
Current release (1.08) added to the first post of this thread.
PhilYoung
Post by PhilYoung » Mon Jan 18, 2016 10:27 am
DutchAcorn wrote:
PhilYoung wrote:
hoglet wrote: Anyone know any more about this problem?
Phil Young
Thanks for that, it's reassuring that I didn't imagine it. The problem is also mentioned a couple of times, for instance here:
viewtopic.php?f=26&t=8512&start=60#p92915
and earlier here:
viewtopic.php?t=6277#p60248 which I think was the thread I was thinking of in the first place.
But since you say Hoglets recent MMFS works correctly with an Econet equipped system, then it's probably a moot point,
Phil Young
TheCorfiot
Post by TheCorfiot » Mon Jan 18, 2016 4:30 pm
Will MMFS work with Steve Pictons Turbo MMC hardware ?
thx :)
Post by sweh » Mon Jan 18, 2016 4:32 pm
TheCorfiot wrote:Will MMFS work with Steve Pictons Turbo MMC hardware ?
Not at the moment, but cross-thread there are discussions on how it might be made to work with it.
Post by hoglet » Mon Jan 18, 2016 5:58 pm
Stephen,
Would you be up for testing a version of MMFS that *might* be compatible with TurboMMC?
All it does is set PB[4:2] as outputs with values 010, which according to Duikkie's schematic should be all that's needed.
I haven't been able to test this as I don't have any TurboMMC hardware, so caveat emptor, and please don't try it on an SD Card containing any valuable data.
Here's the "highly experimental" ZIP:
mmfs_1_09_20160118_1744.zip
Edit: Deleted at it contains bugs that might cause output conflicts.
Anyone else, probably best stay away from this build for now. You have been warned!!! :shock:
duikkie
Post by duikkie » Mon Jan 18, 2016 6:05 pm
look at the source of j.3-drv first , it is not only open the outputs. because there is output and input on the same line
so you can blow-up your via. therefor the buffer enables and disable with data in the program
hoglet wrote:Stephen,
Post by hoglet » Mon Jan 18, 2016 6:11 pm
duikkie wrote:look at the source of j.3-drv first , it is not only open the outputs. because there is output and input on the same line
Do you mean two outputs on the same line?
Is it PB1 and CB1, or something else?
I think even the original MMBEEB implementation connects PB1 and CB1, which with mis-programming could both be outputs.
viewtopic.php?f=3&t=1919&start=540#p129317
Post by sweh » Mon Jan 18, 2016 6:21 pm
hoglet wrote:Would you be up for testing a version of MMFS that *might* be compatible with TurboMMC?
Ah, I love my UPURSFS code, it made this easy to test. Just unzip the file into the right tree then *UPURSFS followed by *SRLOAD MMFS 8000 F Q and it loads :-) I also *UNPLUG'd the TurboMMC ROM so your ROM was the only one that was trying to talk the card.
And it _seems_ to work. With the MMB file I'd created for the CPM tests I was able to *DCAT, *DIN 0 100 (an image that had the test program on), load and save files to that image. It worked with the copro on/off. I tested with MMFS and SWMMFS.
One oddity noted (that probably isn't TurboMMC related). SWMMFS on initial load gives "Bad sum" error; needs control-break to properly initialise. Then it worked.
I also tested SWMMFS with the Z80 copro. Pressing control-break didn't cause CPM to load properly. I got corrupted output and dropped to the * prompt. However from there I could run *CPM and it loaded fine, and inside CPM I could DIR and run BBCBASIC without issues. It's not clear to me why the first control-break failed; nothing showed up the indicate.
Post by sweh » Mon Jan 18, 2016 6:23 pm
Side note: subjectively MMFS felt _slower_ than TurboMMC; eg the initial "*." after control-break seemed to take a fraction longer, and *DCAT definitely took longer to complete.
duikkie
Post by duikkie » Mon Jan 18, 2016 6:23 pm
look at the schema :
if you enable 4 and 3 at the same time your dout of your sd card is connected to your din.
edit:
if cb2 is output and pb0 is allso out , it is not good if all buffers are open( enabled)
Post by hoglet » Mon Jan 18, 2016 6:27 pm
Excellent, and slightly surprising.
How much slower is it than TurboMMC?
sweh wrote: One oddity noted (that probably isn't TurboMMC related). SWMMFS on initial load gives "Bad sum" error; needs control-break to properly initialise. Then it worked.
I've seen that error before. I thought I had fixed it:
https://github.com/hoglet67/MMFS/commit ... e648403aeb
sweh wrote: I also tested SWMMFS with the Z80 copro. Pressing control-break didn't cause CPM to load properly. I got corrupted output and dropped to the * prompt. However from there I could run *CPM and it loaded fine, and inside CPM I could DIR and run BBCBASIC without issues. It's not clear to me why the first control-break failed; nothing showed up the indicate.
Control-break will reset the drive mappings. Are your CPM images on DIN 0/2?
duikkie
Post by duikkie » Mon Jan 18, 2016 6:30 pm
look at page 409/410 in the big book , how fast or slow SRMODE 0 is and SRMODE2 and SRMODE 6
Post by sweh » Mon Jan 18, 2016 6:37 pm
hoglet wrote:How much slower is it than TurboMMC?
Unscientific test...
10TIME=0
20*SAVE TST 1000+7000
30PRINT TIME
TurboMMC: 78. MMFS: 381
So a LOT slower.
Yes, 0 and 2. I did a bit more testing and I think it may be another initialisation issue...
control-break gives an error. At the * prompt I did *CPM and it hung. Repeated this 3 times. Then instead I did "*." followed by '*CPM" and it worked. So I wonder if calling OS7F before any "traditional" data transfer isn't initialising some data properly somewhere.
Post by hoglet » Mon Jan 18, 2016 6:41 pm
duikkie wrote: look at the schema :
I'm not enabling PB3 and PB4 at the same time.
All MMFS is doing is making sure that at all times:
- PB2 = 0
- PB3 = 1
- PB4 = 0
The result being that things are connected exactly as they would for the original MMBEEB hardware.
duikkie wrote: edit:
In MMFS, CB2 is never set as an output, so I think we are safe.
Post by hoglet » Mon Jan 18, 2016 6:48 pm
10TIME=0
30PRINT TIME
So a LOT slower.
Interesting, and not unexpected, as there is ~6 instructions per bit.
MMFS for the none TurboMMC is slightly faster (271).
Could you do a similar test for LOADing?
sweh wrote: Yes, 0 and 2. I did a bit more testing and I think it may be another initialisation issue...
Ah, that's very interesting. I'll see if I can reproduce.
Post by hoglet » Mon Jan 18, 2016 6:51 pm
duikkie wrote:look at page 409/410 in the big book , how fast or slow SRMODE 0 is and SRMODE2 and SRMODE 6
Yes, I see the difference. Thanks.
My initial target was just getting it working in the same way the original MMBEEB worked. i.e. no Turbo mode.
Post by sweh » Mon Jan 18, 2016 6:56 pm
hoglet wrote:Could you do a similar test for LOADing?
(write protection enabled on the SWR bank)
TIME=0:OSCLI "LOAD TST 2000":CLS:PRINT TIME
TuboMMC 67 vs MMFS 204
duikkie
Post by duikkie » Mon Jan 18, 2016 6:59 pm
if you do it right you can read as fast as turbo can read :) , SMART spi is a little slower because it calculates every time with pb lines to use not standaard pb0/pb1.
Post by hoglet » Mon Jan 18, 2016 7:03 pm
duikkie wrote:if you do it right you can read as fast as turbo can read :) , SMART spi is a little slower because it calculates every time with pb lines to use not standaard pb0/pb1.
But only with TurboMMC hardware, right?
I'll need to try to get hold of a TurboMMC board I think.
duikkie
Post by duikkie » Mon Jan 18, 2016 7:11 pm
no no :) , you don't need a turboboard (hardware) , i am not sure anymore but SRMODE2 is allso possible without a TURBO board. , that why SMART spi is fast in reading.
the only thing you need to do is use SRMODE2 to read, but you can't lose the hole SRMODE0 , it is all there in the source of smart spi (j.3-drv) , was a puzzle when to use SRMODE 0 /SRmode 2 and SRMODE 6 , you have to check if buffer is there then you can use SRMODE6 .
duikkie
Post by duikkie » Mon Jan 18, 2016 7:16 pm
look at 3-drv and learn dutch :D
viewtopic.php?f=2&t=9913
Post by hoglet » Mon Jan 18, 2016 7:20 pm
duikkie wrote:no no :) , you don't need a turboboard (hardware) , i am not sure anymore but SRMODE2 is allso possible without a TURBO board. , that why SMART spi is fast in reading.
OK, I agree now that all current hardware should be able to use SRMODE2 for "turbo" reading.
So the only benefit of the TurboMMC hardware is being able to use SRMODE6 for "turbo" writing, by reconfiguring the buffers.
So I think I'll have a play with SRMODE2 tomorrow. I'll also try to do it without learning dutch!
Thanks!
