WANTED: Slot-loading CD/DVD (Suit Phoebe case) [Sorted]
wanted ads for physical hardware, software + literature
Forum rules
You're welcome to trade Acorn-related stuff with other forum members here - the rule of thumb to follow when trading, is that items or services offered should be of interest to our Acorn community. Do NOT use multiple accounts - please trade with your regular (and only) forum account. If you're giving items away, please make it clear if you would be unhappy with the recipient selling on some or all of the items. Similarly, please ensure that the giver is comfortable with you re-selling items you have accepted as a gift. We cannot be held responsible for what happens in these trading forums or for deals done via PM. This must be done at your own risk. If you aren't comfortable with this - make the trade via an alternative site which can apply safeguards of their own. Be sensible - if someone approaches you to trade via PM who is not posting in the public forums, this may be a sign that they are not entirely what they seem. Please report it to the moderators if you receive an unsolicited message from anyone suspicious, so that it can be investigated and hopefully stop anyone being taken advantage of.
IanJeffray
Post by IanJeffray » Tue Aug 25, 2020 9:13 pm
Title says it all. I used to have one. I don't know what happened to it (Probably put in a PC then flogged). Now I have a hole to fill. IDE or SATA. Full size 5.25" bay, slot at the top, button at the right (ideally, but could bodge...)
biggles
Re: WANTED: Slot-loading CD/DVD (Suit Phoebe case)
Post by biggles » Mon Oct 05, 2020 11:27 pm
I believe the original Phoebe would have had a Sony CDU771 drive, which do occasionally come up on ebay. It means the light and button will line up without any hacking (other than figuring out how to mount it without the rails). I've never managed to find the DVD equivalent though - would be interested to know if anyone has!
There's a CDU771 available in the states at the moment, expensive postage though:
https://www.ebay.co.uk/itm/SONY-CD-ROM- ... SwH09ZHKs-
Post by RobC » Tue Oct 06, 2020 3:32 pm
This CDU571 should also fit (and was listed as to be used in Phoebe by some references): https://www.ebay.co.uk/itm/233505255260?var=0
IanJeffray
Post by IanJeffray » Tue Oct 06, 2020 9:06 pm
Thanks both. I was aware that CJE were selling a Phoebe case with a Sony drive not fitted / not confirmed, but hadn't dug up anything more firm to go on than that reference. The Phoebe specs don't state a brand. I'd been looking at Pioneer drives (I had a DVD-104S many years ago) as these look like they may have vaguely fitted -- and my eBay-fu was clearly useless as I'd been searching for any slot-loader for weeks without joy -- knowing the specific model numbers to look for sure helps - I'll grab one!
As for the rails - dang - I'd not noticed that. The Phoebe case I have at least has a floppy drive bracket and I found the perfectly-fitting Mitsumi drive for that. This sounds like a job for Mr 3D Printer! :)
Re: WANTED: Slot-loading CD/DVD (Suit Phoebe case) [Got - pending check!]
Post by RobC » Wed Oct 07, 2020 7:49 am
This mentions the Sony CDU571: https://armclub.org.uk/eureka/eureka42.pdf
This mentions the 771: https://www.4corn.co.uk/archive/misc/Ph ... 0Sheet.pdf
I have a 571 in my Phoebe case and it lines up correctly. However, as mentioned previously, fixing it in place without the original metalwork is a bit of a pain.
IanJeffray
Post by IanJeffray » Thu Oct 08, 2020 12:38 am
Coo - I'd never seen that before, that's great!
I also recently tripped on this site of the designer of the Phoebe case front....
https://devon3dcad.co.uk/acorn-computer ... -pc-tower/
IanJeffray
Post by IanJeffray » Thu Oct 08, 2020 12:49 am
And seeing the photos there reminded me of some old crap I have... these rails from a PC case I have/had appear to fit the Phoebe case really quite well. We'll see how it works out when the CDROM arrives -- looks like I may need to drill some holes, at least.
IanJeffray
Post by IanJeffray » Sun Oct 18, 2020 10:07 pm
So I received the Sony drive. And a visually identical Goldstar one!
The drive rails were drilled and fitted. Needs careful alignment of the slot, but ...
https://youtu.be/-s_k_HFiokY
\:D/
CJE-4D
Re: WANTED: Slot-loading CD/DVD (Suit Phoebe case) [Sorted]
Post by CJE-4D » Mon Oct 19, 2020 12:47 pm
Ian, did you get a Sony CDU771 or CDU571?
IanJeffray
Post by IanJeffray » Mon Oct 19, 2020 5:32 pm
I got the CDU571 as per the Phoebe spec. It's really almost impossible to tell the difference from the Goldstar CRD-7161B...
SONY CDU571 top, GoldStar CRD-7161B below.
Return to “wanted”
