FS: Slogger PCBs: Pegasus, Click, Stop Press etc
peddle your acorn wares here!
Forum rules
Re: FS: Slogger PCBs: Pegasus, Click, Stop Press etc
Post by 1024MAK »
Hi Dave
My cardboard box of bits arrived safely this morning :D
Thank you =D>
robinirvine
Post by robinirvine »
So OK Erm....., embarrassing admission :oops: , received my box of goodies yesterday and I truly felt like a 10 year old on Christmas day !!!!! :D :D
All good, now need to start working on gathering all the BOM’s. :wink:
Anyways thanks Mr Arcadian
Regards, Robin Irvine
_________________________
Acorn Electron 32k (Iss 4)
& Slogger Turbo-Driver Board
& Slogger ROMBox+ & Plus 3
& A heap 'o' ROM's
jms2
Post by jms2 »
Got mine as well a couple of days ago... many thanks Dave! :D
Post by danielj »
Word to the wise for anyone who picked up a turbo driver:
The turbo driver won't fit if you socket the 6502!
Post by daveejhitchins »
danielj wrote:Word to the wise for anyone who picked up a turbo driver:
Would either of these help?
viewtopic.php?f=8&t=6089
p.s. I've a Turbo Board but have not had time to look-at-it-yet :roll:
Post by danielj »
No, it's if you socket mount the 6502 on the turbo driver. It's all rather tight. I just ended up soldering it direct to the board (and even then I had to snip the tops of the header pins beneath it flush with the pcb to get it to sit nicely). Works perfectly though, the PAL gets a little warm...
I'll nab some header pins off you though, always useful. See PM :)
danielj wrote:Works perfectly though, the PAL gets a little warm....
GALs run a little cooler . . . Fancy trying one out? (I can slip a couple in with strips - Can you program?) I think I heard some saying they had the contents decoded?
Post by danielj »
Hmm... Don't think so unless this old willem I have won't deal with them. I have my eyes on a VP290 as soon as I scrape the readies together. I haven't noticed anyone saying they've decoded it?I can't imagine it's that complicated.
Post by Prime »
AllanD decoded them a couple of years ago, a some of them where flakey, I'll dig the equations out tomorrow and post them.
danielj wrote:Hmm... Don't think so unless this old willem I have won't deal with them. I have my eyes on a VP290 as soon as I scrape the readies together. I haven't noticed anyone saying they've decoded it?I can't imagine it's that complicated. d.
The Wellon doesn't support PLDs either! GAL are supported, however. I have a VP-880 (went obsolete two weeks after I bought it ](*,) ) and was most disappointed, they won't even READ PLDs. You wouldn't have thought it would be that difficult? I suppose they have to draw a line somewhere!
Post by danielj »
ARgh. chip-programming-minefield. In the realms of my tinkering would I ever find myself in a situation where I'd need to use a PAL rather than a GAL? There are a whole set of GALs that are just drop-ins for the early PALs aren't there?
danielj wrote:ARgh. chip-programming-minefield. In the realms of my tinkering would I ever find myself in a situation where I'd need to use a PAL rather than a GAL? There are a whole set of GALs that are just drop-ins for the early PALs aren't there?
Just depends how many you found in the loft :oops: And, how many you used as 'masters' for your firmware :oops:
AlanD
Post by AlanD »
Hello All
heres my PAL for slogger turbo its has been used by myself and i seem to remember giving it to Phil HS some while back
i used an ATMEL - ATF16V8
this will build with wincupl
Name AlanD ;
PartNo 00 ;
Date 31/10/2009 ;
Revision 01 ;
Designer Alan Daly ;
Company home ;
Assembly None ;
Location None ;
Device g16v8a;
/* Acorn Electron Turbo Board PLD */
/* Inputs: */
Pin 1 = romoein;
Pin 2 = upa15;
pin 3 = upa14;
pin 4 = upa13;
pin 5 = turbo; /* turbo mode low -- normal mode high */
pin 6 = phiout;
pin 7 = upRnW;
pin 8 = ipirq;
pin 9 = upnmi;
pin 11 = upphiin;
/* Outputs: */
Pin 12 = uprdy;
Pin 13 = ramp1;
Pin 14 = ramnoe;
Pin 15 = ramnwe;
Pin 16 = ulaa15;
Pin 17 = ulaa14;
Pin 18 = ramce2;
Pin 19 = romoeout;
/* (!(turbo # upa13 # upa14 # upa15)) = 1 -- when in turbo and first 8K */
$DEFINE TURBOACTIVE (!(turbo # upa13 # upa14 # upa15))
/* Logic equations */
/* this line does nothing other than use unsed signals*/
ramp1 = uprdy # phiout # ipirq # upnmi # upphiin;
/* the real equations*/
ramnoe = turbo # upa13 # upa14 # upa15;
ramnwe = upRnW;
ulaa14 = (!(turbo # upa13 # upa14 # upa15)) # upa14;
ulaa15 = (!(turbo # upa13 # upa14 # upa15)) # upa15;
ramce2 = (!(turbo # upa13 # upa14 # upa15));
romoeout = (!(turbo # upa13 # upa14 # upa15)) # romoein;
/* Logic: examples of simple gates expressed in CUPL */
/* inv = !a; inverters */
/* and = a & b; and gate */
/* nand = !(a & b); nand gate */
/* or = a # b; or gate */
/* nor = !(a # b); nor gate */
/* xor = a $ b; exclusive or gate */
/* xnor = !(a $ b); exclusive nor gate */
slogger turbo.zip
(803 Bytes) Downloaded 126 times
ATB
AlanD
Post by danielj »
Thanks Alan, I'll try and gal-i-fy this and see if my turbo driver diminishes in toastiness!
Also good to know this as I'm not sure if all the turbo driver boards that Arcadian shipped had the PAL in already and they're pretty much useless without it.
TheCorfiot
Post by TheCorfiot »
I have just ordered 10 GAL 16V8B Atmel chips which I will program if anyone wishes to change their PAL's for a GAL or is just missing the chip.
Cheers for uploading the code Alan.
Site Admin
Post by Arcadian »
Right, got back home from GEEK in the early hours, so I'll finally be able to get the 3-4 packages sent that have been outstanding since last week.
Thanks for posting your Turbo source for the PAL, Alan! :)
TheCorfiot
Cheers Dave, got my turbo driver today..
Havent been able to get it working yet though lol....
Elk acts as if no 6502 is inserted but all continuity tests to the mobo and turbo board are fine..
Have replaced the 6264 and CPU to no avail...
The PAL does warm up nicely as expected....
Will persevere with it though...
Post by danielj »
That's really odd :? Mine's working fine - there's almost nothing to go wrong with them. PAL fried?
Post by Prime »
danielj wrote:That's really odd :-/ Mine's working fine - there's almost nothing to go wrong with them. PAL fried?
That is possible, when I got mine a couple of years back I had to use Alan's reverse engineered PAL code to program a new PAL/GAL (ATF16V8B IIRC).
TheCorfiot
Cheers Phill,
It's the only device left on the board not replaced.
I have some Gal's arriving soon, hope my G540 programmer can manage them as it does list the devices...
AlanD
Post by AlanD »
Hello All
@danielj I fitted somewhere around 20 of these to ELKS for Arcadian (Dave) a couple of years ago i'm guessing these boards are out of the same box (correct me if i'm wrong Dave). At that time some boards had no PAL fitted and of those that did a significant number did not work .My guess was that some of the PALS where either programmed incorrectly or just blank. Phil HS also experienced same PAL issues i think.
P.S.
if you suspect your PAL has failed and you remove it you can test the rest of the board by temporarily linking the following pins in place of the PAL this will make your turbo board run in normal mode but it proves the 6502 is ok and the ELK motherboard is OK
feed thru A14,A15 and ROM enable
Pin 1 = romoein; to Pin 19 = romoeout;
Pin 2 = upa15; to Pin 16 = ulaa15;
pin 3 = upa14; to Pin 17 = ulaa14;
Remove RAM Chip or Disable with following two links
Pin 14 = ramnoe; to PIN 20 VCC
Pin 18 = ramce2; to PIN 20 VCC
ATB :D
AlanD
TheCorfiot
Hi Alan, thank you very much for your kind input..
I have downloaded your pld file and should be recieving the gal's in the next few days..
I have a Genius G540 programmer which claims to be able to program the devices but I am somewhat confused regarding the file type I should load your pld file into the buffer.
Selcting bin file does show up your ascii (c) messages in the buffer..
Any help or guidance would be appreciated as if I am successful I would be happy to send replacement chips out to anyone who needs one.
Post by danielj »
TheCorfiot wrote:Hi Alan, thank you very much for your kind input..
You need to compile it with wincupl (free download from ATMEL) into a jedec (.jed) file. That can then be written into the GAL :)
TheCorfiot
Now that makes sense lol.
AlanD
Post by AlanD »
Hello All
heres the vector file if you don't have wincupl
this archive contains the vector jed file.zip
(651 Bytes) Downloaded 142 times
AlanD
Post by danielj »
Works a treat Alan. Feels about half as hot as the PAL did in mine.
AlanD
Post by AlanD »
Hello Daniel
Another satisfied customer =D>
AlanD
danielj wrote:Works a treat Alan. Feels about half as hot as the PAL did in mine.
daveejhitchins wrote:GALs run a little cooler . . . Fancy trying one out?
Love it when a plan comes together :D
Post by danielj »
Trufax - and thanks to you Dave!
guddler
Post by guddler »
Did my parcel get sent yet? The posties been somewhat absent so far :)
Return to “for sale / freebies”
