For sale: RGBtoHDMI boards
peddle your acorn wares here!
Forum rules
IanB
Re: For sale: RGBtoHDMI boards
Post by IanB » Sun Sep 13, 2020 8:34 pm
I'll be sending out the boards over the next couple of weeks in batches, kits first as I have to finish building the others.
I'll PM you when your boards are ready to go.
sixedup
Post by sixedup » Mon Sep 14, 2020 12:04 am
Sigh ... late to the party as I was on vacation. If you are still open to orders, can I have 1 x RGBtoHDMI board for my BBC please? Fully built by preference, but will take a kit as long as the SMD is already done (my soldering has limitations!)
Richard
IanB
Post by IanB » Mon Sep 14, 2020 6:37 pm
I've added some kit assembly instructions to the wiki:
https://github.com/hoglet67/RGBtoHDMI/w ... mbly-Notes
CommanderCoder
Post by CommanderCoder » Sun Sep 20, 2020 11:06 pm
I'm interested in buying at least one RGBtoHDMI board for my newly repaired set of vintage computers: In particular to get colour on my Acorn Atom. So an Analogue board too.
I have a EACA Video Genie (TRS80 Model I clone) which I think might be an interesting test for the board too.
1xAnalogue Board (built)
1xRGBtoHDMI board (built)
Thanks.
marcusjambler
Post by marcusjambler » Tue Sep 22, 2020 8:22 am
Hi Ian
Please put me down for the second batch.
1 x RGBtoHDMI kit
1 x Analog board kit
Marcus
sixedup
Post by sixedup » Fri Sep 25, 2020 9:18 pm
Hi Ian,
Minor change of plan; rather than just going for 1 x RGBtoHDMI board (built), can I go for:
1 x RGBtoHDMI (built if possible)
1 x Analog board (built if possible)
Makes sense to future proof myself :-)
Richard
IanB
Post by IanB » Sat Sep 26, 2020 3:02 pm
I think all those that have paid so far should have received their boards so let me know if you didn't.
rodders
Post by rodders » Sun Sep 27, 2020 7:53 am
Hi Ian,
Can you put me down for 1x RGBtoHDMI kit please.
Rod
BBC Model B 32k ICL issue 3, WE ROM/RAM board, Speech Processor, TurboMMC, PiTubeDirect
BBC Master 128
Mince
Post by Mince » Wed Sep 30, 2020 5:57 pm
Hello, if there are still some in the second batch, could you put be down for 1x RGBtoHDMI built, with no analogue board, thanks!
sota
Post by sota » Wed Sep 30, 2020 7:27 pm
Hi Ian,
Can you put me down for one RGBtoHDMI board please.
Thanks!
Pat
nelgin
Post by nelgin » Thu Oct 01, 2020 8:23 pm
Add me please. I'm in the US and just got a UK BBC B but want to run it with my HDMI monitor. Let me know how much you want and the cost of shipping for a fully assembled kit please.
Thanks,
Nigel
sjo03
Post by sjo03 » Fri Oct 02, 2020 1:20 am
Can you please add me for two build boards ? One with analog and one without (for my bbc and for the spectrum).
Thank you so much! Johan
billcarr2005
Post by billcarr2005 » Sat Oct 03, 2020 10:29 am
I'd also like a built RGBtoHDMI, should there be one available!
Am I correct in thinking I'd also *just* need the RPi Zero WH (with memory card) and case then it'd be ready to run?
Site Admin
Post by Arcadian » Sat Oct 03, 2020 1:56 pm
You just need a regular Pi Zero I think, not W, not WH.
Mince
Post by Mince » Sat Oct 03, 2020 9:17 pm
You don't need the W, but you do need the header, I don't think I had one supplied with my first one (the RGBtoHDMI). If you buy a non-H version, you need to get one and solder it on yourself.
If you want the reset button to work, you'll need to solder on a small two-pin header onto your Pi Zero, next the main header. The two-pin header is supplied with the RGBtoHDMI kit.
KenLowe
Post by KenLowe » Fri Oct 16, 2020 8:16 pm
Just getting around to soldering up my boards now. I've had a quick read through the assembly instructions, but didn't see anything about the direction of the 2 x resistor networks. I assume you're using normal convention, and the common leg on the resistor network (the end with the dot) goes into thru hole with the square solder pad? Sorry if this is written somewhere, but I missed it.
Post by danielj » Fri Oct 16, 2020 8:43 pm
Marked pin on board (square around it) = pin 1 = pin with dot on network.
IanB
Post by IanB » Sun Oct 25, 2020 11:55 pm
FYI I've ordered another batch of boards which should be available in a couple of weeks or so.
Also I've noticed that there are two different versions of the case and one is not really suitable for use with RGBtoHDMI.
This is the correct one:
https://www.ebay.co.uk/itm/1Pcs-Black-P ... 3762548529
It has M2.5 machine screws and large plastic support pillars that can take the metal spacers.
This is the unsuitable one:
https://www.ebay.co.uk/itm/Plastic-Prot ... 3549857517
This has self tapping screws and very thin support pillars.
You can make this case work but you have to drill out the plastic pillars to take the metal spacers and buy M2.5 machine screws to fit in the top of the spacers.
When looking at other listings, please check that any photos showing the screws and pillars match the first one above
DaveLecky
Post by DaveLecky » Mon Oct 26, 2020 11:18 am
Hi Ian,
Can you remind us of the price please, it’s been removed from post 1.
Electron Plus 3 and plus 1, AP6 and Home made MMFS PP SD interface
Electron Plus 1 Pres AP3/4
Beeb issue 7 with IFEL 16 socket Rom/Ram board
Master 128, BooBip multi OS,IFEL SD card
StrongA RPC, A3020
Atom
Richard Hallas
Post by Richard Hallas » Wed Oct 28, 2020 11:33 am
Hi Ian,
As discussed on the other thread about my monitor (viewtopic.php?f=3&t=20871), I'm very keen to get one of your next batch of RGBtoHDMI boards, please.
I just need one, and I don't think I need the analogue option. Thanks very much.
Richard Hallas
Former editor of RISC User and Foundation RISC User magazines
Designer of the RISC OS cogwheel logo • Designer of the RISC OS 5 icon set
IanB
Post by IanB » Wed Oct 28, 2020 5:44 pm
It should be around £30 for the built ones and a few pounds less for the kit ones as most of the parts are already fitted on this new 12 bit batch but I haven't finalised things yet.
noggin
Post by noggin » Mon Nov 02, 2020 2:58 pm
I'd like to sign up for a fully built board please and an analogue interface if they are still available.
tarcus69
Post by tarcus69 » Mon Nov 02, 2020 6:29 pm
Can I get 3 fully builts and one analogue please? Thanks.
Pepperm
Post by Pepperm » Tue Nov 03, 2020 11:28 am
Hi
I would love the 2 board solution, I have many Pi zeros. How do I go about getting them ordered please?
Regards
billcarr2005
Post by billcarr2005 » Tue Nov 03, 2020 12:58 pm
Reiterating my desire to own one of the next batch... i can worry about getting the RPi Zero later :)
Pepperm
Post by Pepperm » Thu Nov 05, 2020 10:37 pm
Hi
How do I get my hands on an RGB to HDMI adaptor please? I see that there are some for sale in Australia but I am in the UK...
Regards
IanB
Post by IanB » Fri Nov 06, 2020 12:12 am
Just post in this thread as you have already done, you will be contacted by PM when some new boards are available probably in the next week or so.
roobarb!
Post by roobarb! » Fri Nov 06, 2020 3:00 am
Hey @IanB, could I add myself to the list of interested folk, please? :)
BBC Model B - 32K, Issue 4, IFEL RAM/ROM, Speech System, Turbo MMC
A3010 - Unknown condition, hiding in the loft!
Risc PC - Fine last time I saw it!
chrissawer
Post by chrissawer » Fri Nov 06, 2020 10:30 am
I am also interested in 1x RGB kit for the next batch, please add me to the list. Thanks!
ryanm
Post by ryanm » Fri Nov 06, 2020 5:06 pm
Hi Ian.
I would like one built RGBtoHDMI board for my Model B+ BBC Micro.
Thanks so much.
Return to “for sale / freebies”
