FS: Econet Podule - all gone
peddle your acorn wares here!
Forum rules
IanS
Post by IanS » Thu Aug 13, 2020 5:31 pm
I have 4 basic Econet podules for sale. You will need a standard econet module to make use of these (or the patience to solder in all the other components).
With module fitted (module not included)
£20 + postage at cost.
Any takers?
1. 8271
2. danielj
3. Boydie
4. BeebMaster
5. 8271
6. dangardner
7. Rod C
8. sP1d3r
9. carcher
10. robheaton
Re: FS: Econet Podule
Post by 8271 » Thu Aug 13, 2020 6:20 pm
Two please !
Serial computer hoarder & econetophile
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
Post by danielj » Thu Aug 13, 2020 7:23 pm
One please! :)
Boydie
Post by Boydie » Thu Aug 13, 2020 7:24 pm
One please
Post by BeebMaster » Thu Aug 13, 2020 7:29 pm
I'd like one if there are any more available.
Does it need the modified Econet software or the "original"?
Post by 8271 » Thu Aug 13, 2020 7:56 pm
I will take one and let Ian (beebmaster) take the other that I jumped on ..... (Will take a second one out of the next batch though!)
IanS
Re: FS: Econet Podule - all gone
Post by IanS » Thu Aug 13, 2020 10:18 pm
Ok, the first 4 have now been allocated, I'll send out some PM's asking for payments when I work out the postage (not sure I can get them in a large letter the socket is quite thick)
IanS
Post by IanS » Sat Aug 22, 2020 12:44 am
OK, I've got another 4 up for grabs.
Post by Rod C » Sat Aug 22, 2020 2:36 am
Hi Ian
I would like one of these please.
Rod
sP1d3r
Post by sP1d3r » Sat Aug 22, 2020 8:37 am
Hi Ian
Can I have one please, a kit of parts without the 5-pin DIN would be good for me.
dangardner
Post by dangardner » Sat Aug 22, 2020 10:28 am
I'd like one please.
carcher
Post by carcher » Sat Aug 22, 2020 10:47 am
Hi Ian,
Could I buy a podule please - if there is one still available?
Thanks,
Chris
IanS
Post by IanS » Sat Aug 22, 2020 11:36 am
Why a kit?
robheaton
Post by robheaton » Sat Aug 22, 2020 11:38 am
Hi Ian,
I'm interested in one of these, if available.
Rob.
IanS
Post by IanS » Sat Aug 22, 2020 11:52 am
All gone, (depending on sP1d3r taking a built unit).
sP1d3r
Post by sP1d3r » Sat Aug 22, 2020 4:02 pm
Why a kit?
Hi Ian
Thanks for allocating me a podule, -
I meant that a kit would be less bother than assembling and packaging a podule from your point of view and also cost less to post.
If you've made up the podules with particular members in mind, I'd take a kit to assemble if you've got the parts. (I like assembling PCB's)
anightin
Post by anightin » Sat Aug 22, 2020 4:14 pm
If there is another batch at some point I would like a couple of these please.
Many thanks
Andy
IanS
Post by IanS » Sat Aug 22, 2020 5:42 pm
Why a kit?
I don't list them for sale until they are buit and tested. Do you still want a built one? (You will need an econet module to get it working)
sP1d3r
Post by sP1d3r » Sun Aug 23, 2020 7:09 am
Hi Ian
Can you PM me with details of what you have available please?
Although I have an Econet module, I'd like to build the PCB clock, econet and termination.
Much appreciated :D
stevebubs
Post by stevebubs » Thu Aug 27, 2020 6:12 pm
I have a couple of RPCs that could do with these cards being installed.. So if you have another batch or 2, I'd be interested in 1 or 2 cards.
S
sP1d3r
Post by sP1d3r » Wed Sep 02, 2020 8:05 am
Hi Ian, is there a parts list for the complete module, please?
sP1d3r
Post by sP1d3r » Wed Sep 02, 2020 8:41 am
#-o I've found the econet podule zip file in the Re: Econet podule for RISC PC & A7000 thread with the XML document, btw so no problems.
Post by BeebMaster » Wed Sep 02, 2020 9:53 am
I'm planning to fit the Econet interface components to the Podule, so last night I found the XML file with all the component information as well and put it in a table, attached. N.B. it's only the Econet interface components, not the Podule circuitry or the clock/terminator.
Econet Podule Components.pdf
(31.81 KiB) Downloaded 12 times
Post by BeebMaster » Wed Sep 02, 2020 10:07 am
Just noticed that R24 to R29 are for the Clock and Terminator, so not needed if only fitting the Econet interface.
sP1d3r
Post by sP1d3r » Wed Sep 02, 2020 3:07 pm
:!: A small pcb for programming the ATTiny is also required, unless it can be programmed after it's fitted into the podule.
I believe that the Arduino IDE would work for this.
ATTiny usb programmer
IanS
Post by IanS » Wed Sep 02, 2020 3:20 pm
J5 is the programming header on the podule. There is a jumper to isolate the power (J7) so the programmer won't try and power the whole circuit.
Post by BeebMaster » Wed Sep 02, 2020 5:09 pm
I didn't have any axial caps or any suitable for decoupling, so whilst waiting for them to arrive, I've put the rest of the components on the board. Looking good, even if I say so myself:
Post by BeebMaster » Thu Sep 03, 2020 10:50 pm
Finished it today.
Working well, although my Cumana SCSI podule doesn't like it...
IanJeffray
Post by IanJeffray » Thu Sep 03, 2020 11:51 pm
Know-nothing suggestion: Have you tried moving the podules around? I have a Morley SCSI card that gets very upset at having an Atomwide Ether3 in the same machine unless the Morley is in podule slot 2. Not sure if it's module initialisation order or what, but maybe worth a quick try? I'm sure IanS will have a better response.
Post by BeebMaster » Fri Sep 04, 2020 10:23 am
I think I did that...I tried several things. There are only 2 podule slots to play with and the Econet podule definitely works in either, but not with the Cumana podule. If unplug all the Cumana podule's modules it doesn't help. However if I take the actual ROM out of the socket on the podule then the RPC boots up fine.
