FS: Raspberry Pi to 1MHz bus interface
peddle your acorn wares here!
Forum rules
You're welcome to trade Acorn-related stuff with other forum members here - the rule of thumb to follow when trading, is that items or services offered should be of interest to our Acorn community. Do NOT use multiple accounts - please trade with your regular (and only) forum account. If you're giving items away, please make it clear if you would be unhappy with the recipient selling on some or all of the items. Similarly, please ensure that the giver is comfortable with you re-selling items you have accepted as a gift. We cannot be held responsible for what happens in these trading forums or for deals done via PM. This must be done at your own risk. If you aren't comfortable with this - make the trade via an alternative site which can apply safeguards of their own. Be sensible - if someone approaches you to trade via PM who is not posting in the public forums, this may be a sign that they are not entirely what they seem. Please report it to the moderators if you receive an unsolicited message from anyone suspicious, so that it can be investigated and hopefully stop anyone being taken advantage of. This forum is not for advertising items you have for sale on ebay or other third party marketplaces.
KenLowe
Post by KenLowe » Tue Mar 17, 2020 11:26 pm
UPDATE: Please be aware that I am no longer offering, as standard, a separate remote 1MHz level shifter with header pins. For those who want to use the 1MHz level shifter remotely, a couple of cable solutions exist using what is now the standard under keyboard level shifter. The post below has been updated to reflect this change. However, whist I still have some boards without the headers soldered on yet, I can offer these as non-standard on request. There will be no additional cost for this.
Intro
If you have been following this thread, you will be aware that I have been designing a level shifter board that allows a Raspberry PI Zero, 3B or 4 to be interfaced with the BBC / Master 1MHz port. This allows various pieces of hardware to be emulated on the Raspberry PI. Currently, the following hardware is emulated:
  • ADFS Harddisc (BeebSCSI implementation)
  • Music 5000 / 3000 (with audio playback through the beeb / master internal speaker)
  • Expansion RAM
The Raspberry PI software has been developed by forum member dp11. Further details and firmware download can be found on his github page here.
If interested in purchasing one of these boards, then please either reply to this thread, or drop me a PM with your specific requirements, and I'll be back in touch.
The standard 'under keyboard' level shifter board
The level shifter board is designed to be plugged directly into the 1MHz port on the underside of the beeb / master. A Raspberry PI Zero, or ZeroW can then be plugged into the level shifter 40 pin header, and everything will sit nicely within the well under the keyboard.
Standard 1MHz Level Shifter
Installed under keyboard
Remote Installation Options
There are a couple of different ways to connect the standard 'under keyboard' level shifters remotely to an external RPi. Both options are equally good, but my recommendation would be to go for the Female / Female cable + small adaptor board; particularly if you're going to mount it in a case as the pins come to the edge of the case and allow the cable to be unplugged quite easily. It's also a slightly cheaper option, however, it does add some 'bulk' to the whole arrangement, and if you're not using a case, the Female / Male solution may look more elegant. It really is end user preference!
DO NOT TRY TO MAKE A FEMALE / MALE CABLE BY JUST PLUGGING HEADER PINS INTO THE SOCKET OTHERWISE BADNESS WILL OCCUR. THE UPPER AND LOWER PINS GET SWAPPED IF YOU TRY TO DO THIS, AND YOU COULD DAMAGE YOUR LEVEL SHIFTER OR THE BEEB.
Using a Female / Male cable
The first photo shows the male connector plugged into the level shifter, and the cable coming out the 'rear' of the case. The second photo shows the ribbon cable coming out the front and under the case. The photos also show the 1MHz unit with a power cable plugged into the 'rear', which is used to power the 1MHz RPi and level shifter.
Female / Male ribbon - rear exit
Female / Male ribbon - front exit
Using a standard Female / Female cable + small adaptor board
With this option the cable comes out the 'rear' of the case. The 1MHz unit also has a power cable plugged into the 'rear', which is used to power the 1MHz RPi and level shifter.
Female / Female ribbon with adaptor
Powering the level shifter and Raspberry PI
Please note that it is necessary to provide power to the level shifter board, as power is not available from the 1MHz bus. Various power options are available.
  • If mounting remotely, then you should power the Raspberry PI directly from a standard micro USB (or USB C for the RPi 4) power supply. The level shifter board will then draw power from the Raspberry PI power supply.
  • If plugging the board directly into the 1MHz port on the underside of the computer, then the preferred method is to pick up power from either the user port, or the tube port. A short cable will be supplied for this purpose. If both of these ports are in use, then an alternative 5v power source will need to be found. If using PiTubeDirect in the tube port, then I have designed a level shifter board for this port that has a pass through power connector, which will allow you to pick up power from the tube port, whilst still being able to use the port for PiTubeDirect. Details of this board are available in the next post below. The RPi Zero(W) will then be powered from this power source.
Power from Tube Port
Power from User Port
1MHz level shifter powered from Tube level shifter
Pricing
  • Cost for standard 'under keyboard' level shifter is £15. This includes UK P&P. Please add £1.50 for postage to Europe and £2.50 for postage elsewhere.
  • For remote mount, I can supply a standard female / female ribbon cable (approximately 80cm) and small adaptor board, all for £7.
  • Alternatively, I can supply a female / male ribbon cable (approximately 80cm) for £8. Note however, that I have very limited stock of the male connector.
Please note that the Raspberry PI is not included, and you will need to source this separately (along with microSD card, and power supply if using remotely).
Acknowledgments - Please send me a PM if anyone else needs to be added to this list for their contributions
dp11 - for the original 1MHz bus level shifter concept, for the software & for helping to test
hoglet - for PiTubeDirect, and for helping to test
BigEd - for PiTubeDirect
simoni - for the original BeebSCSI code
KenLowe
FS: Raspberry Pi to Tube bus interface
Post by KenLowe » Tue Mar 17, 2020 11:27 pm
UPDATE: Please be aware that I am no longer offering, as standard, a separate remote Tube level shifter with header pins. For those who want to use the Tube level shifter remotely, a couple of cable solutions exist using what is now the standard under keyboard level shifter. The post below has been updated to reflect this change. However, whist I still have some boards without the headers soldered on yet, I can offer these as non-standard on request. There will be no additional cost for this.
Intro
As well as the 1MHz level shifter, I also have a number of tube level shifters available for sale. The tube level shifter is designed to work with the Raspberry PI, and PiTubeDirect software to emulate the following co -processors:
  • fast 65C02 (*FX 151,230,0)
  • 3MHz 65C02 (*FX 151,230,1) (for games compatibility)
  • fast 65C102 (*FX 151,230,2)
  • 4MHz 65C102 (*FX 151,230,3)
  • 112MHz Z80 (*FX 151,230,4)
  • 63MHz 80286 (*FX 151,230,8)
  • 27MHz 6809 (*FX 151,230,9)
  • PDP-11 (*FX 151,230,11)
  • 59MHz ARM2 (*FX 151,230,12)
  • 35MHz 32016 (*FX 151,230,13)
  • null co-pro (*FX 151,230,14) (to save having to power off the PI)
  • 1000MHz ARMnative (*FX 151,230,15)
  • 64KB Normal 65C02 (lib6502) (*FX 151,230,16)
  • 256KB Turbo 65C02 (lib6502) (*FX 151,230,17)
  • OPC5LS (*FX 151,230,20)
  • OPC6 (*FX 151,230,21)
  • OPC7 (*FX 151,230,22)
This level shifter includes a special power pass through connector which allows the 1MHz level shifter to be powered via the Tube port, whilst retaining the functionality of PiTubeDirect on the Tube port.
The Raspberry PI software has been developed by forum members hoglet, BigEd and dp11. Further details and firmware download can be found on hoglets github page here.
The level shifter board is designed to be plugged directly into the Tube port on the underside of the beeb / master. A Raspberry PI Zero, or ZeroW can then be plugged into the level shifter 40 pin header, and everything will sit nicely within the well under the keyboard.
Tube Level Shifter - Under beeb option
Similar to the 1MHz bus level shifter, there are two different ways to connect the standard 'under keyboard' Tube level shifters remotely to an external RPi:
  • Firstly via a standard female / female ribbon cable and small adaptor board.
  • Secondly, via a female / male ribbon cable.
Both options are equally good, but my recommendation would be to go for the standard Female / Female cable + small adaptor board; particularly if you're going to mount it in a case as the pins come to the edge of the case and allow the cable to be unplugged quite easily. It's also a slightly cheaper option, however, it does add some 'bulk' to the whole arrangement, and if you're not using a case, the Female / Male solution may look more elegant. It really is end user preference!
Pricing
  • Cost for standard 'under keyboard' Tube level shifter is £12. This includes UK P&P. Please add £1.50 for postage to Europe and £2.50 for postage elsewhere.
  • For remote mount, I can supply a standard female / female ribbon cable (approximately 80cm) and small adaptor board, all for £8.
  • Alternatively, I can supply a female / male ribbon cable (approximately 80cm) for £9. Note however, that I have very limited stock of the male connector.
Please also note that I can supply a further non standard Tube level shifter with a special 26 pin header, which allows the level shifter to interface with older Raspberry PIs that have a 26 pin GPIO header. No components need to be removed from these older Raspberry PIs if using this special 26 pin header, and the level shifter will still be compatible with later Raspberry PI models with 40 pin GPIO headers. Please contact me for details.
hoglet, dp11 & BigEd - for developing the PiTubeDirect project, including the software and level shifter
KenLowe
Re: FS: Raspberry Pi to 1MHz bus interface
Post by KenLowe » Tue Mar 17, 2020 11:28 pm
This post will list all noted interest and current progress. It will be updated regularly. If your status looks wrong, please let me know...
Key:
U: Underside
R: Remote
RC: Remote & Female / Female Ribbon Cable
UCA: Underside with Female / Female Ribbon Cable & Adaptor
UCB: Underside with Female / Male Ribbon Cable
Completed
User 1MHz Tube Status
tucker 1U - Posted 02/04
marcusjambler 1U 1U Posted 19/03
tricky 1U 1U Posted 19/03
mr-macrisc 1U - Posted 21/03
th3bar0n 2U 2U Posted 22/03
Stewie66 1U - Posted 27/03
CJS 1U - Posted 19/03
awilliams 1U - Posted 19/03
markrwj 1U + 1RC 1U Posted 21/03
rharper 1U - Posted 20/03
Rod C 1U 1U Posted 19/03
Alan00 1U + 1R - Posted 24/03
roganjosh 1R - Posted 25/03
Remklep 2U - Posted 19/03
1024MAK 2U 2U Posted 21/03
Kazzie - 1U Posted 20/03
Wheel_nut - 1U Posted 22/03
aotta 2U 1U Posted 22/03
IanB 2U 2U Posted 23/03
dominicbeesley 1R - Posted 23/03
mph1708 1U + 1R 1U Posted 24/03
BCCweirdo 1U - Posted 15/04
tone76 1U 1U Posted 23/04
Boydie 1U + 1R 1U Posted 19/04
DaveLecky 1U 1U Posted 14/04
shakesc 1U - Posted 14/04
crowly 1U - Posted 15/04
egel 1U + 1RC 1U Posted 15/04
jimmy 1U 1U Posted 16/04
anightin 1U 1U Posted 14/04
PJ via email 2U 2U Posted 18/04
trixster 2U 2U Posted 29/04
Simon 1U - Posted 17/04
JW via Facebook 1U 1U Posted 19/04
cr12925 1U - Posted 03/05
BeebMaster 2U - Posted 06/05
cr12925 - 1U Posted 07/05
aotta 1U 1U Posted 08/05
chrisa 1U 1U Posted 08/05
RobC 2RC - Posted 09/05
moose 1UCA 1UCA Posted 09/05
Knuckx 1U - Posted 19/05
Hopper 1U - Posted 20/05
roobarb! 1U 1U Posted 20/05
hubertn 2UCB 1U Posted 29/05
Lardo Boffin 1UCB - Posted 31/05
MR via Facebook 1UCB - Posted 31/05
dudleysoft71 1U - Posted 31/05
Steve3000 1U - Posted 01/06
In progress
DamienSturdy 1 - Await response
jms 1U 1U Await response
Seldon2k 1U + 1R 1U + 1R Await response
Followed up 06/05
anightin
Post by anightin » Wed Mar 18, 2020 7:06 am
Hi Ken,
I would be interested in 1 each of Tube and 1MHz boards (non-remote option) please.
Many thanks
Andy
DaveLecky
Post by DaveLecky » Wed Mar 18, 2020 8:54 am
Hi Ken,
I have already noted my interest in a pi tube interface, but would also like now to note interest in a option 1 underside install for the 1Mh bus please.
Ta
Electron Plus 1 Pres AP3/4 with drive
Beeb issue 7 with IFEL 16 socket Rom/Ram board, IFEL SD card, Floppy interface
Cumana drives,Adder Programmer
Boydie
Post by Boydie » Wed Mar 18, 2020 2:22 pm
Please can I clarify my interest - 1 each of the underside 1MHz and Tube, and 1 remote 1MHz (so same overall total as before).
Post by Kazzie » Wed Mar 18, 2020 2:53 pm
If stocks last, I'd like to express an interest in an underside tube shifter. Thanks.
mph1708
Post by mph1708 » Wed Mar 18, 2020 7:25 pm
I too would like to clarify my previously stated interest for 2 x 1 Mhz units.
As 1 x underside 1MHz unit and and 1 x remote 1MHz please.
If possible I would add 1 x underside Tube unit to the list too.
Regards
Mike
aotta
Post by aotta » Wed Mar 18, 2020 7:38 pm
I confirm my interest, but please consider the underside version for my wanted adapters (it's not specified in the list now..).
Thank you Ken
KenLowe
Post by KenLowe » Wed Mar 18, 2020 8:38 pm
Okay folks. Hopefully I've captured everyones requirements to date. Let me know if I've missed your post.
I've placed a line part way down the list to indicate those who I've been in contact with. Those below the line will need to wait until I've received the next batch. I should have sufficient quantity in this next batch to cover all remaining noted interest.
Thank you all for your patience.
Edit: Anyone who initially noted interest, but is no longer wanting a board, can you please let me know, so I can remove you from the list and elevate everyone else up. Thanks.
Post by Kazzie » Thu Mar 19, 2020 5:06 am
You caught my post, but I seem to have ended up in the 1MHz column rather than the Tube column by mistake.
Thanks in advance.
KenLowe
Post by KenLowe » Thu Mar 19, 2020 6:56 am
Sorry. The tabs don't line up particularly well when your editing the posts, so it wrongly looked like it was against the Tube adaptor. Now sorted. I've also moved you up the list, since currently I don't have any stock limitations of Tube adaptors, and I've sent you a PM.
Post by jms2 » Thu Mar 19, 2020 8:07 am
Hello Ken,
This project looks superb - and it has somewhat crept up on me because I hadn't been following the development thread. Sometimes it's better that way; seeing the finished product inspires me to look back at how it was created, whereas it can be hard to understand the end goal when there's a lot of detail being discussed.
Anyway, I'd be interested in one of each, in the "underneath" config please.
th3bar0n
Post by th3bar0n » Thu Mar 19, 2020 11:59 pm
Hi Ken,
Incredible job with these, they look awesome!
I'm still interested, as per my original request, however I can't seem to PM at the moment (says I don't have enough posts).
is there anyone monitoring this thread who can fix that?
Many thanks
IanB
Post by IanB » Fri Mar 20, 2020 12:01 am
IanB		2	2
Just to add that all of mine should be Underside
tone76
Post by tone76 » Fri Mar 20, 2020 9:50 am
Hi Ken,
I know you haven't got down to me on the list just yet, but I'd like to confirm my order for 1 x 1MHz interface and 1 x Tube interface. Underside (Option 1) versions of both, please.
I didn't choose the Acorn life, the Acorn life chose me.
Post by Kazzie » Fri Mar 20, 2020 11:43 am
Hi Ken,
Many thanks
Click the "Contact Us" (envelope) link at the bottom of the page, and that will let you ask for PM rights from an administrator. :)
Post by 1024MAK » Fri Mar 20, 2020 10:25 pm
Hi Ken
Can I please have the following:
Option 1 (Underside)
£15 including UK P&P.
Quantity: 2
Tube level shifter
£12 including UK P&P.
Quantity: 2
Please let me know the total if it’s not 2 x £15 + 2 x £12
Thanks for developing and producing these =D>
KenLowe
Post by KenLowe » Fri Mar 20, 2020 10:41 pm
I've sent you a PM with alternative contact details.
PM sent.
Post by 1024MAK » Fri Mar 20, 2020 11:39 pm
For editing text only, use a text editor with a fixed width character font, then copy to the forum text editor box :wink:
If you want a table, have a play with the tool on this site. Create your table, then copy the resulting ‘code’ into the forum text editor box. Not sure how big a table you can have mind. May also be a pain to edit it.
Reason: Edited to add the link that I had forgotten to include...
Post by 1024MAK » Sat Mar 21, 2020 8:19 am
Post above edited to include the link that I forgot :oops: #-o
KenLowe
Post by KenLowe » Sat Mar 21, 2020 8:36 am
That sounds quite useful. I'll give it a test to see how it looks.
Edit: Works well and easy to edit / update. I've now switched to the table code. Thanks for the tip.
Wheel_nut
Post by Wheel_nut » Sat Mar 21, 2020 11:48 pm
Please could you add my request for One Tube "Under" Level Shifter Board to your list.
I can pay by PayPal Friends and Family whenever you are ready.
Robin
#2 BBC Model B Issue 7 + 8271 DFS + Dual Floppy + Speech + PiTubeDirect on KenLowe's Tube Level Shifter
#3 BBC Model B Issue 7 + 8271 DFS + Cumana Single Floppy
KenLowe
Post by KenLowe » Sat Mar 21, 2020 11:53 pm
Robin
I've added you to the list, and sent you a PM.
trixster
Post by trixster » Sun Mar 22, 2020 8:13 am
Hi ken.
Great project!
Please could I be added to the list for:
2x Option 1 (underside) Raspberry Pi to 1MHz bus interface
2x Option 1 (underside) Tube level shifter
Uk p&p
dominicbeesley
Post by dominicbeesley » Mon Mar 23, 2020 2:13 pm
Please could I have an Option 2 remote
Dom
KenLowe
Post by KenLowe » Tue Mar 24, 2020 11:55 am
Folks,
I'm putting a pause on selling these, whilst there are movement restrictions in place. I've posted out to everyone who has paid me, so assuming postal service remains active, everyone who has purchased from me should receive their package shortly.
Thank you, and stay safe!
Ken.
KenLowe
Post by KenLowe » Thu May 07, 2020 11:04 pm
Ok folks, I am lifting the pause in selling now that the forum is open for business once again. However, I will be continuing to follow the social distancing and stay at home guidance issued by the government, so there may be a delay in me getting to the post office / post box if you do make a purchase.
Just prior to the pause, I had started running short of the Tube level shifter, but I received a new batch earlier this week, so I currently have plenty stock of both Tube and 1MHz level shifters.
Please also note that the remote option level shifter will be by special request only now. Instead, I will now be offering the under keyboard option as standard. If you do want to use the level shifter remotely, you will then have two options. The first option is to use a female / male ribbon cable (which I may be able to supply at cost). The second option is purchase a small additional pin converter that will allow you to use a more standard female / female ribbon cable. This pin converter will cost an additional £2. In time, I will update the first post to reflect this change.
If you are interested in either board, then either reply below, or drop me a PM, stating your preference and I will get back in touch.
Take care, and stay safe!
Ken.
chrisa
Post by chrisa » Fri May 08, 2020 11:55 am
Hi Ken,
Could I please have one of each interface, underside option for both. UK p&p.
Thank you!
Chris.
moose
Post by moose » Sat May 09, 2020 10:06 am
I'm interested in one of each of the tube and 1 MHz adapters. I'd like to use them with pi3s, so ideally I'd get the remote versions.I'd be happy enough with adapter cables to let me use the underside ones if that's easier/quicker though.
Stu
Return to “for sale / freebies”
