FS: USB "POST box" adaptors (for debugging Archimedes / Risc PC systems that don't boot)
peddle your acorn wares here!
Forum rules
IanJeffray
Re: FS: USB "POST box" adaptors (for debugging Archimedes / Risc PC systems that don't boot)
Post by IanJeffray »
myelin wrote:
Tue May 18, 2021 6:13 am
IanJeffray wrote:
Mon May 17, 2021 2:27 pm
I'm not sure if it's my build, or the code or ... not sure .. but the pixel never displays white, as I think it should to indicate "Idle, no power" - it's always a flashing green in that state, the same as "idle, has power". Connected (but no power)=Cyan and Running=Blue work appear as I think are expected. Could do with updated docs for this :lol:
Okay, so there is one bug that I haven't figured out. When the board is powered from USB but otherwise disconnected, often the green 'target power' LED will light up, and the neopixel flashes green (idle, target powered on). It goes back to normal (green target power LED off, neopixel flashing white) once I actually plug it in to a target though. I haven't taken the time to debug this; presumably some power is feeding back from the USB side via the various pullup resistors.
I've seen the power LED do weird things like that too, but it doesn't bother me.
I have NEVER seen the neopixel display white.
I'm sending out a batch of boards to folks today though... they all appear perfectly functional and reliable, other than these possible LED funnies.
Post by 1024MAK »
Received yesterday, a POSTbox through my letterbox :D
Thanks to Ian and myelin =D>
myelin
Post by myelin »
Hooray! Ian, can you message me with who you’ve already sent them to (+ serial numbers)? I’ll update the first message in this thread.
SW/EE from New Zealand, now in Mountain View, CA, making Beeb/Elk/Arc hardware projects for fun.
Most interesting: Arcflash, POST Box, Ultimate Electron Upgrade
acp
Post by acp »
Hi there, could I please be added to the waititing list for one of these if the queue's still open?
spanners
Post by spanners »
Hi, Can you remove me from the queue? I'm probably going to start getting rid of my RISC OS junk.
hank yellow
Post by hank yellow »
Could you please also add me to the queue? (If it's still open, that is)
myelin
Post by myelin »
All added/removed :)
I have four v3 boards and the last v2 board ready to go; will email people shortly!
DaveLecky
Post by DaveLecky »
Hi there,
Could you please add me to the list.
Electron Plus 1 Pres AP3/4
StrongA RPC,
Atom
ScurvyGeek
Post by ScurvyGeek »
I would like to be added to the waiting list, please.
z0m8ied0g
Post by z0m8ied0g »
Please can you add me to the waiting list.
Stephen
acorn_fan
Post by acorn_fan »
… and please add me to the list for one too. I’ve a tricky A5000 to crack. Thank you!
wicksee
Post by wicksee »
Could you add me to the queue please. I neeeed one of these!
myelin
Post by myelin »
You are all now on the list :)
(See first post in this thread for details.)
julians
Post by julians »
Would you add me to the queue as well please?
I've a slightly temperamental 440 that refuses to boot every now and then which I'd like to get sorted out at some point.
Julian.
IanJeffray
julians wrote:
Mon Jun 28, 2021 3:46 pm
Does it flash a POST code on the floppy when it fails? Such sporadic fails are often the hardest to resolve. The last time I had this kind of issue it came down to a poor connection to the backplane -- the board was insufficiently supported (original plastic supports all missing) and causing intermittent drop-out of the podules. This meant that every time I stripped it down to examine for faults, the fault went away... very annoying!
julians
Post by julians »
IanJeffray wrote:
Mon Jun 28, 2021 4:05 pm
No, it just sits there doing nothing.
The odd thing is that it will start up normally, occasionally lock up / crash, then refuse to boot for 15 - 30 minutes, then behave perfectly well.
I'm thinking it's the hard drive but will start a new thread once I've some time to concentrate on it.
Julian.
IanJeffray
julians wrote:
Mon Jun 28, 2021 4:17 pm
Checked the PSU? The 5V does need to be quite accurate for reliable operation, IME.
If it's a total failure as you describe, a POSTbox won't help you anyway, as it needs the CPU to at least start executing the POST code from ROM before it can do anything.
julians
Post by julians »
IanJeffray wrote:
Mon Jun 28, 2021 4:22 pm
I'll check the voltages and see what they look like.
Julian.
Got mine today good sir......
Thank you very much.
ajsellors
Post by ajsellors »
I would like one of the USB "POST box" adapters. If there aren't any in stock, please add me to the wish list.
thanks
Andrew
IanJeffray
ajsellors wrote:
Thu Jul 29, 2021 1:07 pm
I'll probably build another small batch in August - strictly for UK folks (EU customsmare be damned). I'm struggling a bit with people on the list not responding, so offers will now be time-limited and I may just contact people that are more 'active' anyway. They'll be £30 including postage. Stay tuned.
