BBC AGD Games
BBC AGD Games
Post by oss003 » Tue Jul 16, 2019 7:28 pm
Ok guys,
time for a preview ....... 8)
I managed to convert Simons magnificent 'Robot, The Impossible Mission' game to a BBC version ........ :)
It uses some extra AGD features which are added to the BBC version now like SW RAM usage (thanks Kieran), Megablocks and Adventuremode.
You do need 16KB Sideways RAM to run the game.
I still have to find a way to load a panel on the screen before starting the game........
The game has to look like this:
robot.ssd
(26 KiB) Downloaded 60 times
Re: BBC AGD Games
Post by tricky » Tue Jul 16, 2019 10:08 pm
Looking good, how do you load it on an Atom?
Re: BBC AGD Games
Post by oss003 » Wed Jul 17, 2019 6:19 am
You mean the panel?
On the Atom I have a Basic loader which loads the title screen and waits for a keypress. Then the panel is loaded in video memory and after that the game is loaded and ececuted.
In the BBC version, the video registers are tweaked to get the right resolution before the game starts so loading the panel has to be done in the game after the tweaking ...... but not every game has a panel ... I can however always load a panel and if no panel is needed, just load an empty panel...... :roll: or do the tweaking in Basic ..
SimonSideburns
Re: BBC AGD Games
Post by SimonSideburns » Wed Jul 17, 2019 9:34 am
Oh wow, I'm blown away. I thought I'd never see the day the game would run on the Beeb.
Now if only we had more memory for a higher colour mode. something to think about for nULA I guess.
As for calling the game magnificent, what can I say except thanks.
Re: BBC AGD Games
Post by oss003 » Mon Sep 30, 2019 8:32 pm
Guys I have a question .......
I'm having problems with the keyboard read routine OSBYTE &79 checking for the '9' or the 'I' keys.
According to the Advanced User Guide, the internal keycode for '9' is &25 and for 'I' is &26 but when I test it in AGD it seems that both values need to be switched ......... so the '9' keycode is &26 and the 'I' is &25 ..... :roll:
Can somebody confirm this?
This is the code:
; Keyboard test routine.
; Input:
;  A = key to read
; Output:
;  carry clr = key pressed
;  carry set = key not pressed
ktest:
	sta z80_a		; save key
	tya
	pha
; _BEEB keyboard read
	lda z80_a
	eor #$80		; _BEEB just look for this key
	tax
	lda #$79
	jsr OSBYTE
	txa
	bmi pressed 	; _BEEB X is negative if key is pressed
	sec			; key not pressed
	pla
	tay
	rts
pressed:
	clc			; key pressed
	pla
	tay
	rts
Re: BBC AGD Games
Post by lurkio » Mon Sep 30, 2019 8:39 pm
According to the Advanced User Guide, the internal keycode for '9' is &25 and for 'I' is &26 but when I test it in AGD it seems that both values need to be switched ......... so the '9' the keycode is &26 and the 'I' is &25 ..... Can somebody confirm this?
Have you seen this?:
Re: BBC AGD Games
Post by oss003 » Mon Sep 30, 2019 8:57 pm
No, but this confirms my findings ...... =D>
BTW these were the only 2 wrong keys in the table ......
Thanks ...
soviet
Re: BBC AGD Games
Post by soviet » Fri Dec 13, 2019 7:39 pm
do you got any new AGD games to run on the BBC :D
Re: BBC AGD Games
Post by oss003 » Fri Dec 13, 2019 9:13 pm
Yes, a lot of them are running now but a lot are using sideway RAM.
I even got WinAGD working to design your own games, please have a look at: viewtopic.php?f=57&t=17991&hilit=BBC+MPAGD
Maybe I'll convert some games in my vacation starting soon ....
Re: BBC AGD Games
Post by oss003 » Sat Mar 21, 2020 8:41 pm
Hi guys ... I have a question about BeebAsm ...
For AGD I want to create a discimage which can be auto-booted.
These are the lines in my batch file to do this:
REM Use BeebAsm to make a BBC disc image
 IF NOT EXIST Output/%1.bin goto error
 echo PUTFILE "Output/%1.bin", "AGDGAME", $1200, $1200 > disc.asm
 echo PUTFILE "B-em/LOADER.BAS", "LOADER", $1900, $8023 >> disc.asm
 echo PUTFILE "B-em/TITLE.SCR", "TITLE", $5800, $5800 >> disc.asm
 beebasm.exe -i disc.asm -do Discs\%1.ssd -boot AGDGAME
This works fine but !BOOT executes *BASIC and *RUN AGDGAME and what I want is *BASIC and CH."LOADER"
Is this possible?
Re: BBC AGD Games
Post by tricky » Sat Mar 21, 2020 10:25 pm
-opt N
Has the same effect as
*OPT 4,N
Where I think the default is 3, *exec
I write the !boot from beebasm and only -opt, not-boot iirc
You can also give it an image as a template.
Re: BBC AGD Games
Post by oss003 » Sun Mar 22, 2020 10:01 am
Tricky, if I use
beebasm.exe -i disc.asm -do Discs\%1.ssd -opt
then a parameter error is generated.
Is there a way to start a Basic program with *RUN?
I also tried to create a !BOOT file with the PUTTEXT command, that doesn't generate an error but doesn't create the file !BOOT on the image .....
 echo PUTTEXT "B-em/BOOT", "!BOOT", $0000, $FFFF >> disc.asm
Re: BBC AGD Games
Post by tricky » Sun Mar 22, 2020 10:43 am
I use:
ORG &C000
EQUS "B%=&" : HEX4 MAIN : EQUS 13
EQUS "CH.", 34, "MOON", 34, 13
save "!BOOT", &C000, P%, 0, 0
The first line is because I *LOAD the game in the basic loader and then CALL B% to start it.
I'm sure that there are better ways to do this and to write my MACROs, but this is what I use:
MACRO HEX1 v
	d = v AND &F
	IF d<10
		EQUB '0'+d
	ELSE
		EQUB 'A'+d-10
	ENDIF
ENDMACRO
MACRO HEX2 v
	HEX1 v DIV &10
	HEX1 v
ENDMACRO
MACRO HEX4 v
	HEX2 v DIV &100
	HEX2 v
ENDMACRO
PS And I build the final image with:
..\tools\beebasm.exe -w -vc -i build.asm -do MoonPatrol.ssd -opt 3 -title "MoonPatrol"
Re: BBC AGD Games
Post by CMcDougall » Sun Mar 22, 2020 1:19 pm
I did have a program from The Micro User, but can't find it :x
this also does it for a small program :
basic to RUN.ssd
ssd
(1.25 KiB) Downloaded 30 times
Re: BBC AGD Games
Post by oss003 » Sun Mar 22, 2020 3:56 pm
Ok, got it working now ......... my mistake .... #-o
I manually added !BOOT ...... at the wrong place.
This works for me:
 if exist "screens/titles/%1.SCR" (
   echo PUTFILE "screens/titles/%1.SCR", "TITLE", $5800, $5800 >> disc.asm
 if exist "screens/panels/%1.PAN" (
   echo PUTFILE "screens/LOADERPAN.BAS", "LOADER", $1900, $8023 >> disc.asm
   echo PUTFILE "screens/panels/%1.PAN", "PANEL", $6800, $6800 >> disc.asm
 ) else (
   echo PUTFILE "screens/LOADER.BAS", "LOADER", $1900, $8023 >> disc.asm
 echo PUTFILE "screens/BOOT", "!BOOT", $0000, $FFFF >> disc.asm
I also expanded it to add a titlescreen and a panelscreen if they exist.
Re: BBC AGD Games
Post by daveejhitchins » Sun Mar 22, 2020 4:04 pm
You should be able to modify this quite easily . . .
Transfer.ssd
(26.25 KiB) Downloaded 31 times
Re: BBC AGD Games
Post by oss003 » Fri Nov 13, 2020 9:45 am
Hi guys, I was wondering if it is possible to change the screenaddress to &A800 (in sideways RAM).
This is the idea to have a much free RAM for AGD as possible:
Is this possible?
Re: BBC AGD Games
Post by hoglet » Fri Nov 13, 2020 9:49 am
Is this possible?
In a word, no!
Sorry...
Re: BBC AGD Games
Post by oss003 » Fri Nov 13, 2020 9:51 am
And the screen from &0E00-&2600?
Re: BBC AGD Games
Post by tricky » Fri Nov 13, 2020 2:19 pm
Yep, that is fine.
R12=HI(scr_addr/8)
R13=LO(scr_addr/8)
Apart from &E00-&1900 is probably owned by DFS with &1100+ usually free if not using file handling other than *LOAD/*RUN.
PS If you don't need the disc after loading, I think it is safe to *TAPE and then use it anyway, exiting with a psudo power on reset but it probably isn't "legal".
kieranhj
Re: BBC AGD Games
Post by kieranhj » Sat Nov 14, 2020 12:51 pm
I figure I should just share this here, rather than leave it languishing on my PC. Although I'm no longer actively helping with the development of BBC AGD, I did have some success a while back converting Foggy's Quest by Dethmunk into MODE 1 to give it a bit of colour (the Spectrum version looks gorgeous!) It's hardcoded for the BBC Master I'm afraid as this was just WIP.
foggy.ssd
(26.5 KiB) Downloaded 15 times
Re: BBC AGD Games
Post by lurkio » Sat Nov 14, 2020 1:25 pm
I figure I should just share this here, rather than leave it languishing on my PC. Although I'm no longer actively helping with the development of BBC AGD, I did have some success a while converting Foggy's Quest by Dethmunk into MODE 1 to give it a bit of colour (the Spectrum version looks gorgeous!) It's hardcoded for the BBC Master I'm afraid as this was just WIP.
Oh, this is very good, for heaven's sake! Brilliant work! Please don't give up on this..! [-o<
Are there any other AGD games for the Beeb that are in progress or already complete?
The only one I know of is ROBOT - The Impossible Mission
Re: BBC AGD Games
Post by oss003 » Sat Nov 14, 2020 1:38 pm
Hi Kieran,
I want to update this version to be compatible with the mode4 version as soon as I have time. Also implementing INK and PAPER is on my list to create coloured text foreground and background like the Atom version.
First I want to get MPAGD working with the new memory map so that you have one block for the game.
To be continued ...
SimonSideburns
Re: BBC AGD Games
Post by SimonSideburns » Sat Nov 14, 2020 8:27 pm
I just played through ROBOT - The Impossible Mission on the web based emulator and managed to complete it on Medium difficulty level with two lives remaining, and there were some quite odd glitches with sprites. It seems like sprites were picking up the first frame of the next sprite on one of the frames for the current sprite. This wasn't an issue on the original Spectrum version.
I wonder what's going on with that.
Return to “miscellaneous new bbc and electron games”
