DOOM - ARM7TDMI version
dudleysoft71
Post by dudleysoft71 »
Over the last few weeks I've been working on a new port of DOOM to the BBC micro, this version is built targetting the ARM7TDMI which means it will run on the PiTubeDirect, a real ARM7TDMI co-processor, and since it emulates the ARM7TDMI it also runs in BeebEm.
I wrote this build to do three things:
  1. Remove the requirement to load a ROM image to play the game.
  2. Support all the official WADs plus custom WAD files without modification
  3. Support ARM7TDMI so it will run in BeebEm.
The game supports VideoNULA palette modes, both a dynamic 16 colour mode using -NULA parameter, and a 16 grey scale version using -GREY, as well as a dithered mode 2 8 colour mode.
Here's some screenshots:
You can download an ADL disk image here:
DOOM.zip
(185.05 KiB) Downloaded 19 times
Copy onto an ADFS hdd, and then put your WAD file in the same directory.
Supported official WADs:
  • DOOM1/WAD - Shareware doom wad
  • DOOM/WAD - Original full game
  • DOOMU/WAD - Ultimate Doom
  • DOOM2/WAD - DOOM 2
  • TNT/WAD - TNT: Evilution
  • PLUTONIA/W - The Plutonia Experiment (note this is truncated to 10 characters)
These are detected automatically, you can use -FILE to specify as many files as you like.
James Watson - DudleySoft
BBC Model B 32K - PiTubeDirect, Pi1Mhz, Smally Mouse, Gotek, DFS/ADFS, 4xSWRAM.
dudleysoft71
Re: DOOM - ARM7TDMI version
Just like with Quake I've added a HDD image with the shareware version of the game:
DOOM_HDD.zip
(1.86 MiB) Downloaded 20 times
This can be placed on an SD card for BeebSCSI, or the files copied into your own HDD image and run using *DOOM [-NULA|-GREY]
I've also created a github repository with the source to build the game, you will need the ARM-NONE-EABI toolchain installed, and if you wish to alter the assembly language used in beebScreen you need to have xxd in your path since this is used to convert the BeebAsm binary files into C source files to include in the game.
The repository is here: https://github.com/dudleysoft/beebDoom
marcusjambler
Post by marcusjambler »
:shock: Fantastic I love a bit of DOOM =D> =D>
dudleysoft71
I've created a new build of DOOM with support for RGB2HDMI NULA palette emulation.
To use this build simply run using:
*DOOM -HDMI
This will enable the 16 colour dynamic NULA palette via an RGB2HDMI adapter.
DOOM_HDD.zip
(1.86 MiB) Downloaded 3 times
DOOM.zip
(185.05 KiB) Downloaded 3 times
Return to “miscellaneous new bbc and electron games”
