Wanted - Orbit Zero
Re: Wanted - Orbit Zero
Post by sweh » Thu Feb 27, 2014 12:39 am
Arcadian wrote:If there are bits missing, how come it's loading on PJ's Beeb ok? Hmmm ... :?:
Those missing bits are probably the 256 bytes the loader grabs directly from the tape and writes to E00
billcarr2005
Post by billcarr2005 » Thu Feb 27, 2014 1:10 am
sweh wrote: Those missing bits are probably the 256 bytes the loader grabs directly from the tape and writes to E00
Indeed they are! Couldn't get them with MAKEEUF or bbctapedisc, but Jimmy's B-Em22alpha was able to load the WAV. :)
ORBIT ZERO.zip
ORBIT ZERO
(5.25 KiB) Downloaded 91 times
Post by CMcDougall » Thu Feb 27, 2014 1:33 am
billcarr2005 wrote:Jimmy's B-Em22alpha was able to load the WAV. :)
how did you get it to do it? I got to the Searching, but then started half way through the first file :?
Good stuff, got mine working too :) , but you beat me to it! 8)
billcarr2005
Post by billcarr2005 » Thu Feb 27, 2014 1:52 am
CMcDougall wrote: how did you get it to do it? I got to the Searching, but then started half way through the first file :?
Mine did too, so i cut the 256 byte section out, and switched tapes after the first file had loaded. 8)
MINEFIELD.zip
MINEFIELD
(3.12 KiB) Downloaded 79 times
Post by CMcDougall » Thu Feb 27, 2014 10:20 am
^oyy, that was my job [-X 8)
billcarr2005 wrote:cut the 256 byte section out, and switched tapes after the first file had loaded
#-o , it was 2am in the morning, and was knackered! :lol:
PS Arcadian, 4 blank C90s left, any more beeb MIA? :?
Post by sweh » Thu Feb 27, 2014 1:50 pm
This morning, before work, I decided to make the loader work for me...
*TAPE
PAGE=&E00
P%=&78
[PHA:LDA#&FA:STA&D46:PLA:RTS
?&220=&78:?&221=0
*FX14 4
CHAIN ""
This interrupt forces the "RUN" to be replaced with "STOP" in the page &D loader area, so everything loads and runs as normal but then the program bombs out with Bad program.
At this point I can go into EXMON, move memory 0E00-2E00 up to 4000 then *CARD and *SAVE ORBIT2 4000+1E00 E00 E00
Again the resulting program has "Bad program" errors but this is because of the original "copy protection". It looks good. So this evening I'll take a look to see if we just need 0D FF at the end, or if I need to be clever with the loader. But I should have a working SSD (if no one else has done it before hand).
Post by leenew » Thu Feb 27, 2014 2:11 pm
Good work to all involved in this one.
Can't wait for the SSD :D
billcarr2005
Post by billcarr2005 » Thu Feb 27, 2014 4:56 pm
The above links are for the full, working, 100% OK SSDs :roll:
Post by leenew » Thu Feb 27, 2014 5:25 pm
Err.... What I meant was.... I can't wait to try it when I get home :^o
Post by sweh » Fri Feb 28, 2014 1:19 am
sweh wrote: Again the resulting program has "Bad program" errors but this is because of the original "copy protection". It looks good. So this evening I'll take a look to see if we just need 0D FF at the end, or if I need to be clever with the loader. But I should have a working SSD (if no one else has done it before hand).
OK, even though it may not be necessary...
The last bytes of the code are 0D 7F, rather than 0D FF to indicate end of program. Binary edit fixed that. Now the code needs too much memory to run at &1100 so needs to be at &E00, so I added a simple basic "*LOAD" "FOR loop relocator" "PAGE/OLD/RUN" routine, and then modified the existing loader to set page and chain that.
I kept the original 7 second delay on the load screen just 'cos (see line 615). In a brief test CHAIN "ORBIT" works on BeebEm and looks to behave the same as the original tape did on my real Beeb.
orbit.zip
(5.61 KiB) Downloaded 87 times
Site Admin
Post by Arcadian » Thu Mar 27, 2014 3:52 am
Here are [photos of] the instructions, for anyone interested!
Post by sweh » Mon Mar 31, 2014 1:53 am
Arcadian wrote:Here are [photos of] the instructions, for anyone interested!
I've gotta say; I think this thread is an exemplar for what this forum is about; we get the raw wav, break the protection, come up with alternative solutions and also get a scan the insert.
I think this is good work by everyone, and all involved should be proud of their co-operation.
vanekp
Post by vanekp » Sat Nov 11, 2017 7:18 pm
Arcadian wrote:The tapes weren't in the best of shape, but let's see if anyone can turn these into working images!
GraphicResearch_Minefield_BBC_Recording1.wav
GraphicResearch_Minefield_BBC_Recording2.wav
GraphicResearch_OrbitZero_BBC_Recording1.wav
GraphicResearch_OrbitZero_BBC_Recording2.wav
Two copies of each respective game were recorded on the first side of the cassette (each reverse side was blank).
Aww the waves for Orbit Zero are gone, anyone have a tape image (uef or wav) of this game wanted to look at the copy protection :wink:
Site Admin
Post by Arcadian » Sat Nov 11, 2017 7:58 pm
I've just checked the server, the files are still there - part of the path is /wav/bbc/ not /wavs/bbc/ - I'm not sure how that got changed but I've fixed the links below so you should be good to grab them now ...
Post by CMcDougall » Sat Nov 11, 2017 8:01 pm
^If you read, the UEF was not possible as the protection was a swap from 1200 to 300baud to load first block of main part to &E00
The .WAVs *might* be on my desktop PC, but not got it on regularly as never have time :(
vanekp
Post by vanekp » Sat Nov 11, 2017 9:42 pm
Yes got all that from the posts, which is why I though it would be interesting to look at it and see if it can be copied/reproduced in another way than makeUEF :wink:
So yes I would appreciate a copy if that is possible :)
Post by CMcDougall » Sun Nov 12, 2017 10:52 am
^ did the new links above my post from Dave work for you? Let me know & if not will upload for you :wink:
vanekp
Post by vanekp » Sun Nov 12, 2017 11:38 am
thanks, had to change wavs to wav in the link then it worked (as per above) :wink:
vanekp
Post by vanekp » Sun Nov 12, 2017 2:43 pm
They converted to UEF without a problem 1st one has some dropout before the 1st program (log files below)
MakeUEF V2.3.
Command line:
-i GraphicResearch_OrbitZero_BBC_Recording1_8bitFiltered.csw -w 0 180
Date (D/M/Y) and time:
12/11/2017   14:53
Expected baud rate is 1189.
Gap written, length 0.714195 seconds.
Security waves written, length 25 waves, as follows:
S,S,S,L,L,S,S,L,S,S,L,S,S,S,L,L,S,S,L,S,S,L,S,S,L,
The security waves start with a wave.
The security waves end with a wave.
Carrier tone written, length 233 waves.
Baud rate of the preceding data was 1211.888
Gap written, length 0.002653061 seconds.
POSSIBLE DROPOUT - THE GAP IS LESS THAN 0.02 SECONDS.
Security waves written, length 1 waves, as follows:
S,
The security waves start with a pulse.
Carrier tone written, length 503 waves.
Security waves written, length 3 waves, as follows:
L,S,S,
The security waves end with a pulse.
Baud rate of the preceding data was 1207.795
Gap written, length 0.001904762 seconds.
Carrier tone written, length 11 waves.
Baud rate of the preceding data was 1225
Gap written, length 0.01197279 seconds.
Carrier tone written, length 11451 waves.
Baud rate of the preceding data was 1206.278
The following block size is 284
Found :      ORBIT 00	Checksum ok
1 data blocks written.
Carrier tone written, length 2156 waves.
Baud rate of the preceding data was 1205.194
Found :      ORBIT 01	Checksum ok
2 data blocks written.
Carrier tone written, length 2157 waves.
Baud rate of the preceding data was 1204.793
Found :      ORBIT 02	Checksum ok
3 data blocks written.
Baud rate of the preceding data was 1204.345
Found :      ORBIT 03	Checksum ok
4 data blocks written.
Baud rate of the preceding data was 1204.146
Found :      ORBIT 04	Checksum ok
5 data blocks written.
Baud rate of the preceding data was 1203.643
Found :      ORBIT 05	Checksum ok
6 data blocks written.
Baud rate of the preceding data was 1203.096
Found :      ORBIT 06	Checksum ok
7 data blocks written.
Baud rate of the preceding data was 1202.077
Found :      ORBIT 07	Checksum ok
8 data blocks written.
Baud rate of the preceding data was 1201.314
Found :      ORBIT 08	Checksum ok
9 data blocks written.
Baud rate of the preceding data was 1201.609
Found :      ORBIT 09	Checksum ok
10 data blocks written.
Baud rate of the preceding data was 1201.648
Found :      ORBIT 0A	Checksum ok
11 data blocks written.
Baud rate of the preceding data was 1200.891
Found :      ORBIT 0B	Checksum ok, last block flag
12 data blocks written.
1 ordinary files written.
Carrier tone written, length 12730 waves.
S,
Gap written, length 0.02721088 seconds.
Security waves written, length 14 waves, as follows:
Carrier tone written, length 12012 waves.
Baud rate of the preceding data was 1202.048
The following block size is 283
DATA BLOCK WRITTEN WITH A BAD CHECKSUM OR NON-STANDARD BLOCK.
13 data blocks written.
BLOCK NUMBER 00 MISREAD.
Carrier tone written, length 12028 waves.
Baud rate of the preceding data was 1199.841
14 data blocks written.
MISREAD A BLOCK.
Carrier tone written, length 12198 waves.
Baud rate of the preceding data was 1195.684
The following block size is 280
Found :          ? 00	Checksum ok
15 data blocks written.
Carrier tone written, length 2140 waves.
Baud rate of the preceding data was 1192.625
Found :          ? 01	Checksum ok
16 data blocks written.
Baud rate of the preceding data was 1191.576
Found :          ? 02	Checksum ok
17 data blocks written.
Baud rate of the preceding data was 1191.26
Found :          ? 03	Checksum ok
18 data blocks written.
Carrier tone written, length 2141 waves.
Baud rate of the preceding data was 1190.375
Found :          ? 04	Checksum ok
19 data blocks written.
Baud rate of the preceding data was 1190.055
Found :          ? 05	Checksum ok
20 data blocks written.
Baud rate of the preceding data was 1189.62
Found :          ? 06	Checksum ok
21 data blocks written.
Baud rate of the preceding data was 1189.408
Found :          ? 07	Checksum ok
22 data blocks written.
Baud rate of the preceding data was 1189.375
Found :          ? 08	Checksum ok
23 data blocks written.
Baud rate of the preceding data was 1188.212
Found :          ? 09	Checksum ok
24 data blocks written.
Baud rate of the preceding data was 1187.232
Found :          ? 0A	Checksum ok
25 data blocks written.
Baud rate of the preceding data was 1186.935
Found :          ? 0B	Checksum ok
26 data blocks written.
Baud rate of the preceding data was 1187.567
Found :          ? 0C	Checksum ok
27 data blocks written.
Baud rate of the preceding data was 1186.968
Found :          ? 0D	Checksum ok
28 data blocks written.
Baud rate of the preceding data was 1187.526
Found :          ? 0E	Checksum ok
29 data blocks written.
Baud rate of the preceding data was 1186.514
Found :          ? 0F	Checksum ok
30 data blocks written.
Baud rate of the preceding data was 1185.986
Found :          ? 10	Checksum ok
31 data blocks written.
Baud rate of the preceding data was 1186.354
Found :          ? 11	Checksum ok
32 data blocks written.
Baud rate of the preceding data was 1186.399
Found :          ? 12	Checksum ok
33 data blocks written.
Baud rate of the preceding data was 1186.28
Found :          ? 13	Checksum ok
34 data blocks written.
Baud rate of the preceding data was 1185.624
Found :          ? 14	Checksum ok
35 data blocks written.
Baud rate of the preceding data was 1185.237
Found :          ? 15	Checksum ok
36 data blocks written.
Baud rate of the preceding data was 1185.349
Found :          ? 16	Checksum ok
37 data blocks written.
Baud rate of the preceding data was 1185.295
Found :          ? 17	Checksum ok
38 data blocks written.
Baud rate of the preceding data was 1184.48
Found :          ? 18	Checksum ok
39 data blocks written.
Baud rate of the preceding data was 1185.028
Found :          ? 19	Checksum ok
40 data blocks written.
Baud rate of the preceding data was 1184.464
Found :          ? 1A	Checksum ok
41 data blocks written.
Baud rate of the preceding data was 1184.502
Found :          ? 1B	Checksum ok
42 data blocks written.
Baud rate of the preceding data was 1186.209
Found :          ? 1C	Checksum ok, last block flag
43 data blocks written.
2 ordinary files written.
Carrier tone written, length 12714 waves.
S,
Baud rate of the preceding data was 1189.523
Gap written, length 0.02530612 seconds.
MakeUEF V2.3.
Command line:
-i GraphicResearch_OrbitZero_BBC_Recording2_8bitFiltered.csw -w 0 180
12/11/2017   15:34
Expected baud rate is 1186.
Gap written, length 0.007052154 seconds.
Carrier tone written, length 12240 waves.
Baud rate of the preceding data was 1184.448
Baud rate of the preceding data was 1183.723
Baud rate of the preceding data was 1182.932
Baud rate of the preceding data was 1183.821
Baud rate of the preceding data was 1183.11
Baud rate of the preceding data was 1181.999
Baud rate of the preceding data was 1185.058
Baud rate of the preceding data was 1184.592
Baud rate of the preceding data was 1185.318
Baud rate of the preceding data was 1188.273
Baud rate of the preceding data was 1185.253
Baud rate of the preceding data was 1185.453
Baud rate of the preceding data was 1184.986
Gap written, length 0.02816327 seconds.
Baud rate of the preceding data was 1185.549
Carrier tone written, length 12027 waves.
Security waves written, length 22 waves, as follows:
Carrier tone written, length 12208 waves.
Baud rate of the preceding data was 1187.903
Baud rate of the preceding data was 1195.139
Baud rate of the preceding data was 1195.641
Baud rate of the preceding data was 1188.394
Baud rate of the preceding data was 1187.216
Baud rate of the preceding data was 1186.819
Baud rate of the preceding data was 1184.436
Baud rate of the preceding data was 1184.209
Baud rate of the preceding data was 1183.93
Baud rate of the preceding data was 1184.05
Baud rate of the preceding data was 1183.864
Baud rate of the preceding data was 1185.695
Baud rate of the preceding data was 1185.649
Baud rate of the preceding data was 1186.951
Baud rate of the preceding data was 1187.799
Baud rate of the preceding data was 1188.067
Baud rate of the preceding data was 1188.278
Baud rate of the preceding data was 1188.555
Baud rate of the preceding data was 1191.8
Baud rate of the preceding data was 1195.301
Baud rate of the preceding data was 1190.47
Baud rate of the preceding data was 1185.739
Baud rate of the preceding data was 1183.926
Baud rate of the preceding data was 1182.396
Baud rate of the preceding data was 1181.82
Baud rate of the preceding data was 1182.535
Baud rate of the preceding data was 1180.474
Baud rate of the preceding data was 1181.795
Baud rate of the preceding data was 1180.89
Baud rate of the preceding data was 1182.126
Gap written, length 0.01222222 seconds.
I never came across any 300 baud blocks so not sure where that story comes from The loading is a bit odd, as the 1st program turns the tape motor back on and loads a one block basic program which then loads the 3rd basic program in at &E00.
It loads on BeebEm (Need to remember to set page to &E00 before you load the 1st program or it will come up with bad program as it can't find the M/C at the correct address.) but then comes up with Bad program at the end.
On B-em it does load, after a fashion as it has a hangup finding the 3rd part if you rewind and let it search a 2nd time it then finds it, but 1st time around it does not find block 0.
Attached are the csw log and uef files for both files.
Peter.
GraphicResearch_OrbitZero_BBC_Recording2.zip
(114.14 KiB) Downloaded 47 times
GraphicResearch_OrbitZero_BBC_Recording1.zip
(113.35 KiB) Downloaded 46 times
