BCPL System Disc
BCPL System Disc
Post by Coeus » Sun Jan 14, 2018 8:38 pm
After expanding the SSD of a BCPL system disc into a directory on VDFS I noticed that it now seemed to have more files in than it did originally. I went to check against the list in the manual and also found the file EXMP3B file missing and even going back to the original SSD it is still not there.
The BCPL system disc has 31 files on it as originally supplied and what I think has happened is that someone has decided EXMP3B, being an example program, isn't that useful and that a copy of the ROM for loading into sideways RAM would be a more useful way to use the 31st file. In use this may indeed be so but as searching for this disc found only the one embedded in Wouter's ROM archive, and that has the same missing file and is no doubt where I got my current SSD from, I am a little concerned as to whether a proper copy, i.e. with the set of files originally distributed, has been archived somewhere.
Pernod
Re: BCPL System Disc
Post by Pernod » Sun Jan 14, 2018 10:05 pm
Is this it?
BCPL_Utilities.zip
(51.52 KiB) Downloaded 43 times
Post by sweh » Sun Jan 14, 2018 10:22 pm
There's some disks at https://acorn.huininga.nl/pub/disks/ori ... soft/BCPL/
% beeb info BCPL\ Utilities.ssd
Disk title: BCPL (12)  Disk size: &190 - 100K
Boot Option: 3 (EXEC)   File count: 31
Filename:  Lck Lo.add Ex.add Length Sct
$.TRACE        000000 000000 000384 138
$.TESTPRO      000000 000000 000680 131
$.TED          000000 000000 001538 11B
$.SYSHDR       000000 000000 0004C5 116
$.STATS        000000 000000 00066C 10F
$.STACK        000000 000000 000202 10C
$.RAS          000000 000000 0016FF 0F5
$.OPT          000000 000000 000386 0F1
$.NEEDCIN      000000 000000 0004CA 0EC
$.LIBHDR       000000 000000 000412 0E7
$.LIB          000000 000000 000532 0E1
$.JOINCIN      000000 000000 0002D0 0DE
$.JOIN         000000 000000 0001FA 0DC
$.IO           000000 000000 000280 0D9
$.INSTR        000000 000000 000B80 0CD
$.HEAP         000000 000000 00040C 0C8
$.GLOBALS      000000 000000 0000CE 0C7
$.EXMPHDR      000000 000000 0000EF 0C6
$.EXMP3B       000000 000000 001034 0B5
$.EXMP2B       000000 000000 001143 0A3
$.EXMP1B       000000 000000 0008CC 09A
$.EXAMPLE      000000 000000 000974 090
$.EX           021126 020002 00055C 08A
$.ENCODEB      000000 000000 00036B 086
$.ED           000000 000000 002548 060
$.DEBUG        000000 000000 001280 04D
$.BCPLTRN      000000 000000 00117F 03B
$.BCPLSYN      000000 000000 00165E 024
$.BCPLCCG      000000 000000 001A82 009
$.BCPLARG      000000 000000 00020E 006
$.BCPL         000000 000000 000160 004
Post by Coeus » Mon Jan 15, 2018 5:39 pm
Thanks, guys.
Wouter Scholten
Post by Wouter Scholten » Mon Jan 15, 2018 11:45 pm
Coeus wrote:After expanding the SSD of a BCPL system disc into a directory on VDFS I noticed that it now seemed to have more files in than it did originally. I went to check against the list in the manual and also found the file EXMP3B file missing and even going back to the original SSD it is still not there.
That's odd, well, I did have an original of BCPL and the other discimages I made of originals as I saw them first when I acquired the originals, but I made the discimage of BCPL disk from a copy years arlier and I think used the non-original disk that I got some time in the late 1990s for that...
