Supreme Team - Touchline Computers 1987 3.5"ADFS80M
Post by CMcDougall » Sun Sep 17, 2017 6:07 pm
got this also from DaveE, he did not have much hope for it, and he was right... :(
disc changed into new case, squeaked like mad doing a *CAT, fell disc fell apart
so bad, now can even see through parts of it now :shock: :
media
what I now get after a backup to a known good disc using ADI rom:
CAT
ldr
hopefully this will jog someones memory, so can get it archived from a good blank disc! [-o<
below is what I got from the backup, I also have some files from ADFS to DFS which I will have to compare later...
but most files failed if >&100 in length... so don't hold your breath
SupremeTeam-Touchline1987-ElkADFS80Merrs.zip
(40.09 KiB) Downloaded 42 times
Re: Supreme Team - Touchline Computers 1987 3.5"ADFS80M
Post by danielj » Sun Sep 17, 2017 6:09 pm
Best clean the drive heads, Col - that will have gunked them something chronic...
Post by CMcDougall » Sun Sep 17, 2017 6:28 pm
^I sure did Daniel, and then formatted the backup ADFS disc back to DFS so it's usefull again! :lol:
even when ADI was reading 'original copy', mostly would give errors too, especially >Track30
Post by CMcDougall » Mon Sep 18, 2017 3:31 pm
me wrote:some files from ADFS to DFS which I will have to compare later..
& here they are....
BLANK80dtB files DIR.zip
in FILES dir
(2.28 KiB) Downloaded 39 times
BLANK80dtA.zip
dir $ C
(31.41 KiB) Downloaded 44 times
Post by CMcDougall » Sat Mar 31, 2018 8:12 pm
thanks to Daniel, he stuck it through his kyroFlux thingy ma bob for a better read.
still does not work, MENU file corrupt, but if other peeps know how to fix ADFS F discs, this may be your bag...
supremeTeamERRs.zip
still errs, with LOG file
(115.7 KiB) Downloaded 31 times
