Aztecs & Time Detectives
request software or documentation that you can't find online
ARandomDave
Post by ARandomDave » Sun Apr 14, 2019 3:22 pm
Hi all,
Recently I've been lusting after playing two educational games I remember playing in an IT lesson some years ago, "Aztecs" and "Time Detectives - The Victorians" by Sherston Software.
I managed to find a demo for Aztecs and was disappointed when it ended. I've been keeping my eye out on eBay (despite prices..) but haven't seen either pop up. Its sad really, as I'm sure so many copies were thrown in the bin when they were ripped out and replaced with Windows machines.
Thanks in advance!
Edit 2019-10-27: Victorians now working, just after Aztecs now.
ARandomDave
Re: Aztecs & Time Detectives
Post by ARandomDave » Sun Jul 28, 2019 4:01 pm
After much waiting, I have been able to source "Time Detectives - The Victorians" - complete with all literature from eBay.
Even better, I have been able to image the disks using fluxengine, with the exception of one sector on disk 1 - the key disk. Application and fonts installed just fine, but the program wont load - reporting "Please put the Victorians startup disc in drive 0". fluxengine copies the data anyway, where it can, ignoring things like the CRC check.
Has anyone got any suggestions as to how to get this running in RPCEmu? - I've spent ages trying to get to this point and any help would be greatly received.
ARandomDave
Post by ARandomDave » Sat Aug 17, 2019 2:10 pm
*bump*
If I uploaded the disk images somewhere, would someone mind trying them with a physical Acorn to determine if the images themselves are good (and perhaps it's just the emulation later)
Thanks in advance
ARandomDave
Post by ARandomDave » Sun Nov 10, 2019 3:33 pm
After managing to successfully bypass the protection in "Time Detectives - The Victorians", I thought I'd have a go at circumventing the protections in ArcVenture and ArcVenture IV. Sadly, both used more comprehensive protection checks. However, armed with !DDT and !Zap I was eventually able to bypass the checks in both
ArcV I implements its protection in a standalone module (ShAlloc) and opens cleanly in !Zap allowing two calls to XADFS_DiscOp to be bypassed without the need for decent debugging tools. If you're looking to do the same the change I used is as follows:
00000208 BL &00000178
ArcV IV was significantly more complex. The protection is implemented in the main !RunImage binary, which itself is compressed with squeeze (compression version 4.00). After trying several tools to decompress, I was eventually able to unsqueeze using http://ftp.uni-stuttgart.de/pub/systems ... queeze.spk. This left me with a ~170KB binary file (this felt monstrous to step through).
After locating a close-enough relevant instruction at 0002f168 (adr r1, &0002f198 ; = "Please place the %s startup disk in drive 0"), I spent some time single-stepping through to identify where the call was taking place. This was made more painful by !DDT crashing fairly frequently. If you're looking to do this too, the change is as follows:
0002F178	BL	&0002F184
(You'll need to have the "Resources" disc in drive 0 to play still, but the protection mechanism wont complain about the startup disc).
If anyone can source me Aztecs I'd be certainly appreciate it and happy to have a go at circumventing the protections.
If what I've posted above breaks any rules, then my apologies - happy to amend the post.
OutlawMedalist
Post by OutlawMedalist » Sun Dec 15, 2019 12:58 pm
Hey, is there any way you could send me the files for Time Detectives?
I remember playing it a bunch as a kid when I was at school but never finished it. I've been looking for it on and off for about a year or so now.
ARandomDave
Post by ARandomDave » Thu Dec 19, 2019 7:54 pm
Get in touch and we can work out the details.
ARandomDave
Post by ARandomDave » Thu Dec 19, 2019 7:56 pm
ArcVenture 1 through 4 are all now patched to bypass protection and back with the author for release. For completeness, the changes to bypass the protections are described below.
ArcVenture II
For ArcVenture II, the protection check occurs in !AV2Start's "!RunImage" First, decompress the image using "UNSQUEEZE" and then modify the instruction at 0x81A0:
  From 000081A0 BL &0000D84C
  To 000081A0 BL &000081A4
If the instruction doesn't match the above, be sure the unsqueeze completed successfully. Optionally, then re-squeeze the file again and put it back on the disk.
ArcVenture III
The protection occurs in !AV3's !Runimage. First locate the DEFNpalset function (basic line 4314) then make the following changes:
On BASIC line 4316, change EQUD &EB000029: to EQUD &EB000025:
On BASIC line 4317, change EQUD &EB000025: to EQUD &EB000021:
Sadly, the copy of Aztecs that the CCH has is in poor condition. Two files on disk 2 are corrupt (TWO.map and TWO.guard). Disk 3 has corruption across multiple files. If anyone can provide disk 2/3 I'll gladly share how to bypass the protections for use in RPCEmu etc.
ARandomDave
Post by ARandomDave » Thu Jul 23, 2020 7:27 pm
I've managed to source another copy of Aztecs and image the disks. Sadly however there's the chance of a single corrupt sector on disk 3.
If anyone happens to have disk 3 I'd really appreciate borrowing it, or getting a flux image of it. Otherwise I'll start the tedious process of comparing against the CCH copy to see if it can be pieced back together.
ARandomDave
Post by ARandomDave » Thu Jul 23, 2020 9:18 pm
Thanks davidb for messaging me, unfortunately I don't have PM rights just yet so have been unable to respond.
Thankfully, despite Track 41 Sector 4 of the "Mask" disc being corrupt/empty, the game seems to play without issue. If anyone else is looking to get this up and running in RPCEmu, locate the function DEFNpalset in !runimage on the "key disc". Ammend the second line of ASM starting "EQUD &0A00001A:EQUD &E1A0C001" change to "EQUD &0A000023:EQUD &E1A0C001". In my copy, this was line 6430. This has the effect of bypassing the XADFS_DiscOp call at 000080E4 in the disassembled ASM.
The games I started in KS2/Year 5 are finally complete. Not sure I expected to complete them after so much time, or that I'd ever been able to guess the work involved in getting them up and running :D
MyJumpersFullOfFears
Post by MyJumpersFullOfFears » Sat Jul 25, 2020 10:00 am
It would help if you were to tell others where they could find the ADF of it (that is, if there even is one). While I personally do not remember these games from my own time in primary school, I have always been interested in discovering more 32-bit educational titles that can be run in Arculator and RPCEmu.
ARandomDave
Post by ARandomDave » Sat Jul 25, 2020 11:35 am
My understanding of the approach the community is taking is that 8bit stuff is fine to share as (most) copyright holders have moved on and are not enforcing. 32bit however, there were still several interested parties and so it is frowned upon to distribute the copyrighted works without copyright holder approval.
In the cases of the titles I've "cracked":
  1. The ArcVenture games are now available following contact made with the original programmer - he posted about this here - viewtopic.php?f=13&t=18270 and on his blog here https://arcventure.online/2020/01/25/di ... ures-past/ MarkV kindly provided me with disc images, which I modified and returned to him for release.
  2. For Time Detectives and Aztecs, I have tried contacting Sherston by sadly the original team are no longer there and I received no response to my enquiries. I believe they've been through one or more acquisitions, so doubt they know the copyright status themselves. The original discs I purchased are now with JASPP for archiving and hopefully can be made available. (Or in the case of Aztecs, will be once I've posted them)
When I last looked, CJE Micros had copies of Time Detectives and Aztecs available for purchase.
If I've misinterpreted the position the community is taking towards 32bit riscos stuff, please do let me know :D
Post by davidb » Sat Jul 25, 2020 11:55 am
No problem. I wasn't necessarily expecting a response - just letting you know where you might find another copy. :)
Return to “archive requests”
