Midi Track Performer v2
request software or documentation that you can't find online
courseddent
Post by courseddent » Fri Nov 01, 2019 11:00 am
I'm looking for an image of Miditrack Performer v2 by Electromusic Research (also any other software published by them). Have the disk of it, but can't seem to copy.
Thanks!
Re: Midi Track Performer v2
Post by Pernod » Fri Nov 01, 2019 11:02 am
courseddent
Post by courseddent » Fri Nov 01, 2019 3:10 pm
Ah brilliant, thanks for that!
That's version 1.1 so wonder if there's a v2 floating around out there somewhere?
Post by Pernod » Fri Nov 01, 2019 6:19 pm
Is the the disk damaged, or you think it's protected?
courseddent
Post by courseddent » Sat Nov 02, 2019 8:23 pm
I think it could be protected as it doesn't seem to copy. I guess I should maybe try to create an copy/image using XFER? Just haven't given it a go before.
Post by CMcDougall » Sun Nov 03, 2019 12:08 am
don't use XFER as that would take 8mins & end up rippin the disc apart.
use UPURS or OmniFlop, as that takes about a minute & 'skips' across the disc surface.
billcarr2005
Post by billcarr2005 » Mon Nov 04, 2019 9:50 am
If you could catalogue the disk it might help
Or attempt a *VERIFY
The disk I have is a standard 40 track, nothing exotic. Although I think there is some OSWORD &7F direct sector loading.
Maybe V2 increased the protection, although doesn't seem necessary as additional hardware is required to use it anyway?
Return to “archive requests”
