Genie/Genie Junior by PMS
Re: Genie/Genie Junior by PMS
Post by Pernod » Mon May 13, 2019 10:37 pm
tripmeup wrote:
Mon May 13, 2019 9:37 pm
(Genie Junior's Easter Egg screen)
Derek.
I'd read about that, how is it accessed?
tripmeup
Post by tripmeup » Tue May 14, 2019 10:09 am
To quote the manual:
Cunningly concealed within these lines
There are two key for you to find
Revealing GENIE's secret screen
Letting you meet the PMS team
P.S. keys unlock things!
Basically you need to lock the Genie then press CTRL-P .
Take Care! You will need to know the Genie Password to be able to unlock it again!
tripmeup
Post by tripmeup » Sun Jun 09, 2019 9:27 pm
Sorry for the silence....
billcarr2005 wrote:
Sun May 12, 2019 4:09 pm
If you think it might help, it would be trivial to dump the (battery backed) RAM sections, just after resetting the device, in case the ROM code is looking for something specific?
It won't reveal very much. the first page of the battery backed RAM was used for bookkeeping. Everything else was data storage. From a bit of memory & reverse engineering. The data is arranged as 4 singly linked lists. The pointers begin at &8080 (from the start of GENIE RAM). The last used byte is held in &8088.
Unfortunately, the code is not smart enough to recognise an 'empty' Genie so it needs to be formatted. This simply initialises the first page of the battery backed RAM, and puts my name starting at &8070.
Pernod wrote:
Sun May 12, 2019 4:26 pm
Unlikely, but I'll let Derek comment on whether that may be useful. I think current issues are due to having bad dumps of the latch region &1F00-1FFF, as the banks will change during the dump process. Page &1F is identical in all ROMs which seems rather wasteful, maybe intended?
Looks like CJE have one for sale without casing, ready for dumping. http://www.cjemicros.co.uk/micros/indiv ... PMS-GENINT
I don't think there is any code in page &1F, but with a friend, and an arduino, we have a clean dump of an original Genie (see my later post).
Out of curiosity, there was also a Master cartridge version, see http://8bs.com/see/genie.jpg. Would that have been identical to the BBC version or maybe reworked to make use of the Write line?
The hardware was the same, only some tweaks to make it work with the different Master shadow ram (etc.) hardware. I didn't manage to get my version to work on a Master yet... But I'll see if there is another dump that would work.
tripmeup
Genie/Genie Junior by PMS - clean ROM dumps
Post by tripmeup » Sun Jun 09, 2019 9:31 pm
With the help of Colin Cameron (son of the one of the founders of PMS). We got a clean dump from the original ROMs for BBC Genie. I've tested it (under emulation) on BBC B and BBC B+ and it works fine, however so far no luck on Master 128. I'll see if we can find a different version for that one.
Attached is also new dump of Genie Junior. This one works fine with disk image already posted.
Best regards,
Derek.
genie_v1.01.rom
(32 KiB) Downloaded 11 times
genie_junior_v1.1u.rom
(16 KiB) Downloaded 10 times
tripmeup
Re: Genie/Genie Junior by PMS - clean ROM dumps
Post by tripmeup » Sun Jun 09, 2019 9:39 pm
Just for interest, this is how the ROM got dumped!
... and lurking in Gordons garage was a box of old stuff, among which were some master copies of PMS ROMS.
Let's see what he finds!
tripmeup
Post by tripmeup » Sun Jun 09, 2019 9:51 pm
I can confirm that Page &1F, &3F, &5F, and &7F are identical in the clean dump of the ROM. I don't remember if it was used. However in similar hardware (Publisher, 64k PMS NTQ module, etc.) I sometimes put the code that read from the RAM, or for flow control (jumping to subroutines that lived in a different page).
billcarr2005
Post by billcarr2005 » Mon Jun 10, 2019 12:26 am
I've combined the 4 x 8k ROMs i posted earlier and did a file compare and MD5 checksum against genie_v1.01.rom and they are identical! :wink:
And in the "dirty" dump too :lol:
tripmeup wrote:
Sat May 11, 2019 9:54 pm
Thanks. I guess I must have mixed up somewhere. The order of the images seem to be mixed up somehow... If I reassemble them in the order of 80 B0 90 A0 it seems to work "more" successfully. but I still can get it to work. My friend might have found the original source code of Genie (on 5.25" disk). I guess there is a >50% chance that is is long gone but I see if he can read anything off of it (not sure I'd like to risk posting it).
Does that still mean that v1.02 is a erroneous dump, or has the emulation improved?
Post by Pernod » Mon Jun 10, 2019 1:02 am
Excellent work, thanks =D>
It performs the same as v1.01 in MAME, so am tempted to say it's good.
Yes please. I'm sure they'll be some MIA's amongst those.
tripmeup
Post by tripmeup » Mon Jun 10, 2019 11:31 am
For the the 1.02 looks good. I fixed the changes I made within emulator (my biggest problem was that I had forgotten to 'format' the Genie). Now, both look good to me. See screengrabs below...
1.01 running in a modified BeebEm
1.02 running in a modified BeebEm
:( I also just noticed a bug in 1.02 where the vertical lines in the status panel are 1 pixel too long and go outside the top of the box... :(
billcarr2005
Post by billcarr2005 » Mon Jun 10, 2019 10:25 pm
I think that was my thinking behind the following #-o :roll:
tripmeup
Post by tripmeup » Tue Jun 11, 2019 3:46 pm
Yes, you're right. I modified my copy of BeebEm to automatically format the battery-backed RAM on first use... I really don't know why I didn't add the code to Genie in the first place.
void GenieFormat()
	unsigned char initVals1[] = {
		0x37, 0x1B, 0x36, 0x1E, 0x1E, 0x35, 0x12, 0x10, 0x36, 0x34, 0x00, 0x00, 0x03, 0x01, 0x01, 0x01,
		0xFF, 0x01, 0x01, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
		0xF7 };
	unsigned char initVals2[] = {
		0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x81 };
	memcpy(&GenieRam[4][0x00], initVals1, sizeof(initVals1));  // Set default password to GENIE, and init some structures
	memcpy(&GenieRam[4][0x70], "Derek", 5);  // Magic word
	memcpy(&GenieRam[4][0x80], initVals2, sizeof(initVals2));  // Initialise linked lists and free memory pointer.
	GenieRam[4][0xF0] = 0x6E;
Post by Pernod » Tue Jun 11, 2019 4:25 pm
void GenieFormat()
		0xF7 };
So is this essentially all the formatter does?
tripmeup
Post by tripmeup » Tue Jun 11, 2019 4:55 pm
Yes, I think so. I remember the process was pretty simple...
