- BASIC Interpreter / Run Time Engine:
Added the PTR()= syntax to set the pointer of a structure, array or string.
Extended =PTR() to return the pointer of a structure or array as well as a string.
Added = SYS("function") to return the address of an API function, or zero if it doesn't exist.
Added support for @cmd$ possibly being longer than 255 bytes.
Changed TIME from unsigned to signed, since code like 'T% = TIME' is very common.
Fixed a minor problem with the 'pending newline' mode (VDU 23,16,1|) (needs fixing in BB4W too!).
Fixed a bug (in the 64-bit and ARM editions only) causing assigning a string to a numeric variable not to result in the expected 'Type mismatch' error.
- IDEs and Utilities:
SDLIDE: Implemented breakpoints, very similar to those in LBB and bbcide (double-click in the left margin to add or remove a breakpoint).
SDLIDE: Enabled the Print option in the File menu and toolbar. This prints the current program to the default printer.
- Libraries:
Modified filedlg to fix an incompatibility with *HEX 64 mode.
Modified dlglib to reduce CPU usage when idling, especially when a List Box has the input focus.
Modified socklib to prevent a 'double-free' error if PROC_exitsockets is called twice.
- Example Programs:
Modified Ceefax.bbc to recognise the word Thunder in the weather description and display the 'storm' indication.
Modified telstar.bbc to include 'ANSItex BBS' in the list of services, and to disable 'pending newline' mode.
BBC BASIC for SDL 2.0 version 1.15a released
I've released version 1.15a of BBC BASIC for SDL 2.0 - the cross-platform programming language for Windows, MacOS, Linux, Raspbian, Android, iOS and WebAssembly (Chrome/Edge/Firefox). The changes in this version are as follows:
Re: BBC BASIC for SDL 2.0 version 1.15a released
Out of curiosity, what was the issue?Richard Russell wrote: ↑Fri Sep 11, 2020 5:16 pmFixed a minor problem with the 'pending newline' mode (VDU 23,16,1|) (needs fixing in BB4W too!).
Matrix Brandy BASIC VI (work in progress) The Distillery (another work in progress)
It's quite obscure. This program will demonstrate it, if present:
10 MODE 7
20 VDU 23,16,1|
30
40 DIM x%(13), y%(13)
50
60 FOR c% = 8 TO 13
70 PRINT TAB(0,3) STRING$(40,"x");
80 VDU c%
90 x%(c%) = POS : y%(c%) = VPOS
100 NEXT
110
120 CLS
130 @% = &904
140 FOR c% = 8 TO 13
150 READ X%, Y%
160 PRINT x%(c%), y%(c%) " (should be ", X%,Y% ")"
170 NEXT
180
190 DATA 39,3, 1,4, 40,4, 40,2, 0,0, 0,3
In case of TL;DR can I draw attention to the two main new features in SDLIDE, printing and breakpoints:
Printing
The Print option in the File menu and the Print button in the toolbar are now active. They both result in the current program (as displayed in the editing pane) being listed on your default printer. SDLIDE gives no control over layout, font etc. but your Operating System should provide a way of configuring the default printing options, either at a command prompt or via a GUI.
Breakpoints
You can set (or clear) a breakpoint on a program line by double-clicking in the left margin, pressing Ctrl+B or using the Run... Toggle Breakpoint menu option. When such a breakpoint is set, the program will pause on that line (if it is ever executed) when run in Debug mode; breakpoints have no effect if the program is run 'normally'.
In the paused state you can examine variables, stop the program, run to the next breakpoint (if any) or single-step execution (Step Into or Step Over); adding or removing breakpoints will have no effect until the next time the program is run. You can clear all breakpoints by pressing F4 or using the Run... Clear Breakpoints menu option.
Printing
Breakpoints
Thank you. As I suspected, Matrix Brandy also has a bug in that, the second one came out as 0, 4 instead of 1, 4. Now I know what I'll be doing this evening once the small monster is in bed!Richard Russell wrote: ↑Sun Sep 13, 2020 2:28 pmIt's quite obscure. This program will demonstrate it, if present:
Edit: Fixed!
If you've noticed some Ceefax pages not displaying correctly recently, you're not alone. The BBC has changed the HTML format of some of its news pages and this has broken the parser in Ceefax.bbc. I've now fixed this and updated both BBC BASIC for SDL 2.0 and the standalone Android app, although it's always going to be a case of catch-up as the BBC is bound to change things again.
With the portfolio of 'my' versions of BBC BASIC now being quite large I have created this grid showing which version has which capabilities. The boxes marked ? indicate features of which the version is theoretically capable, but I haven't yet attempted an implementation:
I can't find where somebody asked about it, but with my copy of Ceefax.bbc I've done the following tweek which lets you use the "colour keys" f1-f4 for the four fastext-like coloured links.Richard Russell wrote: ↑Mon Sep 14, 2020 5:59 pmIf you've noticed some Ceefax pages not displaying correctly recently, you're not alone. The BBC has changed the HTML format of some of its news pages and this has broken the parser in Ceefax.bbc. I've now fixed this and updated both BBC BASIC for SDL 2.0 and the standalone Android app, although it's always going to be a case of catch-up as the BBC is bound to change things again.![]()
In DEF PROCtimer at the end of the CASE key$ OF structure change to:
WHEN CHR$130,CHR$9: Page% = 100 : Auto% = FALSE : Abort% = TRUE
WHEN CHR$145,CHR$27: PROCback
WHEN CHR$146,CHR$132,CHR$128: PROCprev
WHEN CHR$147,CHR$133,CHR$129: PROCnext
WHEN CHR$148,CHR$131,CHR$32: Auto% = TIME
WHEN CHR$13,CHR$136,CHR$137,CHR$138,CHR$139: PROCnavigate(ASCkey$)
PDP11 BBC BASIC IV Version 0.36
