BBC BASIC for SDL 2.0 version 1.13a released
Deleted User 9295
Post by Deleted User 9295 »
I've released version 1.13a of BBC BASIC for SDL 2.0 - the cross-platform programming language for Windows, MacOS, Linux, Raspbian, Android and iOS. The changes in this version are as follows:
  1. BASIC Interpreter / Run Time Engine
    Implemented VDU 23,18,3,n| to enable or disable alpha/graphics black and secondary character set in MODE 7. It also 'fixes' the SAA5050 Hold Graphics bug.
    Implemented OSWORDs 139 & 140 (again!) to read and redefine the 'teletext' font (documented here).
    Reduced SOUND latency (which risks buffer underrruns on slow systems, but I hope is a better compromise).
    Setting bit 6 of *TEMPO changes the way the pitch envelope repeats to be more compatible with the BBC Micro (it's also now the default).
    Fixed a bug affecting 'scrolling' of one-row-high text viewports (64-bit and ARM editions only).
  2. IDEs and Utilities
    SDLIDE: When loading an Acorn-format tokenised program, 2-byte tokens are automatically converted to their 1-byte equivalent (if any).
    SDLIDE: The file selector now uses smooth scrolling.
  3. Libraries
    Added classlib for Object Oriented Programming, compatible with the BB4W library.
    Added mode7lib to support multiple character sets in MODE 7 (the primary and secondary character sets may be selected from English, German, Swedish, Belgian, Italian, Hebrew, Russian, Greek or US ASCII).
    Modified dlglib and filedlg to support smooth scrolling of listboxes.
  4. Example Programs
    Added sortdemo.bbc (in examples/general) which is a graphical demonstration of six different sorting algorithms, adapted from a QuickBasic program.
    Added a page to mode7dem.bbc to demonstrate alpha/graphics black and the secondary character set.
    Tweaked bbclock.bbc to improve its reliability (previously it could misbehave after running for a few hours).
    Fixed telstar.bbc which was partially broken by the change of the MODE 7 font in v1.11a.
This new version may be downloaded, for all the supported platforms, from the usual location. The GitHub repository has been updated (used to build the MacOS, Raspbian, iOS and 64-bit Linux editions, currently).
Please remember that if you use the BBC2APK Android Application Generator you should download a new APK template to ensure that any updates to the run-time engine are incorporated in your own apps.
Deleted User 9295
Re: BBC BASIC for SDL 2.0 version 1.13a released
Richard Russell wrote:
Fri Jun 19, 2020 5:33 pm
Post by BigEd »
Oh, I do like that! (Hadn't heard of one of those... will have to look it up)
This link worked better for me:
https://www.youtube.com/watch?v=rEcuaOznQo8
Deleted User 9295
BigEd wrote:
Sun Jun 28, 2020 7:22 am
I think you may need Flash enabled for the embedded video to work, but it's too useful a feature of the forum not to make use of it.
Return to “modern implementations of classic programming languages”
