BBC BASIC for SDL 2.0 version 1.12a released
Richard Russell
Post by Richard Russell »
I've released version 1.12a of BBC BASIC for SDL 2.0 - the cross-platform programming language for Windows, MacOS, Linux, Raspbian, Android and iOS. The changes in this version are as follows:
  1. BASIC Interpreter / Run Time Engine
    Updated the MacOS edition (only) to SDL 2.0.12 to fix some graphical glitches.
    Enabled render batching in the iOS edition (deferred from 1.11a because of a compatibility issue).
    Improved the Windows edition's compatibility with the username containing non-ASCII characters.
  2. IDEs and Utilities
    In the SDLIDE file selector, starting to type the wanted filename scrolls the listbox.
    Updated BBCEdit to version 0.34.2 (thanks to Andy Parkes).
    Updated touchide to support copying-and-pasting entire directories.
    Fixed a memory leak in SDLIDE's Compile utility.
    When SDLIDE is used with BBC BASIC for Windows the Compile utility now works (it calls the BB4W compiler).
  3. Libraries
    Added the imglib library for rotating, scaling and flipping 2D images efficiently (a highly compatible library is also available for BBC BASIC for Windows).
    Modified the filedlg library so that starting to type the wanted filename scrolls the listbox.
    Added FN_utf8_to_ansi() and FN_ansi_to_utf8() functions to the utf8lib library.
    Fixed a bug in the box2dgfx library affecting non-zero y-origin values when PROC_gfxMatrix is used.
  4. Example Programs
    Added bbclock.bbc (in examples/physics), a graphical Box2D simulation of a 'Ball Bearing Clock'. This program is compatible with BBC BASIC for Windows if the Box2D libraries are installed.
    Added dunebuggy.bbc (in examples/physics), a Box2D demo of a vehicle with sprung suspension. This program is compatible with BBC BASIC for Windows if the Box2D libraries are installed.
    Added kerning.bbc (in examples/general/) to demonstrate the effect of kerning. This program is compatible with BB4W.
    Modified aliens.bbc to use the new imglib library; this also makes it compatible with BB4W, but without hardware acceleration it runs only slowly.
    Fixed a bug in SkyBaby.bbc affecting some editions (e.g. Android but not Windows), caused by a surprising anomaly in the 'asctime' and 'mktime' C runtime library routines.
This new version may be downloaded, for all the supported platforms, from the usual location. The GitHub repository has been updated (used to build the MacOS, Raspbian, iOS and 64-bit Linux editions, currently).
Please remember that if you use the BBC2APK Android Application Generator you should download a new APK template to ensure that any updates to the run-time engine are incorporated in your own apps.
Richard Russell
Re: BBC BASIC for SDL 2.0 version 1.12a released
Here's a taster of the updated Box2D Ball Bearing Clock supplied with BBCSDL v1.12a:
Richard Russell
Another of the Box2D demos supplied with version 1.12a:
Return to “modern implementations of classic programming languages”
