Repton Instructions
having trouble with an archived file? post in here!
melchett
Repton Instructions
Post by melchett »
I noticed in the Repton loader instructions that it states the following:
To view the map, you must pass over the MAP character during game play; the map is then seen whenever you press "M".
In the code there is no check for a special MAP character, indeed no character exists. The code just checks to make sure the screen is A-H and not I-L when the M key is pressed. I'm uncertain of the origins of those words, were they in the cassette inlay? Can the instructions please be updated to remove that?
geraldholdsworth
Re: Repton Instructions
Post by geraldholdsworth »
That would refer to the Electron version, where the map character did exist.
melchett
Post by melchett »
geraldholdsworth wrote:
Mon Oct 04, 2021 2:33 pm
Interesting that they are different, wonder why? The MODE 7 text for that BBC image is still incorrect though and should be updated.
melchett
Post by melchett »
Also looks like the text was sourced from here -> http://www.acornelectron.co.uk/info/ele ... ton-1.html
Michael Brown
Post by Michael Brown »
Thanks for spotting this.
I have amended the instructions on my disc and sent a copy to Lee for uploading.
The instructions are now as per original BBC tape inlay.
regards,
Mick.
melchett
Post by melchett »
Thank you Mick (and Lee!)
joachim
Post by joachim »
Another Repton instruction pedanticism: in the bbcmicro.co.uk loader for Repton 2 prerelease version, http://bbcmicro.co.uk/game.php?id=2419 we are told that 'The completed puzzle reads "REPTON 2 IS ENDED"'.
This would be true for the final release version, but in this prerelease, the puzzle pieces to the left of the starting area appear to say "COMPLETED" instead of "IS ENDED". So presumably the completed puzzle reads "REPTON IS COMPLETED", or something very similar.
geraldholdsworth
That is correct, almost - "REPTON IS COMPLETE", with the opening level being red and not blue and there being a missing diamond on another level.
Return to “archive issues”
