Repton Instructions
having trouble with an archived file? post in here!
melchett
Repton Instructions
Post by melchett »
I noticed in the Repton loader instructions that it states the following:
To view the map, you must pass over the MAP character during game play; the map is then seen whenever you press "M".
In the code there is no check for a special MAP character, indeed no character exists. The code just checks to make sure the screen is A-H and not I-L when the M key is pressed. I'm uncertain of the origins of those words, were they in the cassette inlay? Can the instructions please be updated to remove that?
geraldholdsworth
Re: Repton Instructions
Post by geraldholdsworth »
That would refer to the Electron version, where the map character did exist.
melchett
Post by melchett »
geraldholdsworth wrote:
Mon Oct 04, 2021 2:33 pm
Interesting that they are different, wonder why? The MODE 7 text for that BBC image is still incorrect though and should be updated.
melchett
Post by melchett »
Also looks like the text was sourced from here -> http://www.acornelectron.co.uk/info/ele ... ton-1.html
Michael Brown
Post by Michael Brown »
Thanks for spotting this.
I have amended the instructions on my disc and sent a copy to Lee for uploading.
The instructions are now as per original BBC tape inlay.
regards,
Mick.
melchett
Post by melchett »
Thank you Mick (and Lee!)
Return to “archive issues”
